Sollte funktionieren da, da 1.1.0 drauf ist. Nur bei 1.0.0 nicht
Note Due to changes in patching and the structure of saved files, scenes and shows created with V1.0.0 are not compatible with later firmware releases. When updating the SQ firmware from V1.0.0, all current settings will be reset, and all existing saved data (Scenes/Shows/Libraries) will be incompatible. This is not the case when updating from any subsequent version of firmware.
