• Externer Inhalt youtu.be
  • Firmware 1.02 Important Notes
    1. The version 1.02 includes new firmware for the fader boards and an update for the WING LIVE SD recording card, which unlocks exciting new features. Please wait until all boards are updated. Do not switch off during the update.
    2. Reacting on user feedback and for consistency with X32, we have changed the EQ Bandwidth parameter to Q. Hence, existing snapshots will be automatically converted on first load. To make this work properly, please: a. Select the Snapshot b. make sure all SAFES are inactive c. make sure to load the old Snapshot with scope set to 'ALL' d. save/overwrite snapshot after successful load
    New Features
    • TC Electronic VSS3 Reverb, from award-winning System 6000, with new Preset-Function – the true Stereo Source Reverb behind thousands of movie and audio productions
    • Stereo/4-Channel 24-Bit Recorder/Player for all FAT32 formatted USB sticks
    • Channel alignment delay increased to max. 8 m (23.3 ms)
    • WING Copilot app and Mixingstation app support, incl. UDP metering and console discovery
    • New FX mix control (dry/wet)
    • Filter adjustment range increased, LC up to 2 kHz, HC down to 50 Hz
    • SD Recording with 64-Channel sample synchronous link for WING LIVE
    • MUTE GROUP assignments via surface (hold MUTE GROUPS and one of the 8 MUTE buttons, while selecting channels) MUTE buttons flash when respective mute group is active
    • Console Init with scope selection
    • EQ bandwidth parameter changed to Q
    • TREMOLO auto gain correction
    • Option to copy the FX name to its channel/bus
    • EXT FX bypass time alignment and send trim
    • Suboctaver FX Mix control added
    • MIDAS I/O Box support (DL251, DL15x, DL231)
    • TAP function on custom controls (UTILITY button on custom controls page allows to adjust flashing behavior)
    • 4 GPIO ports can be configured on the custom controls page, offering outputs or inputs for many different parameters
    • Startup-screen shows update status of fader boards, card, etc.
    • Fader speeds can be selected for Fast/Medium/Slow (UTILITY on fader assign page)
    • Solo-In-Place extended to buses
    • Snapshot scopes enhanced
    • Pure JSON for all snapshot-parameters
    Improvements:
    • TCP stack connection issues fixed
    • Several GUI glitches fixed
    • Main 3/4 send into Matrix 8 issue fixed
    • Channel strip solo button light fixed
    • RTC drift (too fast) fixed • IP stack TCP bug fixed
    • User controls crash fixed Firmware Update Process
    1. Connect a USB cable to the rear panel USB port and to your computer.
    2. Either hold the blank button on the main display during power-up or open the SETUP/GLOBAL Edit page in order to enable OS ACCESS.
    3. A drive icon will appear on your computer, similar to connecting a flash drive or external hard drive. Double click the drive to open.
    4. Extract the firmware zip file and drag/copy the new firmware file into the WING OS drive.
    5. After copying is completed, please eject the WING OS drive from your PC.
    6. WING should reboot automatically a few seconds after ejecting the drive. If it doesn’t, please power cycle the console, and verify the correct firmware version on the lower right corner of the SETUP screen. Note, WING will always boot using the most recent firmware in the OS drive. However, it is recommended to delete older firmware files or move them to a subfolder.
    Schick, dass die blauen DL15x Stageboxen jetzt funzen.
    Was ich ziemlich nötig für das nächste update finde, ist, dass die Kiste per USB-Stick updatebar wird so wie die meisten anderen Pulte und man dafür nicht extra nen Rechner anschließen muß!?
  • das Delay in den Eingangskanälen ist immer noch zu kurz
    bei Videogeschichten kann nur ein ganzes Frame ausgleichen
    schön finde ich das man den FX Namen "vererben" kann
    kann man den Copilot denn schon irgendwo finden?
    Einmal editiert, zuletzt von steffen r () aus folgendem Grund: bin aus dem WLAN geflogen
  • Zur 1.02 hat sich nichts geändert. Lediglich ein kleiner Fehler in der Vss3 Grafik wurde gefixt.
    Weiter werden jetzt auch "schlechtere/mehr" USB Sticks erkannt.
    die 3 Fadergeschwindigkeiten sind ab 1.02 einstellbar.
    Scyte: die Bedienung der Copilot auf einem Telefon wäre für mich eine finger-und augentechnische Herausforderung. Alle Achtung.
  • Slow/med/fast ca.120 KM/h;)
    Mein Gefühl: slow ist die oft bemängelte Geschwindigkeit von 1.01. Fast ist sicher ausreichend ohne die Schlagartige Positionswechsel die ich immer gehasst habe (M32)
    Ich bin bei MED gut aufgehoben.
    Einmal editiert, zuletzt von glen ()
  • Bei mir funktioniert die App unter Android trotz Warnung vor der Installation.
    Bei IOS 10.33 auf einem IPad 4 kann ich problemlos installieren,
    aber beim App Start wird nach dem B-Logo der Bildschirm schwarz und Ende.
    also wohl die Tablette zu alt...?
    DAS IGNORIERE ICH NICHT MAL!
