Hier die Änderungen und Verbesserungen in V1.06
- Metering on all routing pages indicate raw input signals
- Bus to bus mixing (all buses can send into buses 1..8)
- Delay for main buses
- Pre/post selection for bus to bus and bus/main to matrix sends
- FX parameters can now be assigned to faders
- Dynamic EQ for the gate plugin slot
- Compressor 'all' switch (gui) for 76 limiter amp
- GPIO control can be assigned to custom control buttons directly
- Talkback can be controlled by custom controls (and GPIO)
- RTA metering on GEQ FX
- Console lock function holding the HOME button depressed
- Source assignment/mode switch and phantom control on channel HOME page
- Channel delay moved to post fader
- Improved customization copy during source assignment (drag)
- USB player with song list, re-ordering and repeat functions
- Up to 4-ch USB play and record at the same time (with fast usb drives)
- USB transport buttons in custom control section
- New routing page to assign sources to channels
- Firmware update from usb drive via setup menu
- Increased usb drive compatibility
- Random sends on fader bug fixed (faders not moving)
- Increased stability of the usb player/recorder
- General gui/workflow bugfixes and enhancements
Ein Segen ... das updaten per USB Stick funktioniert jetzt.
