  2. unknown_artist
Beiträge von unknown_artist
  • "4.VIERSENER FORUMSTREFFEN" 20.8.06 Viersen (NRW)
    • unknown_artist
    • 8. August 2006 um 13:09
    hmm - bis wann kann man sich denn anmelden - zu 80prozent kann ich(obwohl ich mir dann als kleiner unschuldiger Selberwastler HKS schon nahezu alleine vorkomme :D )....
    MfG Julian
  • Rog´s Audio-Quiz
    • unknown_artist
    • 7. August 2006 um 11:28
    http://www.party-pa.de/phpBB/viewtopic.php?p=420229#420229
    "Grandiose" 43 Punkte - Englisch war noch nie meine Stärke...
  • Rog´s Audio-Quiz
    • unknown_artist
    • 6. August 2006 um 21:46
    Your Score is 43/60 or 71.7% of questions answered correctly
    Das ist unfair - das ist alles auf ausländisch - versteht doch kein Schwein :grin:
    Meine schönsten Fehler
    3. You are on a stage or in a recording studio and see a pink signal cable. What does this tell you.
    You answered: A (That earth has been lifted (pin 1 not connected)) Incorrect!
    Correct answer is: C (That the phase has been reversed (pins 2 and 3 swapped))
    Wer weiß denn sowas?Ich hab keine pinken kabel...
    13. Which combination of woofer voice coil length and magnetic gap height would give maximum efficiency?
    You answered: A (Short coil with deep gap) Incorrect!
    Correct answer is: C (Equal height coil and gap)
    Ja fragt sich nur in welchem Frequenzbereich wa roger...
    18. Which type of enclosure would best suit an 18" woofer with these parameters: Fs: 30 Qts: 0.22 Vas: 428L BL: 23 Mms: 123g SPL: 99 dB
    You answered: A (4th order bandpass horn hybrid) Incorrect!
    Correct answer is: B (2.2 meter rear loaded horn (scoop))
    Is doch eh datselbe....und wie de dat dingen abstimmst, meine güte...
    30. A horn loaded speaker would typically have an efficiency of between
    You answered: B (1 to 20%) Incorrect!
    Correct answer is: C (20 to 50%)
    ich pöhser purche hatte da mal was von 25percent maximal im kopf, na ja roger...
    36. What causes a 4th order bandpass horn hybrid enclosure to suffer from colourations (Horn Honk) at very high power inputs?
    You answered: A (Cabinet resonance's) Incorrect!
    Correct answer is: B (The short horn amplifying the high pressure and high velocity air movement)
    nur weil der keine Hybriden bauen kann soll ich doof sein oder wie- Schweinerei...
    45. What steps can be taken to avoid LF beaming in horizontal ground stacked bass arrays (power alley effect)?
    You answered: C (Outer placed enclosures can be delayed with respect to the inner placed enclosures) Incorrect!
    Correct answer is: B (Outer placed enclosures can be frequency shaded (lowpass filter the outer enclosures))
    Entweder hab ich den Satz nicht verstanden oder auf der Insel geht irgendwas anders als bei mir...
    50. A horn speaker system can be explained as.
    You answered: B (A driver in a closed box radiating into a constant flare angle) Incorrect!
    Correct answer is: C (A driver in a closed box radiating into a pure acoustic resistance)
    DAS Horn will ich sehen - es geht darum den reaktiven anteil zu drücken - rein reel wird man den Strahlungswiderstand wohl nicht bekommen...
    58. Why might you use an RTA?
    You answered: B (To measure a systems frequency response) Incorrect!
    Correct answer is: C (To make a systems frequency response flat)
    Hier ist doch mal grob logisch was falsch oder?
  • YAMAHA SP 2060
    • unknown_artist
    • 6. August 2006 um 16:25
    Aber der Controller hat ein Delay(im Gegensatz zu vielen günstigen Controllern(der kleine Xilica etc)! Hm normale Bässe würde ich nicht über nen Aux-Weg ansteuern - nur Infra Sachen ala S2 o.ä. Wofür gibts nen Eq...
  • mittelklasseamp gesucht
    • unknown_artist
    • 6. August 2006 um 13:28
    Zitat von "SMPTE"
    hallo
    ich kenne palmer nur als DIbox etc hersteller. ich weiss zwar dass es amping von denen gibt habe jedoch noch nie mit gearbeitet.
    dass die dinger zuverlässig sind, davon gehe ich mal aus.
    wie sieht es mit gewicht aus ?
    wenn ich das richtig sehe haben die 3 HE, ok, jedoch frage ich mich ob eine investition in nen Class H oder gar D amp mit 2 oder auch 1 HE zukunftssicherer wäre.
    Ist schon wichtig - was ist dir wichtiger
    |eine gute Handelbarkeit in Bezug auf Gewicht und abmessungen und evtl. Erweiterungen wie z.B die S-Serie
    | das letzte Fünkchen Bassperformance - dann ist die vorgeschlagene Crest Ca eigtl das Mittel der Wahl...
  • EBAY II - Alles zum Thema ebay bitte nur hier posten
    • unknown_artist
    • 5. August 2006 um 15:43
    vergiss die daten - die angaben sind unrealistisch...
    Das ist HIFI
  • 4x SK-BH mit amping für 12.-13. Aug. Raum Köln/Bonn/Düsseld.
    • unknown_artist
    • 5. August 2006 um 14:08
    Hab 8Stk der Bastelhörner -Bei Interesse - PN....
    Das Zeug kann evtl bis Köln geliefert werden - nur melden musst du dich :D
    • unknown_artist
    • 5. August 2006 um 13:12
    was auch preislich noch in Ordnung sind - die neuen kleinen Ram Audio S.
    Die S2000 wäre leistungsmäßig genau das was du suchst und preislich interessant...
    • unknown_artist
    • 5. August 2006 um 12:45
    Zitat von "Ravemaster"
    Der WIrkungsgrad ernscheint mir etwas hoch. da das ein Breitbänder ist kann der Freq bereich stimmen. aber dazu sollen lieber die was sagen die das ding schon in der hand hatten
    Ihr Stümper - das ist Highend - das ist kein Lautsprecher - das ist Legende - sowas gibt es leider fast nirgends zu kaufen.... Und laut sind die auch - so laut naja - aber welcher Hersteller gibt schon passende Daten an - nichts destotrotz High End...
    Hmm da fällts mir ein das hatte was mit Lowther zu tun oder...
  • Hybrid
    • unknown_artist
    • 5. August 2006 um 12:34
    dann hätte er hybriden :)
    OT: Eigtl hacke ich nicht gerne auf Rechtschreibfehlern rum - aber wenn der Threadtitel schon grobe Ausrutscher hat - vergeht einem die Lust.... und für 50 Leute braucht man was anderes als für 3kPax...ausser du bekommst es irgendwie hin 100 HK Lukas zu clustern...
    • unknown_artist
    • 4. August 2006 um 18:37
    sagen wir so - ein arls ist besser - ich geb mal keine Wertung ab - sonst werde ich gleich wieder geschlagen - man kann sie nehmen - aber vertrau mir - und lass es....Bau dir was fürs selbe Geld...
    • unknown_artist
    • 4. August 2006 um 17:43
    gar nicht....nen arls geht besser...wenn der wunsch besteht probehören ev gegen arls ist möglich
  • SK212 welche AMP?
    • unknown_artist
    • 4. August 2006 um 13:01
    Hören bildet.
  • SK212 welche AMP?
    • unknown_artist
    • 3. August 2006 um 18:39
    Zitat von "-Schrecki-"
    Ob jetzt die Endstufe am schlechten Klang ist, naja ich glaube nicht an Endstufenklang...
    Ohne auf das restliche Geblubber einzugehen - Ich schlage einfach mal vor wir gehen in eine gut sortierte Hifi-Abteilung und hören mal eine runde - Wenn du danach noch zu dem Statement stehst - ok....
    Wirst du aber nicht tun :grin:
    und im übrigen denk noch mal nach was für ne Impendanz die gebrückte 700er sieht - das ist nicht so unkritisch...
  • I don´t need THAT!!!
    • unknown_artist
    • 2. August 2006 um 23:00
    lol - der war aber mal echt unter der Gürtellinie...
  • Seeburg TKE212 auf Aktivbetrieb umstellen
    • unknown_artist
    • 2. August 2006 um 20:09
    Zitat von "Eric"
    joa... also mit viel leistung das ist ja schön und gut, aber warum so viel ?! Der Treiber ist doch wahrscheinlich(Ich weiss nicht was da für ein Treiber drin ist!!!) maximal nur mit "200 W" angegeben ... warum prügelt ihr da gut das doppelte drauf? Nur um zu verhindern das der Treiber ins Clipping kommt?
    Die Teile können sehr hohe Spitzenleistungen ab - deshalb so eine dicke Amp...
  • Stackhöhe
    • unknown_artist
    • 30. Juli 2006 um 17:18
    Zitat von "Kracky"
    +bei uns werden Antirutschpads dafür genommen, vorne an der Box zwei große, hinten je nach Reichweite wird mit kleinen unterlegt um den Lautsprecher an zu kippen. Durch den nach vorne gestellten Lautsprecher und nach hinten gezurrte Gurte hast du dann eigentlich kein Problem mit der Trapezform, haben wir auch öfters bei R32.
    Äh, haste ma nen bild - kann ich mir schwer vorstellen immoment...
    • unknown_artist
    • 30. Juli 2006 um 11:20
    Zitat von "fladdi"
    http://cgi.ebay.de/Grundig-PA-3-S…1QQcmdZViewItem
    Ohne worte
    ist doch ok... was soll denn daran komisch sein?
  • Forentreffen in Böttingen am 15. Juli 2006
    • unknown_artist
    • 30. Juli 2006 um 10:57
    les noch mal durch...vielleicht ist der Satzbau nicht ganz klar... :D
    Leider hatte ich auch nicht klar formuliert - mein fehler - aber das etwas einsilbige Statement bezog sich auf
    Ausser von dir und dem Mynut habe ich das aber noch von NIEMAND
    anderem gehört.
    Aber - denkst du nicht das die Diskussion nicht hier hingehört? :?
  • Neodym Magnet Temperaturtest
    • unknown_artist
    • 29. Juli 2006 um 22:10
    Zitat von "Dirk Hahn"
    Hallo Julian, Curietemperaturen liegen bereits ab 70° vor. Kannst du mir beantworten, warum hier bei über 150° C noch kein Memorieeffekt vorhanden ist?
    NdFeB hat eine Curie Temperatur von ca 310° C...Und gerade bei geschickter Kombination der verschiedenen magnetischen Werkstoffe, lässt sich mittlerweile auch bei Neo - Magneten eine gute thermische Stabilität ereichen.
    Deshalb auch kein Memoryeffekt....
  1. Leatcon 2026 Forumstreffen
