  2. djobi
Beiträge von djobi
  • I don´t need THAT!!!
    • djobi
    • 14. November 2005 um 15:11
    aber Sven! Doch nicht in der Kirche!
    (btw: Manuela hatte doch da auch ne nette Anekdote mit ihrem Bühneanhänger, oder? :D )
    /OT-Modus aus
  • Copy und Paste?
    • djobi
    • 14. November 2005 um 10:30
    bevors weg ist halten wirs doch für die Nachwelt fest - natürlich mittels copy & Paste :D :
    Zitat von "www.novacoustic.com"
    Philosophy
    The UHF-101 is a high quality wireless system promising an optimum in sound reproduction and brings sophisticated professional features at an affordable price level.
    The UHF-101 is a self-adapting super cardioid dynamic cartrige with highly consistent super cardioid pattern at 120o off-axis. It creates superb isolation and unsurpassed "gain-before-feedback", optimized for using in vocal and instrument performance. The feature of noise absorption eliminates external and handling noise. The stable steel grille avoids damages. A durable structure modular design enables easy assembly and detachment, especially for after sales service.
    The UHF-101 receiver is made in professional metal design. With its 2 x 20 digits LCD display it shows always information
    about the wireless system configuration, levels and channels.
    Features:
    • Compact size-up to 2950 watts in 2 rack spaces professional quality
    • Performance-incorporates road-proven designs
    • High-current toroidal transformers for greater two-ohm power and low noise
    • Selectable low-frequency filters (30Hz or 50Hz) protect speakers and increase headroom
    • Balanced 1/4"(6.3mm)TRS, XLR and barrier strip inputs
    • Binding post and NeutrikTM Speakon outputs
    • Front mounted gain controls for easy access
    • Signal and Clip LED indicators to monitor performance
    • Independent DC and thermal overload protection on each channel automatically proects amplifier and speakers
  • Nischen und Ecken "abdichten"
    • djobi
    • 13. November 2005 um 23:54
    was ist denn ansonsten mit drängegitter? diese einfachen hüfthohen baustellengitter ?
  • Wie beleuchte ich am besten eine Outdoor-Eisbahn?
    • djobi
    • 13. November 2005 um 19:48
    Bei der Eisbahn in der Essener Innenstadt standen letztes Jahr stinknormale Wind-Ups mit stinknormalen Bars dran. Verkabelt mit ungeschützt verlängerten Harting-MuCo .. das fand ich echt prickelnd :?
    (Dazu nen Lichternetz it Pfosten in der Mitte und noch nen paar Flutern)
  • 50m rs232 steuerleitung realisierbar?
    • djobi
    • 9. November 2005 um 01:00
    lt. der tabelle sind ja mit 9600baud 150 m problemlos möglich - 9600 baud sollte zum Konfigurieren von Geräten auch reichen.
    vernünftiges geschirmtes Kabel (z.B. cat5 oder NF) verwenden und dieses vernünftig verlegen - gut is. Notfalls gibt es noch Line Driver (Verstärker).
    Wir hatten schonmal Störungen auf solche Verbindungen durch anlaufenden Aufzüge oder Grossbacköfen - also bitte getrennt von Stromleitungen verlegen.
  • UV-Fluter im Raum Duisburg
    • djobi
    • 9. November 2005 um 00:11
    Frag mal bei niclen.de , ist zwar DO, aber sollte ja noch in Reichweite sein, oder?
  • Ganz Ganz DRINGEND >Lichthelfer< GESUCHT !!!
    • djobi
    • 5. November 2005 um 10:07
    jaa .. schade
    hätte gerne geholfen, aber lese die anzeige wohl zu spät
    wenn mal wieder was ist: ich komm auch aus essen,
    mail oder pn oder 0179 - 39 745 70
  • Ärger, Unglücke während der VA oder beim Aufbau der PA???
    • djobi
    • 1. November 2005 um 23:54
    Zitat von &quot;Outliner&quot;
    eine traverse die ich nicht mehr brauchte gegen zwei omnitronic-18"bässe getauscht(ich dussel)
    schlechter Tausch! ;)
    (auch wenn ich den Sinn nicht ganz verstehe)
    ansonsten:
    mitten während der VA übers Amprack gestolpert und n Kabel abgetreten
    in der gleichen VA bekamen wir falsche Netzteile für die Verfolger geliefert und ich hab mir am ground-support noch die Fingerkuppe aufgeschnitten
    EQ falsch gesteckt, so dass sich gar nicht liefen :oops:
    Leuchtmittelausfall gabs immer schonmal
    bei ner Schul-VA ist auch mal nen Gitarrenamp ausgefallen
    so übliche Geschichten halt :)
  • Opening für Discoveranstaltung
    • djobi
    • 28. Oktober 2005 um 17:25
    such mal nach "Bernhards Partyhilfe"
    sind Sampler, da sind so Sachen drauf
  • PA-Amp im Hifi-Bereich
    • djobi
    • 28. Oktober 2005 um 17:23
    Was macht denn die von dir gepostete Endstufe in deinen Augen so mies?
    (vor allem weil du ja low-budget suchst)
    Und warum unbedingt PA Amp für Hifi?
    Was kommen denn da für Lautsprecher dran?
    Jens
  • Belastbare T-Bar gesucht
    • djobi
    • 27. Oktober 2005 um 12:20
    Warum kein Selbstbau?
    Ist kein grosser Aufwand
    Und dürfte am einfachsten zum gewünschten Ergebnis führen
  • "Checkliste" für Sub-Bau...
    • djobi
    • 26. Oktober 2005 um 23:25
    Zitat von &quot;LSV Hamburg&quot;
    Was bitteschön spricht eigendlich dagegen ein vernünpftiges Metall Anschlußterminal einzubauen ?
    Das verstehe ich allerdings auch nicht !?
    Ne Neutrik NL 4MP Buchse in die Blende, ggf. noch ne 2te zum Durchschleifen und gut. Die Blende dann mit der Fräse einlassen, dann ist auch alles ordentlich versenkt und geschützt
    • djobi
    • 26. Oktober 2005 um 22:02
    Wieso? Selbst Eurolite hat entsprechende Angaben:
    Max. spaced braceload: 30 kg
    Max. centered braceload: 25 kg
    Dimensions (LxWxH): 1500 x 40 x 60 mm
    Max. load per fixation point: 5 kg
    Dimensions (LxWxH): 2000 x 50 x 50 mm
    Leider ist auch die Wandstärke des Materials nicht angegeben.
    ich würd sagen hier sind die Metallbauer gefragt.
    Und nen entsprechendes Alurohr / Vierkantrohr mit 40 kg Belastbarkeit auf 1,5m sollte doch wohl zu finden sein.
    Wie hoch ist denn eigentlich so ein TV-Zapfen belastbar??
  • Probleme mit Soundcraft Spirit Live
    • djobi
    • 26. Oktober 2005 um 15:40
    Ansonsten machen immer wieder die Insertbuchsen oder die Busverkabelung an den Pulten Probleme .. :twisted:
  • Bass an Line in am Pult
    • djobi
    • 26. Oktober 2005 um 12:58
    also .. deinem Mischpult ist das wohl recht wurscht .. nur: wenn dein Mischpult ein übersteuertes Signal raushaut, geht das über die Endstufe in deine Boxen. DIESE können dadurch Schaden nehmen
  • Gewährleitung und Garantie nicht nur bei Ebay
    • djobi
    • 26. Oktober 2005 um 12:26
    mhh .. privat besitz ist doch privatbesitz, oder?
    Ist die Frage ob dein Ebay Account gewerblich angemeldet ist?
    Und ansonsten - hast du keine bei ebay aktiven Freunde? Familienmitglieder? :D
    Was mich noch intressieren würde wie die Sache aussieht wenn ich mit einem gewerblich angemeldeten Ebay-Account Geräte im Kundenauftrag verkaufe - muss ich dann auch die Gewährleistung geben oder kann ich die auf den Kunden abwälzen bzw. aussschliessen ??
  • Die königsklasse des Preisdumpings
    • djobi
    • 25. Oktober 2005 um 19:52
    also die 40 EUR machen den Braten jetzt auch nicht fett
    Zitat von &quot;Lex2003&quot;
    hm ja ich glaubs dir ja aber ich verstehe nicht wie eine firmma von sowas leben will. naja egal ... ist halt ärgerlich sowas
    kai
    das tut sich ja nicht. Leben tun die woanders von ...
    So Schulpartys laufen nur "nebenbei". Vermarktet wird das dann noch als "soziales Engagement" ... :?
    • djobi
    • 25. Oktober 2005 um 17:22
    nochmal: also ohne LJ/DJ hätte ich ja noch gesagt NORMAL
    ausserdem ist die eine VA nur ne kleine Lichtanlage
    bleiben immer noch 3 größere - wenn ich dabei jedoch wirklich noch 750 EUR für nen DJ einrechne (bzw. abziehen muss), kann ich dein Grauen durchaus nachvollziehen :-/
    (Und diese o.g. Kurse sind auch ein Grund warum ich lange nicht mehr an meiner alten Schule war :-/)
    • djobi
    • 25. Oktober 2005 um 17:10
    wer lesen kann ist klar im Vorteil:
    Code
    (dat is Ruhrpott :!:)
    • djobi
    • 25. Oktober 2005 um 17:03
    also ohne LJ/DJ hätte ich ja noch gesagt NORMAL (in unserer Ecke)
    Leider gewähren genug Firmen Schulen absolute Sonderpreise (2 Sets Projektor, 2 6er bars + ma dimmer + ma pult, 4 Macs mit Martin-Steuerung, F-100 o.ä. und DJ-Platz für ca. 400 EUR und weniger, teils mit anlieferung)
    Leider sind die Ansprüche für solceh VAs schon so hoch, das selbst in Schülerkreisen nur Markenequipment akzeptiert wird; das dann leider noch zu Schleuderpreisen abgegeben wird.
  1. Leatcon 2026 Forumstreffen
