Es geht um die Einbindung via Stackcontrol, den Rest kenne ich gut genug
Es gibt Prioritäten für jeden Platz, mehrere Modi (Last Takes Over), Einstellungen wenn keiner oder mehrere Sprechen.
Spoiler anzeigen
Camera Logic
- Camera Rotation Mode: The Camera Rotation Mode determines how the system manages up to three selected cameras, defined in the columns Cam A, Cam B, and Cam C.
- No Camera Rotation: The initially selected camera remains active, and no further switching to other cameras occurs. This mode is static and ensures that the chosen camera stays locked on the scene.
- Priority to Cam A: If Cam B or Cam C is initially selected, the system will switch to Cam A after a defined time interval. This mode ensures that Cam A has the highest priority in the camera sequence.
- Camera Rotation Scheduler: This mode continuously cycles between Cam A, Cam B, and Cam C, provided cameras and presets have been configured in these columns. The interval between each camera switch is based on the user-defined time, but with slight random variations to create a more natural and less predictable transition.
- Ensure that all cameras have their presets correctly assigned for the rotation modes to function properly. The system will only switch to cameras where both a camera and a preset have been selected.
- Channel Selection Mode: The Channel Selection Mode defines how the system decides which channel is selected based on specific conditions.
- First Wins: The system selects the first channel that meets the activation criteria, displaying a green indicator in the Active column. The selection is based on the cumulative speaking time minus pauses, shown in the Audio column. If two or more channels meet the Active state, the channel with the higher weighting is chosen. If they have equal weighting, the one that first activates the light blue indicator in the Audio column is selected.
- Last Takes Over: The system selects the most recent channel that meets the activation criteria, displaying a green indicator in the Active column. As with 'First Wins', the criteria for Active status are based on cumulative speaking time minus pauses (from the Audio column).
- A switch to the camera of another channel only occurs between channels with the same priority. If a channel with a higher priority than the currently active channel is displayed in the Active column, it will become the active channel, triggering the corresponding camera preset.
Channel Table Setup
- Overview: This page provides a detailed configuration interface for managing camera and microphone logic. Each microphone channel of all connected audio devices, along with three special situations, is represented as a separate row in the table. The columns allow you to define settings for each channel and configure how they interact with cameras and presets.
- The Channel Simulator simulates turning certain channels on and off via HTTP commands in the channel table, effectively mimicking microphone/DSP trigger signals. You can open it here: Open Channel Simulator
- Channel ID: The Channel ID column identifies each microphone channel or speaking position with a unique ID. For standard microphone channels, these IDs are assigned sequentially based on the connected audio device. The first audio device starts with Channel ID 101, the second with 201, and so on. Each audio device can manage up to 100 Channel IDs, except for the last audio device, which can support up to 300 Channel IDs. In the Standard Edition, the last audio device is Audio Device 4, while in the Extended Edition, it is Audio Device 8. Channel IDs 0, 1, and 2 are reserved for special situations, as explained below.
- Location and Name: The Location column allows you to specify a specific area in the room, while the Name column lets you label a channel with a participant’s name or another identifier. Both fields are optional but can be used to transmit data via the API for display as lower-thirds in video outputs. Leaving these fields blank will not affect the system logic.
- On/Off Toggle: Use the toggle in this column to enable or disable signal processing for a specific channel. Disabling a channel means it will no longer participate in microphone or camera logic.
- Status Indicators: The LEDs labeled Audio, Reservation, and Active provide real-time feedback for each channel, indicating whether audio is detected, a channel is reserved for activation, or currently active. Additionally, an API function allows the manual simulation of a channel's Audio state. This lets you toggle a channel between active and inactive Audio status, influencing how the algorithm processes microphone signals. This is especially useful for simulating microphone behavior through external control system.
- API Command Examples:
- ENABLE Channel ID 1: http://141.14.249.238:1881/browser?comman…1&value2=ENABLE
- DISABLE Channel ID 1: http://141.14.249.238:1881/browser?comman…&value2=DISABLE
- ENABLE Channel ID 103: http://141.14.249.238:1881/browser?comman…3&value2=ENABLE
- DISABLE Channel ID 103: http://141.14.249.238:1881/browser?comman…&value2=DISABLE
- The user will receive a confirmation or error message in the browser regarding the execution of the command when using the HTTP URL method.
- API Methods: These commands can also be triggered using the SC100's API via WebSocket or TCP/IP. Refer to the SC100 API documentation for details on how to use these methods.
- Speed Settings: The Speed column determines how quickly a channel achieves the Active status and how tolerant the system is to speech pauses. The setting affects the required speaking time and allowed pause duration as follows:
- At 0, the system allows longer speaking times before activation and tolerates longer pauses. This is useful for environments where speakers may have slower-paced speech.
- At 10, the system requires significantly shorter speaking times to activate the channel but also tolerates only brief pauses. This is ideal for fast-paced discussions or scenarios where quick responsiveness is critical.
- Condition Column: The Condition column is a powerful tool for managing complex microphone setups where multiple microphones may cover overlapping areas or when additional precision is required to select the correct microphone. By defining a dependency on another Channel ID, you can ensure that camera presets are triggered based on the optimal microphone selected by an external processing device, such as an IntelliMix® Automatic Mixer (e.g., Shure P300 or IntelliMix® Room software). This setup is particularly useful in environments where multiple microphones are installed, and the distance to the active speaker is roughly the same.
- Let’s consider an example:
- In a room equipped with multiple Shure microphones, such as MXA310, MXA710, or MXA920, the Microphone Camera Controller algorithm alone cannot reliably determine which microphone is the intended one for camera activation if the speaker is equidistant from multiple microphones. To address this, an IntelliMix® Automatic Mixer, such as the Shure P300 or IntelliMix® Room software, can be introduced to enhance the system's precision.
- In this setup, each microphone device is connected to the IntelliMix® mixer’s input as a summed signal output. The mixer processes the audio signals from all microphones and selects the optimal microphone based on its advanced audio algorithms.
- For example, consider the following configuration:
- Two microphone devices (e.g., MXA920) are installed, and their individual microphone lobes are assigned to Channel IDs 101 to 108 and 201 to 208 respectively.
- A Shure P300 IntelliMix® mixer is set up as Audio Device 3, with its summed outputs from the two microphone devices assigned to Channel IDs 301 and 302.
- To configure this system:
- In the Condition column of Channel IDs 101 to 108 (representing the lobes of the first microphone device), enter '301', which is the Channel ID of the P300 mixer’s summed output for the first microphone device.
- Similarly, in the Condition column of Channel IDs 201 to 208 (representing the lobes of the second microphone device), enter '302', the Channel ID for the mixer’s summed output of the second microphone device.
- With this configuration, the P300 IntelliMix® mixer acts as a decision-making layer, selecting the optimal microphone channel based on audio activity. The Microphone Camera Controller then uses the active Channel ID from the mixer to trigger the correct camera preset. This setup ensures precise and reliable microphone-to-camera mapping even in challenging acoustic environments with multiple overlapping microphones.
- Priority Column: The Priority column allows you to assign priority levels to different microphone channels or speaking positions in the room, ranging from 1 (lowest priority) to 5 (highest priority). By default, higher priority levels enable certain participants to override others and activate their associated camera presets more readily.
- Participants assigned Priority Levels 4 or 5 (indicated with stars) are granted additional advantages in terms of speech detection and retention of the Active status:
- The Speed setting for these priority levels is effectively increased by 2 to 3 steps, provided the resulting value does not exceed 10. This adjustment means that speech detection becomes faster, reducing the time needed for the participant to achieve Active status after starting to speak.
- Additionally, longer speech pauses are tolerated for participants with Priority Levels 4 and 5, as the behavior of lower Speed settings. This ensures that their Active status remains intact during natural speaking patterns, even if brief pauses occur in their speech.
- Camera Assignments: The columns labeled Cam A, Cam B, and Cam C allow up to three cameras and their corresponding presets to be assigned to each channel. These presets should reflect the areas of the room captured by the respective microphone channel. Selecting the (-) symbol for either the camera or preset indicates that no action will be triggered for that channel. In addition, the Preset column includes an Idle option: this activates the selected camera without calling any preset, leaving the camera in its current position.
- Verification: To test the configuration, you can click on the LED for any assigned camera preset. This will immediately activate the associated preset, allowing for quick verification of the setup.
- Special Situations:
- Channel ID 0: This special channel is activated when no microphone channel is active. Use the Speed column to set the response time for this state. It is often used to display an overview of the room, which can be configured using up to three cameras.
- Channel ID 1:This special channel is activated when the microphone camera controller detects an audio signal from the far end during a video conference. It is recommended to assign this channel a higher priority than the seats in the room to ensure that the far-end audio takes precedence over local participants.
- Refer to the Settings Far End Channel panel for additional insights on how to handle far-end audio effectively.
- Channel ID 2: This channel is used when simultaneous speaking is detected from too many positions in the room. You can assign up to three presets to handle this situation effectively.
Shure®, IntelliMix®, and Microflex® are registered trademarks of Shure Incorporated or Shure Acquisition Holdings, Inc. in the United States and other countries.
Time Settings Channel Logic
v3.2.5
- The Minimum Time between 2 Camera/Preset Recalls is the delay that the logic waits before triggering the next camera preset. Ensure that this time is set long enough so that the video transition remains smooth for the far-end participants. Note: Due to varying Pan/Tilt times required by different cameras to reach a preset, the duration between video transitions may vary. The time set here specifically refers to the interval between preset commands sent to each camera.
- The Additional Delay Times define the extra time added to the configured Speed of the respective Channel ID that the logic waits before activating this channel in the pre-event phase. In the post-event phase, it sets the minimum time the logic waits before switching to the camera preset of a newly selected Channel ID.
Additional Delay Time Channel ID No Microphone Active 0 Far End Channel Active 1 2 Or More Channels Active 2
