  2. walt
Beiträge von walt
  • 12" SW (neo-sub/ciare 12.00SW?) zu turbosound tcs-56?!
    • walt
    • 16. Mai 2005 um 22:25
    The Punisher Horn was designed for the Ciare 12.00SW driver. It brings the efficiency up to >100dB/1w/1m. A Ciare will handle 1500W in this horn with no problems. A stack of 4 cabinets driven with 6000W makes your eyeballs shake and makes it difficult to breath when standing close.
    Best regards,
    Walt
  • Punisher Horn Mod | Möglich?
    • walt
    • 16. Mai 2005 um 22:21
    I hope english is not a problem over here?
    I have designed the Punisher horn. When you make the design wider that might give some problems with the correct coupling of the driver to the horn. Try to keep the first section the same style as with the original Punisher. The distance from the speakerbaffle to the panel above will become less than 5cm. It is not known so far if this will have audible effects on the sound. Try and find out would be the advice.
    Best regards,
    Walt
    • walt
    Best regards,
    Walt
