  2. mike.e
Beiträge von mike.e
  • Emminence LAB 10 & 12
    • mike.e
    • 17. Oktober 2005 um 05:27
    It would certainly be possible to design something that has a higher cutoff than the labhorn. Eg F3 40hz.
    What are your requirements?
    Here is one already.
    http://www.billfitzmaurice.com/plans/product_…6dc3c1970839bdf
  • Simulation von Hörnern mit Finiten Elementen
    • mike.e
    • 15. Oktober 2005 um 05:15
    Zitat von "Walt"
    Hello,
    When measuring a real system one usually uses the FFT algorithm to get the frequency response. But your model is not a real system. It will not be faster to do it this way because the computer would have to simulate the whole system en then use the FFT algorithm. But by simulating the system the computer has already solved the equations of motion.
    Try to simulate by octave. Use much frequency points in the low frequencies and less in the higher frequencies. Currently I am doing a dynamic analysis on a container crane with the use of Ansys software. A harmonic calculation on 25 frequencies takes about 5 minutes on a good pc. This is with about 400 elements. You could try do reduce the number of elements.
    Also there are some techniques to reduce computation time but in your case this will be difficult.
    Best regards,
    Walt
    Perhaps for extensive trial and error computation,LINUX based parallel computing could prove useful?
  • EAW La400
    • mike.e
    • 14. Oktober 2005 um 04:35
    Sorry,Keine Idee. It isnt my site.
  • EAW La400
    • mike.e
    • 13. Oktober 2005 um 03:15
    BH760 goes one octave lower than LA400.
    http://mitglied.lycos.de/crusher844/ :D
  • Sound Klinik's "Bastelhorn"
    • mike.e
    • 13. Oktober 2005 um 03:11
    Zitat von "N-Dee"
    OT:
    -> MOAS:
    http://www.audioasylum.com/forums/HUG/messages/53364.html
    http://www.paforum.de/phpBB/viewtopic.php?t=12400&postdays=0&postorder=asc&start=60
    Greets,
    N-Dee
    http://www.geocities.com/xobt/
    http://www.geocities.com/xobt/basshorns/basshorns.htm
    • mike.e
    • 11. Oktober 2005 um 06:17
    :D Very good- I was waiting to see who would do this. What about 200hz?Im wondering what is the cutoff at the upper end.
    My pc does not enjoy 5mb gif files! :?
    Mike.e
  • suche servo-drive bausatz
    • mike.e
    • 9. Oktober 2005 um 08:48
    Selbstbau
    link
    http://wanderkolonie.org/servo2.htm
    http://www.soundimage.dk/Different-col/LinearMotor.htm
