  2. davy gabriels
Beiträge von davy gabriels
  • Sirus Digitalendstufen
    • davy gabriels
    • 6. Oktober 2006 um 20:09
    Hi, I also have a sirus SXA800 amplifier, but the problem I see is that it had a very strong 50hz rumble, has anyone also noticed this on the SXA range amplifiers? otherwise I will also order the SXA1000, because they give plenty of power.
  • leistungsstarkes top - peeckersound
    • davy gabriels
    • 25. Februar 2005 um 19:37
    Wenn es Ihnen interessieren kann... ich verkaufe 2x Peeckersound Xtreme top, siet wie neu aus.
  • Submeeting in the Netherlands
    • davy gabriels
    • 25. November 2004 um 22:06
    Die Messungen haben allesamt KEINE Aussagekraft. Lediglich eine TENDENZ lässt sich erkennen, nämlich dass die (vor Ort befindlichen!) BR echten Tiefbass können und die (vor Ort befindlichen!) Hörner nicht.
    First at all, we had not the intention to measure at all. It was the first time we came together to listen to different types of bass (we saw that german people did it a lot to get together and was always very interesting :D ).
    So someone had taken a measurement system, mostly to make comparison between basreflex and horn enclosures. Purpose was not to make exact max SPL measurements etc... ok?
    We are already planning a new meeting (when it's a little bit warmer brrrrrr) and then do thing in a more structured way.
    • davy gabriels
    • 23. November 2004 um 15:34
    http://www.lucas-nicolas.easynet.be/submeeting/2Punisher.JPG
    das ist der Plot von 2x punisher pro Seite.(kannst du auch sehen in der Link: ....2Punisher.JPG)
    • davy gabriels
    • 23. November 2004 um 11:32
    Ich denke (bin nicht ganz sicher) das ist 1 Punisher. Also nicht viel druck unter 60Hz.
    • davy gabriels
    • 23. November 2004 um 07:51
    Last weekend we had a submeeting in the netherlands
    Pics:
    http://www.ovmsales.nl/imagine/forumtroep/sub/submeeting.htm
    http://www.vitality-show.nl/fotoboek/album31
    http://fossalta.xs4all.nl/powerbass/img/New-line/Submeeting/
    http://fossalta.xs4all.nl/powerbass/Submeeting.wmv
    Used:
    8* 18S BR118 LW1300
    4* 18S BR118 LW1400
    4* BR18 B&C 18 PZB 46
    2* DIY 2* 15" Beyma SM115
    5* Punisher Horn (Ciare 12.00)
    2* LabHorn
    1* M-Horn (empty)
    1* Meyer 700HP
    3* Meyer USW
    2* Meyer UPA
    Plots:
    http://www.lucas-nicolas.easynet.be/submeeting/TL.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/USW.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/700HP.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/Lab.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/18LW1400.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/B&CPZB46.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/18LW1300.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/Punisher.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/1vs2Punisher.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/1vs4Punisher.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/2x18LW1300.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/2x18LW1400.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/2xB&CPZB46.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/2x18LW1400BUX.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/2x18LW1400PL4.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/PL4vsBUX1400.JPG
    If you speak a little bit dutch you can follow on the forum:
    http://forum.licht-geluid.nl/forum/topic.asp?TOPIC_ID=12365&whichpage=1
    greetings from belgium
    PS: if you see T-amps on the pics, they are mine :D (together with the 8x 18s BR118 18W1300)
    PS: you can answer me in german, I understand fully only the writing of german is a little bit difficult but I can try!
  • AG-Audio HCA 3.0 - einfach nur noch ein china amp ?
    • davy gabriels
    • 18. Oktober 2004 um 20:25
    here you can find a test report:
    http://agaudiopro.com/support/pdf/AG…_2004-09-24.pdf
    here you can find pictures of prototypes of their sound system (sorry is a dutch forum)
    http://forum.licht-geluid.nl/forum/topic.asp?TOPIC_ID=11866&whichpage=3
    Top= 15/10/1" horn loaded
    Sub= 1x18" à la WSX
  • HD15, doppelt
    • davy gabriels
    • 17. Oktober 2004 um 21:06
    kaoz: welche 15" Speaker wird gebraucht?
  • HD15, doppelt
    • davy gabriels
  • KMT HT12, HB18, Infra
    • davy gabriels
    • 26. Mai 2004 um 18:09
    Heute auf das Internet gefunden:
    http://s34171674.shoplite.de/sess/utn;jsess…view.shopscript
    Was denken Sie von diesen D&B Klonen?
  • ULTRA-DRIVE PRO DCX2496
    • davy gabriels
    • 4. April 2004 um 14:33
    Problem: ins Verleih hat jemand meine ultradrive gelockt, und naturlich weiss ich nicht das Passwort...
    Gibts irgendwo ein Trick om den Passwort raus zu holen?
    • davy gabriels
    • 8. Dezember 2003 um 10:23
    Jens: habe schon probiert mit langere Release Zeit,aber dann habe ich auch das "klicken". Hast du mal der Dynamic EQ benutzt?
    Denke mal das Gerät nach Thomann zurückschicken...
    • davy gabriels
    • 7. Dezember 2003 um 14:52
    Und hast du auch die Limiters oder Compressors getestet?
    • davy gabriels
    • 5. Dezember 2003 um 16:46
    Habe folgendes Problem: wenn der Limiter aktiv ist, höre ich ein "Klik" in das signal.Wenn der limter ausgeschaltet ist, ist der Ton gut und sauber. Kann dass irgendwo an eine falsche Einstellung liegen?
    Oder wäre es besser der "Dynamic EQ" (compressor) zu gebrauchen?
    Wenn ich der RS232 stecker gebrauche, wie is die belegung von der Kabel von DB9-stecker an der PC nach DB9 an das Gerät? Finde ich nicht in die Gebrauchsanleitung.
    Danke
  • Forumstag bei AD Systems
    • davy gabriels
    • 20. September 2003 um 18:37
    Ich sehe auf die Bilder auch ein Rack mit RAM DQL amps stehen.Haben die es gut gemacht?
  • 2x 2kW @ 2Ohm STABIL!!
    • davy gabriels
    • 15. August 2003 um 14:08
    RAMaudio BUX3.4 oder DQL5.5 / 7.0
  • Die ultimative Basswaffe heisst Föön E920HL !!!!!!!!!!!!!!
    • davy gabriels
    • 24. Juli 2003 um 23:26
    Wie sieht es aus mit das forum treffen in Solingen?
  • Sirus / King stage
    • davy gabriels
    • 24. Juli 2003 um 14:54
    Die Subwoofer sehen aus wie 2 hd15 zusammengestzt oder nicht? http://www.dj-versand.com/shop/shop.html…_king_stage.htm
    • davy gabriels
    • 22. Juli 2003 um 23:54
    Ich auch!Habe diesen katalog heute bekommen,und die Preise sind netto verkaufspreise...also werde ich noch Rabat dazu bekommen,also noch billiger!
    • davy gabriels
    • 22. Juli 2003 um 23:33
    Hat schon jemand Erfahrung mit die Kisten von Sirus(oder King Stage):
    Sie sind nicht teuer:
    PS-1276:hornloaded 12/2" für 1099€
    PS-1802:2x18" für 1125€
