  4. Andere Gewerke (nicht PA)
  5. Strom
Powerlock--VDE
  • tonmann21
  • 1. August 2005 um 20:24
  • tonmann21
    Hallo!
    wer kan mir sagen ob Oowerlock eine VDE-Zulassung hat und wo finde ich diese?
    danke schon mal
    Imma mit der Ruhe--
    Work!Don´t play...
  • Apostoli
    • 1. August 2005 um 22:09
    laut Strom-Stoss Katalog sind die dinger VDE geprüft.
    POWERLOCK-Einzelader-Steckverbinder, LITTON VEAM, IP67, 400A,
    farblich und mechanisch codiert, einfache Schraubmontage, VDE-geprüft
    max. Leitungsdurchmesser: 120qmm
    im Datenblat finde ich folgende angaben...
    Technical notes : CABLE SECTION: POWERLOCK400A: 120mm² screw
    MAX CURRENT: POWERLOCK400A: 400 A. @ < 70° C
    MAX EARTH VOLTAGE: 2Kv AC - 3Kv DC
    MIN FLASHOVER: 9.5Kv AC/DC (peak)
    OPERATING TEMPERATURE: -30° +125° C
    INSULATING RESISTANCE: > 50 MOhm @ 500 VDC
    INPUT PROTECTION: up to IP6 (correct coupling)
    EL. ANTISHOCK PROTECTION: IP2X
    FLAME RESISTANCE: FLAME RETARDANT
    POWER CONNECTOR:
    400 A. - N
    400 A. - N
    Regulations : HEAT/FLAME RESISTANCE: EN60309-I/BS550.7.5.4
    MECHANICAL STRENGTH: EN60309-I/BS550.7.5.4
    The Powerlock Power Distribution Cabinet has been designed and tested to conform to the requirements for
    CE marking by implementing the requirements of the Low Voltage Directive (LVD) 73/23/EEC which is
    implemented as the Electrical Equipment (Safety) Regulations 1994.
    It complies with the following specifications:
    BS EN 60439-1:1999, BS EN 60439-5:1996 and IEC 60529:1992
    The cabinet is fitted with either 1 or 2 NRG sequential units rated at 400A or 600A. These units allow safe
    connection in the correct sequence of Powerlock connectors (Ground, Neutral, Phase 1, Phase 2, Phase 3).
    The unit incorporates a key lockable switch which can be connected to auxiliary safety circuits. Once locked, it
    prevents unmating of the system by unauthorized personnel.
    The cabinet is fitted with external access and blanking panels which are designed to aid in the routing of cables
    both into and out of of the cabinet. An information plate is fitted onto the side of the cabinet incorporating data
    for traceability. The cabinet door incorporates 2 door locks (triangular key type) for security. When latched, the
    cabinet has an IP34D environmental rating. For additional security, a padlock can also be fitted. Fixing plates
    are provided to enable the unit to be be securely fixed during installation, prior to electrical operation.
    The cabinet is fitted with generic safety signs. These signs give warning of the potential electrical hazard,
    together with mandatory signs regarding cabinet security and isolation. All signs supplied conform to the
    current requirements of the Health and Safety (Safety Signs and Signals) Regulations.
    links:
    http://www.ittcannon.com/media/pdf/cata…ckDataSheet.pdf
    http://www.ittcannon.com/media/pdf/cata…lockCabinet.pdf
    http://www.ittcannon.com/media/pdf/cata…netAssembly.pdf
    http://www.ittcannon.com/media/pdf/cata…ion%20Guide.pdf
    http://www.ittcannon.com/media/pdf/cata…ideTestData.pdf
  5. Suche Lichteffekt
    19. September 2026 um 10:13
    dxnny074
    18. September 2026 um 15:16
