Martin MAC 500
  • partytech-MR
  • 22. Oktober 2005 um 21:04
  • partytech-MR
    Hallo Leute,
    wolte fragen worin besteht der wesentliche unterschied des MAC 500 und des MAC 500E? Was hat das E zu bedeuten?
    MFG Michi
  • Crossfader
    • 22. Oktober 2005 um 21:13
    E steht für elektrisch ;)
    Da hats dann Schrittmotoren drin, in denen ohne "E" hockt ein kleiner Chinese und kurbelt....
    Ok Spass bei Seite
    Electrical(MAC 500)
    The luminaire shall operate on 50 Hz supplies at 200, 230, and 245 volts; and on 60 Hz supplies at 208 and 227 volts, +/- five percent. It shall be fitted with a 3 meter (9.8 ft.) length of three conductor 1.5 sq. mm (16 AWG) electrical cable for connection to AC power. The luminaire shall be electrically grounded. The luminaire shall conform with CE safety standards EN 60598-1 and EN 60598-2-17, and with CE electromagnetic compatibility standards EN 50 081-1 and EN 50 082-1. Units intended for use in North America shall be cETL certified for compliance with CSA standard C22.2 No. 166, and ETL certified for compliance with ANSI/UL standard 1573.
    Electrical(MAC 500 E)
    The luminaire shall operate on 50 Hz and 60 Hz supplies at 100, 110, 120, 200, 210, 220, 230, and 240 volts; +/- five percent. It shall be fitted with a 3 meter (9.8 ft.) length of three conductor 1.5 sq. mm (16 AWG) electrical cable for connection to AC power. The luminaire shall be electrically grounded. The luminaire shall, without operator intervention, reduce lamp power 40 percent within ten seconds of being set to blackout condition. Lamp power shall be restored to full without visible delay upon opening of the dimmer. The luminaire shall conform with CE standards EN 60598-1 and EN 60598-2-17 for safety, and with CE standards EN 50 081-1 and EN 50 082-1 for electromagnetic compatibility.
    Environmental
    The luminaire shall be located in a dry area in which the ambient temperature does not exceed 40° C (104° F). Where installed outdoors, the luminaire shall be supplied with a custom protective housing with an IP rating of 44.
    Physical(MAC 500)
    Size (head at tilt limit): 356 x 481 x 673 mm (14.0 x 18.9 x 26.5 in). Weight : 32.8 kg (72.2 lbs)
    Physical(MAC 500 E)
    Size (head at tilt limit): 356 x 481 x 673 mm (14.0 x 18.9 x 26.5 in). Weight: 26.1kg (57.4 lbs)
  • partytech-MR
    • 23. Oktober 2005 um 01:51
    sind die beiden MAC´s von den Funktionen gleich oder ist da einer oder besser. Kann man bei dem MAC 500 PAN TILT genauso Fein einstellen wie beim 500E (läst er sich genauso Fein Steuern), was für Nachteile haben beide??
    MFG Michi
  • DSLmedia
    • 23. Oktober 2005 um 07:34
    MFG Michi
    die Funktionen sind gleich, Vorteil beim E ist das er deutlich (8kg) leichter is. Steht aber auch alles in dem von Crossfader zitierten Abschnitt aus dem Manual
  • jamhot
    • 17. November 2005 um 14:21
    Hallo Michi,
    der 500 E hat ein elektronischen Ballast, wogegen der "normale" nur einen magnetischen Ballast hat. Ich habe die beiden nicht miteinander verglichen, aber bei TV Produktionen kann es von Vorteil sein, die E-Version zu haben. Beim 500 E wird außerdem die Lampenleistung reduziert, wenn der Shutter geschlossen ist.
    Bei anderen Lampen, die es als E- und M-Version gibt, bin ich der Meinung, bei der E-Version mehr Output zu haben.
    Die Gewichtsersparnis ist ein toller Effekt, der auch nicht zu vernachlässigen ist. Allerdings sind Geräte mit elektronischem Ballast meines Wissens nach auch meistens teurer als die gleichen mit magnetischem.
    Uli Weiss
    grandMA lernen
