: What is the preference here for the different types of subs????? Or is this more determined by the type of venue and style of music?????
Hi
There are differences between horns and direct radiators which are not often discussed but profoundly effect the
results. Some semi random thoughts.
Horns are much easier to make "wrong" or mis use and the result is normally a non flat frequency response.
Remember one has to deal with both ends of the spectrum in its design, not just the bass end and horn design has much more "art" in it and "rules of thumb" seem to govern many designs.
A non flat response means that the "peaks" in the response by definition "ring" after excitation which colors the sound.
A vented box is simple, just look up the driver spec.'s and use one of many vented box design programs and
viola, one has a design.
Horns have many more considerations past mating the right driver, frequency range and throat
area, how big does it have to be, how to fold it up and so on.
Horns, particularly bass horns are relatively low in distortion however, what ever distortion the driver produces is added to the air-nonlinearity's contribution.
In probably the majority of bass horns the driver distortion is perhaps 10X - 100X greater than the distortion caused by the horn itself and as a result of distortion and non flat response most bass horns are poor in sonic accuracy.
Also, like so many things about bass horns, much of what is done is a result of folk lore, for example it is insane to put a short Xmax driver (like the old JBL K series) in a low frequency horn as it runs out of excursion at a tiny power level and then is grossly distorted yet countless W bins were made with them because "it is the right driver".
There is nothing fundamentally wrong with horns however and one must think in terms of acoustic size and wave
theory to see all horns do a similar thing.
Direct radiators on the other hand generally spend there lives having much more excursion and while manufacturers do not boast about it, one gets a great deal of "free sound" with direct radiators.
The "free sound" is produced at 2,3,4,5,6,7,etc times the input frequency and while it is not part of the original program material it is an every day phenomena.
Outside of a segment of pro audio, this "Free Sound" (AKA harmonic distortion) is actually considered undesirable as it is not part of the signal but there is no denying that the sound changes the sound produced.
Subjectively, judging subwoofers with say a kick drum, one finds the woofer with the greatest amount of "Free Sound" usually also has the "best" sounding attack (as the higher frequencies give an edge to the sound) where a low distortion woofer only produced the signal it was driven with.
In the role of a music reproducer though, a crossover normally routes the upper frequencies of the kick to the upper speakers. Low distortion woofers NEED a more powerful midbass section to "fill in" the hole in the spectrum that taking the distortion away left.
For a distorted woofer, more of those upper frequencies are produced by the driver and so sounds more "complete" when the sub is auditioned alone but usually worse when the real upper signals are added back in as the distortion competes with them.
I know many don't believe there is much distortion in woofers, they have the luxury of never having measured them.
If there is any doubt, I would urge you to take such measurements, you will see why mfr.'s don't provide this information.
Inverse square law.
Everyone knows that sound pressure from a point source falls off at -6 dB per doubling of distance.
While easy to picture, the first real life example of this so far as horns VS direct radiators really took me back.
We had just introduced the Servodrive TPL-1 at the New York AES convention and Tom Furlong (our salesman at
the time) had arranged with Ken Deloria. to loan Phill Lesch 4 boxes to play through.
The Dead were playing at Madison SQ Garden so when they called and said we should come "hear" the bass system
we jumped into a cab and went that evening.
Phil's normal bass rig (the low bass part) was 4 Meyer 650's and Ken and I went out on stage to "hear" what he was talking about.
At a distance of 10-12 feet or more, the horns were louder and lower no doubt but closer than that and the direct radiators were louder.. I will never forget the feeling of being on stage while they were playing, the whole place was moving up and down as result of the crowd, a weird feeling
Also I will never forget seeing Ken's Sound level meter rapidly climb until he had it right against the grill of the Meyer box and how much slower it climbed as he approached the mouth of the horns.
While the horns produced more acoustic power (evidenced by the higher SPL everywhere past 12 feet), the horn is
both much larger in area (lower acoustic power per area) and the actual origin is located at the small end of the horn.
When people are "up close" the direct radiator can be subjectively more powerful while at the same time the horn system (other than up close) can produce a higher SPL in the room reflecting its greater acoustic power.
One has to ask where do i need the SPL?
Acoustic phase
A direct radiator cannot reproduce the input wave shape (if not a sine wave).
On would think that might be important (being able to reproduce the input signal as closely as possible) but the physics
prevent it with a direct radiator. Instead, the direct radiator has an acoustic phase which is about-90 degrees midband
meaning that the output at any frequency is delayed about 1/4 wavelength (not discussing the ends of the band where more phase changes take place)
Since this delay is a different amount of "time" for each frequency, this reassembles the input waveshape into something which has no resemblance to the original signal.
On can argue that as evidenced by the popularity of direct radiators for bass that the ear must be pretty forgiving about screwing up the waveshape and pretty much makes the concept of hearing "absolute phase" a moot point.
On the other hand everywhere else in the signal chain such butchering of the signal would not be considered
acceptable. Other than in a "perfect world" music system, there are times when reproducing the exact signal, no more, no less is desirable in fact active sound cancellation depends on producing the exact inverse wave shape of the problem source.
Horns can have a big advantage here, a proper horn has "flat" response, it is flat because the acoustic radiation resistance dominates the system (between the upper and lower cutoffs).
In this range, it is possible for the horn to have an acoustic phase which is around Zero degrees.
A flat amplitude response AND Zero degree acoustic phase are the two conditions which have to exist to allow reproduction of the input wave shape.
This property can also exist in a Electrostatic speaker fwiw.
Regardless of what one is used to hearing, a horn "can be" a much more accurate reproducer of the input signal than a direct radiator.
I suspect when the LAB horn is in use many will agree.
Just as there are people with different sensitivity's to colors, textures and so on, personally I believe there are some
people who are more sensitive to phase errors, more sensitive to distortion and then there are those who are less.
Also, there is a matter of what we are used to.
I guess for me the "perfect" reproducer has no distortion, no power compression or other dynamic non linearity, no
phase/time errors, has ruler flat response from DC to Ch-5 (Ok I'll accept subsonic to ultrasonic bandwidth) and frequency independent directivity.
Now how to make one?
Cheers,
Tom Danley
