  5. Licht
coemar farbwechsel outdoorscheinwerfer
  • Sven M
  • 3. Juni 2002 um 21:05
  • Sven M
    Hallo, brauche dringend von großen Coemar outdoorscheinwerfern (weiß den namen leider nicht) ne anleitung..wo kann man überhaupt infos über coemar produkte bekommen?
    _________________
    Immer im grünen Bereich...
    <font size=-1>[ Diese Nachricht wurde geändert von: BigSound am 2002-06-03 21:16 ]</font>
  • Michael
    • 5. Juni 2002 um 02:00
    zB.
    http://www.coemar.com/dbcoemar/home.nsf/index?OpenForm
    > 9820 - Panorama Cyc Power
    Technical Characteristics
    Utilising Coemar's patented Twin Lamp Technology (TLT) it dramatically increases the luminous output whilst minimising the power consumption. The ability to use either 1000 hours lamps or even long life 3000 hours lamps for architectural installations make it the perfect choice for building illumination and large scale indoor or exterior projects where a wide even coverage of illumination is required, with the added ability of infinite colour change. Manufactured in aluminium and stainless steel sheet. Weather protection, high resistance matt black polyester paint.
    lamp 2 x Philips 575 MSD - code 105215
    lamp life 3000 hours
    lamp 2 x Philips 575 MSR/2 - code 105245/2
    lamp life 1000 hours
    base GX9,5
    optics TLT dual lamp system
    beam dispersion device variable size rectangular beam
    4 interchangeable diffusion filters
    dimmer mechanical electronically controlled
    colours CMY colour mixing system
    ventilation forced convection ventilation
    signal control DMX 512
    on/off of the two lamps independent and controllable via DMX
    display reverse reading display
    protection rating IP 44
    weight 47,5 Kg./103 Lbs.
    Download more technical documents >>>
    << Go to Coemar U.S.A. >>
    oder
    http://www.tracoman.com/site_folder/tracohome.html
    Solltest Du über einen Kauf nachdenken, bedenke das Studio Due City Color in D wohl im Architekturlicht (mobilem) führend sein dürfte. Zumietung also viel leichter.
  • Sven M
    • 5. Juni 2002 um 07:14
    jo. danke. muss sie nur auf nem kofferjob nutzen..
  7. Suche Lichteffekt
