Ist es möglich bei dem oben genannten Pult die DMX Kanäle zu patchen bzw. den Fadern DMX Kanäle von 1-512 zuzuweisen oder sind die Kanäle fix von 1-24 verteilt?
Jannik
Jannik
Kurzer Blick in die Anleitung ... Antwort JA
To program the DMX Output Patch
1 Select “Output Patch” from Super User.
Note: If the DMX card is not fitted the option is
not available.
Press Memory Program button to select this
option; the display shows “Out 001 ch 01"
This means that DMX output channel 001 is
being driven by desk channel 1.
2 To select the desk channel which drives the
DMX output channel, press the channel Flash
button for the appropriate channel. For
example, pressing channel 9 Flash button
sets “Out 001 ch 09". This means DMX output
channel 001 is driven by desk channel 9.
Pressing the Memory + / - buttons will cycle
through the DMX channels 001 to 512. Each
of these outputs can be patched to any desk
channel by simply pressing the appropriate
Channel Flash button.
Whenever a change is made to the output patch
the DMX outputs are re-routed instantaneously.
3 To turn a DMX channel off:
press the Channel Flash button again. For
example , pressing Channel 9 Flash button
again sets “ Out 001 ch —” . This means that
DMX output channel 001 is now turned off
permanently.
4 When the Patch is complete Press the
memory Program button to return to the
“Output Patch” option in Super User.
