....wir müssen unseren berufsstand ja nicht von innen heraus schlechtreden
Wenn es tatsächlich Laurel ist, wundere ich mich, dass unter uns "Ohrgeschulten" nicht mehr den Stanley erkannt haben ...
"Es ist ganz klar Laurel. Mir unverständlich, dass jemand Yanny hören kann."
man kann die anstiegszeit der LED meter leider nicht in allen digitalkonsolen einstellen.
und es gibt meist auch keine dokumentation darüber, welche anstiegszeiten für die anzeigen verwendet werden.
Es sollte so sein:
Version 987 no longer supports Waves running internally on the console.
We strongly advise Waves users to read the MultiRack for DiGiCo SD Consoles user guide.pdf explaining the requirements to use Waves MultiRack on an external PC and ensuring that all of the necessary equipment and licences are in place to do this before upgrading their console software.
Please visit http://www.waves.com/downloads/digico for more information
New Features (Further details are available later in this document)
Added support for SD Console Control of External Waves MultiRack.
Support for L’Acoustics L-ISA. Additional buttons have been added to the External control panel to facilitate this.
A "Generic OSC" control panel has been added to each channel. This data can be automated on a per snapshot/cue basis.
Additional recall scopes and recall safes have been added for input channel external controls.
Support for DMI Mic card.
A new Snapshot Groups panel has been added to the Snapshots panel. It allows management of which snapshots are in which groups without the need for the group members to be consecutive or for groups to separated by ungrouped snapshots.
Snapshot Recall Scope and Auto-Update Scope can now be copied from another snapshot, using a new button at the bottom right of the respective scope panels.
An Outputs AFL only option has been added to non-broadcast versions and restricts the Solo PFL/AFL choice to input channels only, all outputs being fixed on AFL.
SD12 now has Free and Protected fader touch options.
A new panning option has been added to the Options>Surface menu allowing a different panning response. Type I is current SD and Type II is the new variant.
In Audio IO, all drop down menus have been made larger.
A new Macro, "load session file" has been added.
Fixes from V929
If snapshot changed a De-Esser to a Multiband Compressor, the top X-over frequency was copied to lower X-over freq.
Master fader assignment was not being brought back after save and load in Broadcast.
The Audio master setting could be switched off on Session load
On SD12, having a GEQ assigned to faders could cause an Access violation when another surface control was activated.
Changes to the Hard Mute state while the surface was offline were being ignored on engine synchronization.
On SD12, after restructuring to 96K, a D2 rack would only show the first 3 socket groups.
On SD9,11 and 12, sessions with more than 2 LCR busses would not load.
On SD7, macro triggers for GPI 17-32 were firing macros with triggers of GPI 1-16.
Including a Control Group as part of a macro fader start group could cause an Access Violation.
On SD12, on screen meters were occasionally freezing momentarily.
MADI Console connections reported as ERR when DMI MADI was used as the connection.
On SD7, switching video sources with snapshots did not always recall the correct source.
On SD10, Swapping faders in the centre bank could cause faders to become ganged.
On SD12, new Engine Host code prevents possibility of intermittent clicking on headphone and some Matrix outputs.
On SD12, Audio Mastership now prevented from intermittently switching incorrectly on session load.
___________________________
Also für die die es interessiert, die PA über die wir hier sprechen ist ein dB Technologies dva K5 und ks20 bässe. Und diese Modelle haben einmal einen integrierten Limiter und eine Mute protect Funktion die die speaker irgendwann mal erstmal lahm legt. Und das sind 2016/17 und nicht 1970
leider ist es unvorhersehbar wann sich diese harte schutzfuktion aktiviert. Deshalb lieber immer die Clip led in Sicht haben.. sicher ist sicher
OK 2018 ist es ganz simpel so, das die Controllerschaltungen immer besser geworden sind, die Antriebe thermisch höher belastbar und nahezu unbegrenzt Verstärkerleistung zur Verfügung steht, allerdings gibt es weiter zwei herbe Grenzen:
1. Der tatsächliche Wirkungsgrad der Antriebe und der Boxen ist nicht besonders viel besser geworden und
2. Im unteren bis mittleren Preissegment existieren immer noch ganz erstaunliche "Schutzeinrichtungen" gegen abuse, die im oberen Preissegment offensichtlich so nicht nötig sind.
Bedeutet für Dein System und Deine Anwendungen, dass Du, wie 'thieloliver' schon sagte, das vor allem passend dimensionieren mußt. Wieviel Schnitze hängst Du denn da so für welche Fläche, wieviel Publikum und welches Genre?
Eine vernünftige Limiterschaltung und Kühlung langt schon. Ampabschaltung wegen Übersteuerung ist so 1980er...
(scnr ?)
Sehe ich auch so.
40 Jahre Lautsprecher kaputt machen sind bei mir sehr überschaubar, meine Lernkurve war extrem steil und beruht genau genommen auf vier Ereignissen ohne je bei Tausenden von Veranstaltungen andere Erlebnisse gehabt zu haben:
1. Ende der 70er habe ich verschiedene RCF Treiber und den legendären Vitavox S3 damit kaputt gemacht, dass ich ein Weilchen brauchte, um zu verstehen, dass die physikalisch wünschenswerte Trennfrequenz zum Mittelhochtontreiber auch für eine aktive 18 dB Butterworth Weiche nicht zwingend was mit dem zu tun hat, was die Treiber wirklich ab können. Folge -> Amplitudentod.
2. Sinus ist echter Stress für einen Lautsprecher
Eine nicht clipende BGW750C bescherte bei 60Hz Sinus innerhalb weniger Sekunden einem damaligen Modell des EV15L in einem korrekt bemessenen Thiele-Small Gehäuse den Hitzetod.
Danach waren die PAs groß und schwer, großzügig dimensioniert, hatten in den Weichen vernünftig eingestellte Limiter und ich hatte nie Streß. Während dieser Zeit versuchten Leute kompaktere, leichtere Anlagen zu bauen und hatten viel Streß mit kaputten Lautsprechern, weil fehlender Wirkungsgrad nicht beliebig durch Ampleistung zu ersetzen war ... ![]()
3. Dann schafften Meyer und danach auch d&b ihre Systeme so zu kontrollieren, dass sie in der akuten Anwendung von Pultbedienern einfach nicht mehr kaputt zu kriegen waren. Es gab zwar wieder für die Locations zu kleine Anlagen, die sich dann nicht gut anhörten aber sie gingen auf den Gigs nicht mehr kaputt. Man kaufte oder bestellte zum Job solches Holz und dachte einfach nicht mehr darüber nach.
4. Sehr viel später irgendwann nach der Jahrtausendwende habe ich noch ein einziges Mal Lautsprecher kaputt gemacht:
Für einen Gig hatte ein ExDJGeneralverleihbudenjungbeschaller ein mir bis dato unbekanntes Produkt Namens Sparc am Start. Nachdem ich so ein bisschen herumgesoundcheckelt hatte, war mir klar, dass dieses Beschallgerät während meines Jobs irgendwann seine Hochtöner verlieren würde und die Kunst darin bestand, diesen Zeitpunkt möglichst weit nach hinten zu verlegen. Tatsächlich war es mir dann vergönnt, diesen Zeitpunkt relativ präzise an's Ende meines Gigs zu terminieren. Das tat mir dann eigentlich nicht wirklich leid.
Das war's. Mehr habe ich nicht kaputt gemacht und zwar ganz ohne präzise Überwachung des Verhältnisses zwischen Pultmaster-Out und Beschallcontroller-In ...![]()
Ja, so ist das eben und wenn man einem anderen Forum und deren Nutzer dort glauben mag, dann ist das Stand der Technik und sowieso mehr als cool.
Du mußt dort nicht sein. Du bist auch hier unter den Kabel- und Faderbenutzern ein geschätzter Nutzer. ![]()
Sagen wir's mal so:
Es ist einfacher geworden, es gab früher keine fertigen Algorithmen, die ein integriertes, gleichzeitiges, vernetztes Verstellen von vielen Parametern erlaubten und man hätte viel mehr mehr messen müssen, was echte Pioniere wie Bob auch gemacht haben.
... und das hat nicht mit simplen Zonen in einem Array zu tun, ob das jetzt prinzipiell funktioniert oder nicht.
Es gab auch früher schon keine "simplen Zonen", es ist schon lange klar, dass man zum Umsetzen bestimmter Sachen die Antriebe des Arrays einzeln ansteuern können muß und d&b war schon immer etwas später dran als beispielsweise Meyer beim Umsetzen neuer, höher integrierter Lösungen ... ![]()
Möchtest Du über den Betrieb des Martin MLA mini im Capitol detailierter berichten?
Ich hole das mal hier her ... schön, dass 12 Jahre, nachdem die LA- Versteher mit mir über das Verbrechen an der reinen Lehre herumzackelten, das Denken in Zonen eines Arrays normal zu werden scheint... ![]()
Schön wäre es, wenn sich hier weitere Beispiele dafür finden würden, wie heute praktisch damit umgegangen wird.
was habt ihr denn gegen die jahrhunderthalle?
ich finde die eigentlich eher gutmütig. gerade, wenn man bestuhlt in die ränge spielt. verwechselt ihr das vielleicht mit der festhalle?
Jup, ich gestehe ... Ich hab's verwechselt ...![]()
Zu viele DON'Ts:
Nicht in die Jahrhunderthalle ...
Nicht für 149,- € ...
Nicht zu nah an die Bühne, wenn bestuhlt ...
ZitatRB-Connect for Apple iOS €129.00 – €149.00 plus 19% Tax, plus Shipping
naja ... da bin ich eigentlich ganz zufrieden, wenn von drei der Si Peng Dinger einer Ausschuß ist ... zumal der Preis der Chinaböller gerade noch mal auf 25,99 € gefallen ist.
IDN:
jetzt war ich auch mal wieder auf nem livekonzert, bei dem ich selbst nicht am pult stand.
und was ich gar nicht verstanden habe: warum muss man bei einer weltbekannten Funkband, die schon seit vielen jahrzehnten tolle musik macht, das drumset (insbesondere die bassdrum!) lauter mischen als den gesang?
Ich ahne, wo Du warst. Nach zu vielen entäuschenden Erlebnissen in diesem Etablissement, vor Allem Funk und Soul, wenn sich die Haustechnik daran versucht hat, geh' ich da nicht mehr hin, auch oder gerade wenn echte Lieblinge dort spielen. So schwer 's mir fällt, werde ich mir auch Jeff Beck dort schenken müssen ... obwohl ... der leistet sich ja hoffentlich auch nen guten Mann ... ![]()
Und wenn wir gerade schon dabei sind ... für das von Dir gehörte Genre gibt's in unsrer Region jetzt ja noch einen weiteren unglaublichen Experten ... TOP Nachspielbandleader und Seniornachwuchsmischer ...![]()
Ich habe mir auch direkt einen Adapter bestellt. Hat immerhin zweimal funktioniert. Danach leider nicht mehr. Da ist mein Oldschool-WLAN doch zuverlässiger, leider. Die Idee eines Kabels verfolge ich aber weiter, danke!
Hast Du genau dieses 'SI PENG' Ding bestellt?
Die zwei der drei die bei mir funktioniert haben, tun das jetzt eigentlich reproduzierbar und zuverlässig.
... werden auch die Yamaha umsteiger endlich zufriedengestellt...
das war beim M7 auch kein feature, welches es von Anfang an gab. Hier war die Idee, für den Monitorbetrieb die Matrix-Busse einfach wie 8 weitere send busse nutzen zu können. Diese Notwendigkeit ergab sich sowohl aus der starren Busstruktur der Yamahas als auch daraus, dass für manche Aufgaben die 16 auxe schlicht zu wenig waren. Das ist natürlich für die A&H Pulte nicht nötig, da man die Architektur selbst bestimmen kann und die Anzahl der auxe, die man dadurch festlegen kann, ausreichend hoch ist.
... es wird die möglichkeit geschaffen, Inputs direkt auf Matrix zu senden. diese möglichkeit hab ich zwar noch nie benötigt, aber immerhin ist es dann ohne umweg über AUX machbar und wird damit den leuten zu gute kommen, die dieses feature gewöhnt sind...
hier kann statt einem zusätzlichen Satz Bus Encoder in den Eingangskanälen auch einfach eine tie line gemeint sein. Diese Option, Mischmodule mit einander zu verknüpfen, wird von manchen Zeitgenossen ja als "unübersichtlich" empfunden, hat mir bei den DiGiCos aber schon mehrfach den Arsch gerettet. ![]()
Du bist eben ein Held ... ![]()
I go with niggles ... buch' Dir jemand dazu, der das wirklich drauf hat ... ist so ne Art Lebensversicherung.
Leider muss ich die Euphorie etwas ausbremsen:
Der SI PENG Adapter für das ipad hat das chinesenübliche Qualitätskontrollenproblem, d.h. der Qualitätskontrolleur ist der Anwender.
Nachdem der erste Adapter mit dem ios11 ipad so prima funktioniert hat, war ich mutig und hab' noch ein zweites Teil gekauft. Gleicher Hersteller, gleicher Vertriebsweg, gleiche Verpackung, gleiche Chargennummer, äußerlich gleiches Teil spielt definitiv nicht mit ipad air, wohl aber mit meinem iphone 6 ????
Dann mutig noch ein drittes Teil, gleiche Chargennummer u.s.w. bestellt ... das spielt jetzt reproduzierbar mit den ipad airs wieder einwandfrei. ![]()
