  2. joefi
Beiträge von joefi
    • joefi
    • 3. Dezember 2025 um 08:44
    Frage an die Spezialisten: sind Szenen und shows kompatibel zwischen QU6 und SQ6?
    • joefi
    • 27. November 2025 um 13:08
    Firmware 3.1 ist online
    • joefi
    • 8. September 2025 um 11:32
    Hi habs mit deepl komplett übersetzt, ist sogar brauchbar, also kein Kauderwelsch erkennbar ...,
    noch dazu wesentlich kleiner, nur 5MB
    • joefi
    • 8. September 2025 um 11:20
    Hi, ich hatte vor das Manual in Deutsch rein zustellen, habs aber wieder zurück genommen,
    da ich mir nicht sicher bin ob es da Ärger geben könnte ...
    • joefi
    • 8. September 2025 um 07:26
    • joefi
    • 6. November 2017 um 12:56
    Hi zusammen,
    Das Webinar ist online
    Externer Inhalt youtu.be
    • joefi
    • 3. November 2017 um 13:40
    Integriertes Alc Metering ...;)
    • joefi
    • 3. November 2017 um 11:48
    Hi zusammen,
    da hier etwas Aufregung bezüglich des 2 LED Metering besteht, hab ich grade folgendes gefunden:
    Hi Guys
    I normally try to keep quiet around here, but since the issue of colour blindness with the chromatic metering has come up, and with there being little SQ documentation available so far, I thought I would add some extra information. I hope that's OK.
    The channel meters on SQ have a configuration screen, where you can customise the thresholds and colours however you like. If green-yellow-orange is not effective for you, you could choose white-blue-red, green-orange, or whatever, with configurable thresholds for when the next colour comes in. The colours can be either a fixed brightness, or vary in brightness according to level. As an example, I just set a desk to use an increasing brightness of white from -30 dBu and upwards, with no colour changes at all. And yes, there is a restore to defaults button!
    The dedicated peak LED always comes on at +15 dBu.
    Regarding the per-bank peak LEDs, these are inside the bank buttons on SQ, so a bank button will turn red if a signal in that bank is peaking.
    I hope this was helpful.
    - Jeff, A&H
    Ich denke, das bringt etwas Licht ins Dunkle ...;)
  • PreSonus StudioLive RackMixer!
    • joefi
    • 27. September 2017 um 14:47
    Hi gibt's schon Preise?
  1. Soundbase vs WWB
  5. Astera AX5 akku refreshen
  6. "Nutzbass"
  10. HK Audio Polar 15
