  2. dasich
Beiträge von dasich
  • Fragen zu Meyersound MSL 3
    • dasich
    • 25. Juli 2006 um 17:02
    http://www.meyersound.com/products/legac…sl-3a/index.htm
    MSL-3A Reinforcement Loudspeaker
    70°H 60°V
    21 1/4" wide
    56 3/4" tall
    30" deep
    241 lbs (109.3 kg)
    Max SPL (Peak/Cont): 135/130
    Freq Range: 75-18 kHz
    You can download this product data sheet in Adobe Acrobat format.
    Acoustical - MSL-3A/M-3A System
    Frequency Response 1 ±4 dB from 75 Hz to 18 kHz
    Maximum SPL 2
    Continuous 130dB
    Peak 135 dB
    HF Coverage
    Horizontal 70°
    Vertical 60°
    Acoustical Crossover Frequency 800 Hz
    MSL-3A Loudspeaker
    Transducers
    Low Frequency (2) MS-12 12-inch cone drivers, 8 ohms per driver
    High Frequency MS-2001A 2-inch throat (4" diaphragm) driver, 12 ohms
    High Frequency Horn 70° modified radial
    HF DC Protection 20 µF Polypropylene capacitor
    Enclosure Vented, horn loaded, multi-ply Finnish birch
    Finish Black textured, charcoal-grey carpet (optional) or black weather protected (optional)
    Physical Dimensions 21 1/4" W x 56 3/4" H x 30" D
    Weight 241 lbs. (109.3 kg)
    Protective Grill Hex perforated metal screen, damped, charcoal-grey foam covering
    Connector EP-4 male, EP-5 male (Europe only), Pyle National (optional)
    Rigging Aircraft pan fittings, 600 lbs. safe working load each
    M-3A Control Electronics Unit
    Input Type 3 Balanced ISO-Input™, 10k ohms
    Output Type Active, push-pull, 200 ohms output impedance
    Maximum Input Level
    Balanced +23 dBu
    Unbalanced +23 dBu
    Maximum Output Level 4
    Balanced +26 dBu
    Unbalanced +20 dBu
    Hum and Noise 5 -90 dBV
    Dynamic Range 6 >110 dB
    Sense Inputs 10K ohms true differential, opto-isolated
    Electrical Crossover Frequency 800 Hz
    High Frequency Delay Type Active all-pass
    Driver Protection Circuitry
    Low Frequency RMS limiter
    High Frequency RMS limiter
    Indicators
    Sense; Hi and Lo Green/Red LEDs
    Limit; Hi, Lo and VHF Red LEDs
    Safe Green LED
    Power Green/Red LEDs
    Controls
    Front Panel Input attenuator, AC power switch
    Preset Panel Lo Cut switch, Safe switch, HF EQ Switch, VHF Var/Cal switch, VHF control
    Connectors
    Balanced Input/Output 3-pin XLR (A-3) female/male
    Sense Inputs Banana jacks
    Power 120/240V AC, 50/60 Hz (internally switchable)
    Physical Dimensions 19" W x 1 3/4" H x 7 3/4" D, Standard rack mount
    Weight 8 lbs. (3.6 kg)
  • DAS vs. DASS
    • dasich
    • 25. Juli 2006 um 15:15
    womit ich mir die Frage stelle, ob schon wieder Ferien sind :shock:
    Ich bin mir sicher, dass das wohl so sein wird.
    Zitat von "Kramusha"
    Ich bin der Meinung, DASS du ein Beispiel hinzufügensolltest.
    Ich bin auch der Meinung, dass DAS hier ein Beispiel ist. ;)
    Lg Dobse
    PS: Jeah, ich werd Deutschlehrer^^
    EDIT: Fehler ausgebessert.. Soviel zum Deutschlehrer :oops:
    :D trotz edit sind noch zwei drin....
  • MIDI-Controller für FX-Rack
    • dasich
    • 24. Juli 2006 um 20:28
    super Sache, fürs eigene Rack und da ist dann auch oft das Problem.
    Ich habe mir ein kleines FX Rack zusammen geschraubt und nehme es kaum noch mit.
    Festivals oder Abend mit 3-4 Bands, Umbauzeiten 10 - max. 15 min. komm dann mal mit eigenem FX Rack ans FOH :shock:
    Wenn nur 2 Bands spielen, vernünftig Soundcheck ist, dann gerne eigenes Rack und dann auch mit externer Bedienung
  • FOH- bzw. Stage-Bilder
    • dasich
    • 24. Juli 2006 um 18:30
    Ja das Passwort Dingsda Nervt.
    Hab ihr ein Glück, dass ich CD´s am sortieren bin. Was sich da so alles findet.
    Kein FOH aber geile, bewegliche Bühnenelemente:
    Zusammen:
    auseinander:
    • dasich
    • 23. Juli 2006 um 19:19
    Dann will ich doch auch mal.
    So muß ein richtiger Abend ablaufen:
    Ersten zwei bis drei Stücke: (ist schon was her, da war das T-Shirt noch HIP :D )
    Die Show läuft:
    Was kann man jetzt noch machen?
    :D so macht das Spass, noch Fragen?
  • Quali
    • dasich
    • 23. Juli 2006 um 14:23
    Menno :( , die 0 kann doch nur ein Admin mit dem Schloss vergeben
  • Quali
    • dasich
    • 23. Juli 2006 um 10:09
    Zitat von "Sven83"
    und ich gebe für einige dummen antworten die 5
    ich habe eine ganz normale frage gestellt, wo ich beim suchen nicht mehr weiter wußte, und dann so!
    :shock: Du kannst doch nicht nochmal die 5 vergeben.
    Schon garnicht für deinen eigenen Thread. :D
    Sorry, nein du hast keine normale Frage gestellt, sondern du hast nach Onlineshops und Herstellern gefragt.
    Für Cases z.B. habe ich dir sofort sechs Hersteller genannt.
    Lieferanten stehen hier im Thread so an die 50 und weitere geschätzte 428 in der Mitgliederliste.
    Warum du kaum Professionelle Lösungen findest, ist mir ein Rätzel.
    Zum Thema Onlineshops schau doch mal hier:Regeln also was erwartest du.
    Obwohl ich selber ja schon die 5 gegeben habe, erlaube ich mir das hier:
    wegen copy/paste-Fleißarbeiten darf ich das :D
  • Quali
    • dasich
    • 22. Juli 2006 um 18:15
    Sorry ich konnte es jetzt nicht lassen
    Hier sind jetzt nur die Homepages der ersten 3 von 183 Seiten aus der MITGLIEDERLISTE
    http://www.audio-studio-nord.de/
    http://neomy.de/
    http://www.event-forum-berlin.de/
    http://www.firstchoice-vt.de/
    http://www.sound-fashion.net/
    http://www.tourlight.de/
    http://www.cen-music.de/
    http://www.event2dance.de/
    http://comamedia.de/
    http://crystal-hannover.de/
    http://www.pa-team.com/
    http://www.sonicdesign.ch/startseite_de.cfm
    http://www.drw-disco.de/
    http://www.pa-bottrop.de/
    http://www.showkon.de/
    http://www.pro-i-vent.com/nonflash/start.htm
    http://www.emmert-veranstaltungstechnik.com/
    http://www.merlin-online.info/
    http://www.mediatec-kempen.de/
    http://www.citibeats.de/
    http://www.jam-hot.de/
    http://www.bsl-showtechnik.de/
    http://www.mdspatec.com/
    http://www.rent-my-sound.de/
    http://www.rode-online.info/
    http://www.asr-tech.de/
    http://www.sel-veranstaltungstechnik.de/
    http://www.lambeckvt.de/
    http://realhorns.de/
    http://www.p-d-e.de/pages/
    http://www.kolb-audio.de/
    http://phonhaus.net/
    http://www.pauersound.de/
    http://www.kompakt-sound.de/
    http://www.event-audio-service.de/
    http://www.cms.sadis-event.de/index.php
    http://www.tonwerk.com/content/index_ger.html
    http://www.jw-electronics.com/
    http://www.musicmediaservice.de/
    http://www.allsound.de/
    http://www.noexit-liverock.de/
    WAS DABEI?
    mal nach Beiträgen sortiert:
    http://www.sound-klinik.de/
    http://www.dmd-power.de/
    http://www.masterlight.de/
    http://www.tamaris-pa.de/
    http://www.av-kom.de/
    so, hab keine Lust mehr....
    will wer weiter machen?
    sonst geb ich mal die 5
  • verzweifelt gesucht.
    • dasich
    • 22. Juli 2006 um 14:06
    http://www.sengpielaudio.com/Kochrezepte.htm
    bittaaaschöööön
    Ob das alles so stimmt was da steht, sei mal dahin gestellt.
    Obs hilft, wenn man es gelesen hat auch.
    In jedem Fall schön ausführlich geschrieben und gut zu lesen.
    • dasich
    • 22. Juli 2006 um 14:05
    ich war das...wass bietest du denn :D
  • Quali
    • dasich
    • 22. Juli 2006 um 14:04
    sorry schlechter einstieg
    Die Suche hat 584 Ergebnisse ergeben
    Die Suche hat 803 Ergebnisse ergeben
    Was suchst du denn wo?
    Cases gibt es nur so als Beispiel amptown-cases, koppicases,huss-licht-ton,crossmedia-cases,skbcases,case-service :roll: :roll:
    • dasich
    • 19. Juli 2006 um 15:39
    Zitat von "treibsand"
    Im Normalfall kann man die Backline (bis auf Bassdrum) so abstimmen und spielen, daß eine Verstärkung nicht erforderlich ist.
    Da muss man sich als Mischer nur so durchsetzen, daß die Instrumentalisten Ihre Amps auf eine vernüftige Lautstärke bringen.
    Schon hat man während des Gigs mehr Zeit fürs Biertrinken. :wink:
    EXAKT
    :D uiuiui, ich hatte schon viele Abstürze dank so einer Regelung.
    Soundcheck wie folgt:
    Spiel mal Schlagzeug.....
    Bass,spiel mal dazu. Amp ein wenig lauter...stop ein wenig leiser
    So noch ne Git. selbes spiel...wunderbar.
    Jetzt noch den Kanal mit den Vocals auf....Prost
    Wenn die Band jetzt noch gut ist, wird es mit Verstärkung nie besser :!: :wink:
    • dasich
    • 19. Juli 2006 um 14:17
    Zitat von "Montesuma"
    Hier isser, der Spruch, schlimmer gehts ja nimmer:
    :D schon tausend mal gemacht.
    muss nix schlechtes sein.
    8) OK für openair evtl schon
    • dasich
    • 19. Juli 2006 um 13:24
    :roll:
    mir persönlich fehlt etwas der Spruch
  • Suche Bilder von WM Übertragung
    • dasich
    • 14. Juli 2006 um 17:14
    bilber werden wieder kommen. Grund ist http://www.iupload.de hat zugemacht.
    die Bilder sind dann wieder unterhttp://apbtools.com/forum/wbblite/thread.php?threadid=102&sid=1ac17818c2d2c617e4ee476d409aa361&page=2
    zu sehen.
  • Plexiglaswand für Drums - benutzt Ihr sowas?
    • dasich
    • 14. Juli 2006 um 11:49
    Reicht es nicht, wenn es oben und hinten offen bleibt? Soooo viel dB kommen da nicht mehr durch. Zumindest ausreichend wenig, daß die vorne stehenden Musiker sauberer abgenommen werden können.
    doch das reicht schon.
    In meinem Fall war aber die geschlossene Kiste praktischer.
    Kiste hingeschoben, Multicore rein und gut.
    Dadurch das die Kiste abgeschlossen war konnten wir alles drinlassen.
    Die Produktion lief über zwei Jahre bis zu 3-4 mal/Woche in einem Haus und musste jedesmal aufgebaut werden.
    Da spart so ein komplett eingerichtetes Schlagzeug schon eine Menge Zeit
    • dasich
    • 14. Juli 2006 um 10:28
    ne da hat kein Lidl Ventilator geholfen.
    Das war ne Holzkiste aus Multiplex mit richtiger Tür und so, also komplett geschlossen.
    Wir haben da sogar mit so einem Trocknerschlauch eine abgesetzte Abluft eingebaut. Mit so einem dicken Lüfter, der dann 10 Meter weiter hinten stand und er hatte noch an der Decke einen Ventilator hängen.
    In der Kiste war es einfach immer super heiß und stickig.
    War eine 3,5 Stunden Show, die arme Sau hat mir schon Leid getan.
    8) Tja hätte er mal in der Schule besser aufgepasst und etwas vernünftiges gelernt 8)
    • dasich
    • 14. Juli 2006 um 10:13
    Ich habe mal eine ganze Batterie von Plexiwänden anfertigen lassen.
    Wegen Lagerung, Transport und aus Kostengründen die untere hälfte aus Holz mit Teppich bespannt und oben dann Plexiglas. Nut und Feder Prinzip
    Das war für ein Musikal.
    Da standen zwei Schlagzeugsets und div. andere Schlagwerke direkt hinter den Streichern.
    Es hat doch schon sehr geholfen und war für diese Produktion auch optisch nicht so das Problem, da das Orchester auf einer Hinterbühne hinter einer Gaze saß.
    Auf einer normalen Bühne den Schlagzeuger kompl. hinter Plexiglas zu stellen, was ja auch eine gewisse Höhe haben muss damit es funktioniert, mach keine Freunde bei den Musikern.
    Ich habe auch schonmal ein Schlagzeug komplett in eine Kiste verbannt.
    Mit Isoliermaterial ausgekleidete Holzkiste.
    So ca 5m² gross mit vorne und seitlich Plexiglas um den Kontakt zu dem Dirigenten und anderen Musikern zu erleichtern.
    Der Schlagzeuger hat dann noch einen Kopfhörer und einen Ventilator bekommen.
    Für mich war das absolute Spitzenklasse.
    Aber der Schlagzeuger selber hat mich nach der Produktion glaube ich gehasst.
    Ich musste ihm auch nach jeder Vorstellung ein Bier ausgeben, damit er die Killos wieder drauf bekommt, die er in der Kiste immer verlohren hat.
    Da waren gefühlte 50° C drin.
    :D War auch eine Musikalproduktion.
    Bei solchen Produktionen muss man sich immer mit dem Dirigenten gut halten, dann kann man schon Sachen durchsetzten, die sonst unmöglich sind.
    8) Ach ich liebe das.
  • Drum Effekte?
    • dasich
    • 14. Juli 2006 um 09:59
    Zitat von "Tobias Zw."
    Witzigerweise finde ich die "alten, schlechten" Digitalhalle für Rock'n'Roll-Drums immer noch am besten. Meiner Meinung nach setzt sich die räudige 8-bit-Hallfahne eines SPX90 oder 900 viel besser durch (und klingt auch besser) als z. B. ein TC M2000. Bei Gesängen ist's dann bei mir genau umgekehrt. Und, wie gesagt, das ganze gilt nur für Rock'n'Roll.....
    MfG Tobias Zw.
    Dem stimme ich zu 100% zu.
    Bei mir steht für R´n´R auch immer ein SPX90 / 900 auf dem Rider.
    Man braucht viel weniger Hallanteil um ein schöneres Ergebniss zu erzielen, wie mit den "gut" klingenden.
  • Phantasialand Scanner
    • dasich
    • 13. Juli 2006 um 22:35
    Frag mal bei http://www.avisys.de/
    ich glaube die haben das ausgestattet
