Fragen zu Meyersound MSL 3
  • Neo
  • 25. Juli 2006 um 16:42
  • Neo
    ich interessiere mich für die MSL3 hat jemand technische Daten, Größe, Gewicht, und bis wann wurden sie gebaut.
    Hab im Web nix brauchbares gefunden.
  • dasich
    • 25. Juli 2006 um 17:02
    http://www.meyersound.com/products/legac…sl-3a/index.htm
    MSL-3A Reinforcement Loudspeaker
    70°H 60°V
    21 1/4" wide
    56 3/4" tall
    30" deep
    241 lbs (109.3 kg)
    Max SPL (Peak/Cont): 135/130
    Freq Range: 75-18 kHz
    You can download this product data sheet in Adobe Acrobat format.
    Acoustical - MSL-3A/M-3A System
    Frequency Response 1 ±4 dB from 75 Hz to 18 kHz
    Maximum SPL 2
    Continuous 130dB
    Peak 135 dB
    HF Coverage
    Horizontal 70°
    Vertical 60°
    Acoustical Crossover Frequency 800 Hz
    MSL-3A Loudspeaker
    Transducers
    Low Frequency (2) MS-12 12-inch cone drivers, 8 ohms per driver
    High Frequency MS-2001A 2-inch throat (4" diaphragm) driver, 12 ohms
    High Frequency Horn 70° modified radial
    HF DC Protection 20 µF Polypropylene capacitor
    Enclosure Vented, horn loaded, multi-ply Finnish birch
    Finish Black textured, charcoal-grey carpet (optional) or black weather protected (optional)
    Physical Dimensions 21 1/4" W x 56 3/4" H x 30" D
    Weight 241 lbs. (109.3 kg)
    Protective Grill Hex perforated metal screen, damped, charcoal-grey foam covering
    Connector EP-4 male, EP-5 male (Europe only), Pyle National (optional)
    Rigging Aircraft pan fittings, 600 lbs. safe working load each
    M-3A Control Electronics Unit
    Input Type 3 Balanced ISO-Input™, 10k ohms
    Output Type Active, push-pull, 200 ohms output impedance
    Maximum Input Level
    Balanced +23 dBu
    Unbalanced +23 dBu
    Maximum Output Level 4
    Balanced +26 dBu
    Unbalanced +20 dBu
    Hum and Noise 5 -90 dBV
    Dynamic Range 6 >110 dB
    Sense Inputs 10K ohms true differential, opto-isolated
    Electrical Crossover Frequency 800 Hz
    High Frequency Delay Type Active all-pass
    Driver Protection Circuitry
    Low Frequency RMS limiter
    High Frequency RMS limiter
    Indicators
    Sense; Hi and Lo Green/Red LEDs
    Limit; Hi, Lo and VHF Red LEDs
    Safe Green LED
    Power Green/Red LEDs
    Controls
    Front Panel Input attenuator, AC power switch
    Preset Panel Lo Cut switch, Safe switch, HF EQ Switch, VHF Var/Cal switch, VHF control
    Connectors
    Balanced Input/Output 3-pin XLR (A-3) female/male
    Sense Inputs Banana jacks
    Power 120/240V AC, 50/60 Hz (internally switchable)
    Physical Dimensions 19" W x 1 3/4" H x 7 3/4" D, Standard rack mount
    Weight 8 lbs. (3.6 kg)
    Es grüßt der Stephan
    • 25. Juli 2006 um 18:43
    geile box, gabs fast baugleich auch von AudioPerformance als SL II.
    meines wissens wurde die produktion irgendwann in den 90ern eingestellt.
  • ImmerLauter
    • 25. Juli 2006 um 19:26
    Die Audio Performance SL II gibts sogar immer noch neu zu kaufen, auf Anfrage allerdings. Die Box hat so viele Fans, dass die immer noch mit nichts anderem arbeiten möchten (trotz des Gewichtes).
    Die Meyer MSL und Audio Performance SL sind identisch bis auf den Hochtontreiber. Die SL klingt noch ein bißchen sanfter und dabei auflösender. Mid driver ist in beiden OEM von Ciare.
