  4. Biete
American Audio 6001plus, wie neu hat noch Garantie!!
  • bowdy
  • 17. Februar 2010 um 13:03
  • bowdy
    Kaum Gebrauchte 1,5 Jahre alte American Audio 6001plus
    Output Power:
    - 2 ohms, 1 khz 1% THD 2530W RMS per channel
    - 4 ohms, 1 khz 1% THD 1920W RMS per channel
    - 8 ohms, 1 khz 1% THD 1260W RMS per channel
    - 4 ohms, 1 khz 1% THD 5100W RMS (Bridged Mode, mono)
    - 8 ohms, 1 khz 1% THD 3650W RMS (Bridged Mode, mono)
    Total Harmonic Distortion (THD):
    - Less than 0.03% (20Hz-20kHz, @ 4 Ohms)
    Input Sensitivity & Impedance:
    - 1.0v rms (0 dBv) (@ 8 Ohms)
    Eingang & Ausgang:
    Eingänge: XLR 3pol und Klinke 6,3mm
    Ausgänge: Speakon und Klemmanschluss
    Dimensions & Weight: Height :
    - 5.25 (13.3cm)
    - Width: 19 (48.3cm)
    - Depth: 15.9 (40.5cm)
    - Weight: 83,3 lbs (37,8kg)
    Frequency Response:
    - ±.5dB, 1W RMS 8 ohms (10Hz - 35 kHz)
    - ±3dB, 1W RMS 8 ohms (5Hz - 85 kHz)
    Hum & Noise:
    - 100 dB, unweighted (@ 8 Ohms)
    Signal to Noise Ratio:
    - 100 dB , unweighted (@ 4 ohms full power) A Weighted
    Slew Rate:
    - 25v/usec
    Damping Factor:
    - 500 (@ 8 Ohms)
    Protection Circuit:
    - DC output protection
    - Overload protection
    - Short circuit protection
    - On & Off protection
    Special Features:
    - Limiter
    - Sub Woofer Crossover 20-200Hz
    - LED mode indicator
    - Contractor Smart Feature (Switch on rear panel to disable front volume controls)
    Power Consumption:
    - 53A @ 120V AC (@ 4 Ohms) / 25.5A @ 240V AC (@ 4 Ohms)
    Turn-On Thump Protection:
    - Yes
    Cooling System:
    - Dual 2 speed fans & heatsink
    Am liebsten in Berlin abholen, da ich für den Versand keine Garantie übernehme.
    550 Festpreis
  3. Soundbase vs WWB
  7. Astera AX5 akku refreshen
  8. "Nutzbass"
