  4. Biete
[VK:] Audio Interface Icon, kl. Studiomonitor, DJ Controller
  • slaytalix
  • 22. Juni 2013 um 12:49
  • slaytalix
    a) Neusonik Neo 3 Aktiv-Studiomonitore 24 Watt, 3" + HT im Paar 99 VHB, OVP
    NE03 (Pair)
    NE03 are affordable stereo monitors for home recording, computer use and mixing. The stereo pair feature 3" drivers with a front-mounted bass port and built-in 24W stereo power amplifier. In addition to being an affordable solution for beginners and musicians on a budget, the NE03 monitors provide a "real-world" reference for music and post playback.
    Specification
    • Stereo powered reference monitors
    • 3" drivers
    • Front-mounted bass port
    • 12W + 12W power amplifier
    • Stereo unbalanced RCA inputs
    • Black wood-grain appearance
    • Dimensions: 3.9" W x 6.0" H x 5.4" D
    • Weight: 5.0 lbs (pair)
    b) Aktive Monitore Kurzweil KS 40 A Paar VHB 89 € OVP
    Kurzweil im Paar, bekannt duch Workstations & Pianos
    Boxensystem mit 3/4" Hochtöner und 4" Treiber
    Leistung 20 Watt
    Separate Lautstärke- und Baß- Einstellpotis
    Magnetisch geschirmt
    Bassreflex-Design
    c) Icon Audio Interface Cube DJ, VHB 105 €, OVP
    USB 4 Fach Audio, Mikrofon Eingang, Fader, Duplex f. Aufnahme & Abspielen
    - 24bit 96/192 kHz 4-In/4-Out USB recording audio interface for DJs - 4x4 analog line I/O full duplex recording and playback - 4 analog inputs and 4 analog outputs on RCA jacks - Mic input on XLR connector with gain control - Individual Line ? Phono level switch for input 1 & 2 - Mic in ? Line1/2 in switch for input 1&2 - Output 1/2 or 3/4 Master volume controlled by horizontal cross fader, which also allows instant switching between both outputs - 1 headphones output with assignable source and individual volume control - Flexible channel routing via the software control panel - USB2.0 High Speed equipped - USB bus-powered - Supports Direct sound, WDM and ASIO2.0 - Compatible with Mac OSX (Intel CPU) and Windows XP, Vista (32bits), Windows 7 (32-bit/64-bit) - Full duplex, simultaneous record/playback
    d) Icon DJ Controller black I-DJX, VHB 70 €, OVP
    ICON i-DJX Mini USB MIDI-/DJ-Controller Black
    Features:
    2 x high-sensitivity touch screen with backlight.
    Preset templates are included for Deckadance, Traktor and CrossDJ.
    Backlit PVC preset covers for popular DJ software such as Deckadance, Traktor and CrossDJ are included
    34 assignable backlit buttons allow you to control majority of the functions of different software.
    “Shift” & “HotCue” buttons to use in conjunction with the other buttons to assign more control functions.
    11 assignable control encoders for controlling functions such as loop, EQ (hi, mid, low), song select, etc.
    Extremely compact and perfect match with MacBookTM
    Class-compliant with Windows XP, Vista (32-bit), and Mac OS X
    USB bus-powered
    Firmware upgrade available simply via USB connection and iMap software.
    e) Mixvibes U-Mix Control II, VHB 130 €, OVP
    MixVibes U-Mix Control 2
    Der MixVibes U-Mix Control 2 ist ein kompakter und sehr robuster DJ-Controller für DJ-Software, so dass er optimal für die Bedürfnisse mobiler, digitaler DJs ausgelegt ist. Mit insgesamt 133 Fadern, Reglern und Tastern, die dank Shift-Taste dopplelt belegbar sind, bietet der MixVibes U-Mix Control 2 umfassende Kontrolle über die Funktionen von DJ-Software, dabei ist er auf die Software MixVibes Cross ausgelegt, kann aber auch andere Programme steuern.
    Über Lichtsignale an den einzelnen Reglern bekommt der DJ eine sofortige Bestätigung jeder Funktion. Die Pitchfader des MixVibes U-Mix Control 2 sind mit 14 bit hochauflösend und gewährleisten wie auch die anderen Regler eine hohE Lebensdauer.
    MixVibes U-Mix Control 2:
    kompakter, mobiler und robuster DJ-Controller
    insgesamt 133 MIDI-Controls
    Shift-Taste für alternative Funktionen auf allen Controllern
    hochauflösende Pitch-Fader mit 14-bit
    Bestätigung durch Lichtsignale allen Reglern
    langlebige Fader, Drehknöpfe und Taster
    Bedienung optimiert für MixVibes Cross Software
    Stromversorgung über USB
    INKLUSIVE MixVibes Cross DJ LE Software
    incl. Cross DJ LE Software auf CD mit Lizenz
    Version ohne Audio Interface !
    § 19,1 USTG - Vorsteuer ist nicht gesondert auszuweisen ! Abh oder 5.90 € DHL versicherter Versand
    Alle Geräte mit Gewährleistung, Sachmängelhaftung
    Apollo Audio & E-Bike Rental.
  3. Soundbase vs WWB
  7. Astera AX5 akku refreshen
  8. "Nutzbass"
