  4. Biete
Eminence Lautsprecher Kappa Pro-12A, Kappa Pro LF 15-2
  • aposto [ka]
  • 29. September 2016 um 16:38
  • aposto [ka]
    verkaufe hier
    4 Stück Eminence Kappa Pro 12-A zu je 130€ (Thomann: 155€)
    SPECIFICATION
    Nominal Basket Diameter 12", 305 mm
    Nominal Impedance* 8 Ω
    Power Rating*
    Program Power 1000 W
    Watts 500 W
    Resonance 37 Hz
    Usable Frequency Range 57 Hz - 2.8 kHz
    Sensitivity* 97.1 dB
    Magnet Weight 80 oz.
    Gap Height 0.37", 9.5 mm
    Voice Coil Diameter 3", 76 mm
    THIELE & SMALL PARAMETERS
    Resonant Frequency (fs) 37 Hz
    DC Resistance (Re) 5.46 Ω
    Coil Inductance (Le) 1.22m H
    Mechanical Q (Qms) 6.93
    Electromagnetic Q (Qes) 0.25
    Total Q (Qts) 0.24
    Compliance Equivalent Volume (Vas) 121 liters / 4.27 cu.ft.
    Peak Diaphragm Displacement Volume (Vd) 249 cc
    Mechanical Compliance of Suspension (Cms) 0.32 mm/N
    BL Product (BL) 17.3 T-M
    Diaphragm Mass Inc. Airload (MMs) 59 grams
    Efficiency Bandwidth Product (EBP) 148
    Maximum Linear Excursion (Xmax) 4.8 mm
    Surface Area of Cone (Sd) 519.5 cm2
    Maximum Mechanical Limit (Xlim) 14.8 mm
    MOUNTING INFORMATION
    Recommended Enclosure Volume
    Sealed N/a
    Vented 17-34 liters / 0.6-1.2 cu.ft.
    Driver Volume Displaced 0.09 cu.ft. / 2.55 liters
    Overall Diameter 12.38", 314.5 mm
    Baffle Hole Diameter 11.07", 281.2 mm
    Front Sealing Gasket Yes
    Rear Sealing Gasket Yes
    Mounting Holes Diameter 0.27", 6.9mm
    Mounting Holes B.C.D. 11.69", 296.9mm
    Depth 6.22", 158 mm
    Net Weight 16.6 lbs, 7.53 kg
    Shipping Weight 18.4 lbs, 8.35 kgs
    MATERIALS OF CONSTRUCTION
    Coil Construction Copper voice coil
    Coil Former Polyimide former
    Magnet Composition Ferrite magnet
    Core Details Vented core
    Basket Materials Die-cast aluminum basket
    Cone Composition Paper cone
    Cone Edge Composition Cloth cone edge
    Dust Cap Composition Solid composition paper dust cap
    4 Stück Eminence Kappa Pro-15LF 2 8 Ohm zu je 160€ (Thomannpreis 190€)
    SPECIFICATION
    Nominal Basket Diameter 15", 381 mm
    Power Rating*
    Program Power 1200 W
    Watts 600 W
    Resonance 35 Hz
    Usable Frequency Range 38 Hz - 1.8 kHz
    Sensitivity* 97.8 dB
    Magnet Weight 120 oz.
    Resonant Frequency (fs) 35 Hz
    DC Resistance (Re) 6.5 Ω
    Coil Inductance (Le) 1.4m H
    Mechanical Q (Qms) 7.3
    Electromagnetic Q (Qes) 0.32
    Total Q (Qts) 0.3
    Compliance Equivalent Volume (Vas) 198.8 liters / 7.02 cu.ft.
    Peak Diaphragm Displacement Volume (Vd) 571.2 cc
    Mechanical Compliance of Suspension (Cms) 0.2 mm/N
    BL Product (BL) 21.6 T-M
    Diaphragm Mass Inc. Airload (MMs) 102 grams
    Efficiency Bandwidth Product (EBP) 112
    Maximum Linear Excursion (Xmax) 6.7 mm
    Surface Area of Cone (Sd) 856.3 cm2
    Maximum Mechanical Limit (Xlim) 18 mm
    Sealed N/a
    Vented 76.5-164 liters / 2.7-5.8 cu.ft.
    Driver Volume Displaced 0.152 cu.ft. / 4.31 liters
    Overall Diameter 15.21", 386.3 mm
    Baffle Hole Diameter 14", 355.6 mm
    Mounting Holes Diameter 0.28", 7.1mm
    Mounting Holes B.C.D. 14.56", 369.8mm
    Depth 6.57", 166.9 mm
    Net Weight 22.3 lbs, 10.12 kg
    Shipping Weight 24.8 lbs, 11.25 kgs
    Core Details Vented and extended core
    alle Lautsprecher sind neuwertig und waren kurz in einem Gehäuse verbaut.
    Versand ist kein Problem, passende Kartons sind vorhanden.
    Wer 4 oder mehr nimmt, bekommt einen Preisnachlass.
    Eine Rechnung von Kleingewerbe wird ausgestellt.
    Alexander
  3. Soundbase vs WWB
  7. Astera AX5 akku refreshen
  8. "Nutzbass"
