DiGiCo SD V925
  • 15. April 2017 um 11:32
    Das Firmware Paket V925 ist nun nach SD12 auch für alle anderen SD Serie Konsolen vom ftp Server auf dem üblichen Weg downloadbar.
    • 15. April 2017 um 11:49
    Hier noch die release notes:
    SD Series V925 Release Notes
    March 2017
    New Features
    Support for SD12 Console.
    A macro “Finish X-fade now” has been added.
    The Snapshot/Cues panel background colour now changes when Auto Update is enabled.
    New buttons have been added to the SD5 & SD7 Matrix panel that allows it to be viewed on all
    surfaces.
    An undo button has been added to the EQ and Dynamics panels.
    On the SD7, options have been added to make the assignment of the 4 auxs to act globally/per
    bank/per layer/per surface.
    On the EX007, an option has been added to allow one of the Four Aux Controls to act as the
    Touch/Turn control when the Master Screen is visible.
    A new “Join Groups” panel has been added to the layout menu. This allows individual channels or
    Sets of channels to be assigned to individual or multiple groups using the channel select/LCD
    buttons.
    A “select” button has been added to group setup panels for joining multiple channels to a group.
    A Wait time can now be added to Snapshot Crossfades for Faders and Pans.
    A “capture recall times” button has been added to the recall times panel. The will add the current
    time code when a new snapshot is added.
    A “Cancel Crossfade” function has been added to the snapshots/cue panel.
    A diagnostics button has been added to the Session report panel. This will provide a printable
    version of the Console diagnostics panel.
    The Matrix can now be selected as a no solo source.
    If an EQ gain is at 0dB, the LED Ring around the gain encoder will no longer be lit.
    The Gate Key source can now be switched in and out with removing the Routing.
    Channels in the SD5 center screen can now have their controls adjusted using Touch turn.
    On the SD5 Centre screen, aux sends can now be scrolled using the master section up/down
    arrows.
    A new button “assign master fader” has been added to the fader banks panel. This allows the
    Master fader to be re assigned on SD5 and SD12.
    In Offline software, an option has been added to allow the adjustment of rotary controls using a
    mouse wheel or USB controller
    Theatre
    The “Join CG” LCD function button can be disabled from the Theatre Options tab.
    The option to disable Cue insert/update has been expanded to allow the exclusion of the update
    relative Group faders button.
    A new macro has been added for “Update Group (Faders only)” has been added.
    When Channel Cues is first opened, no channels are initially selected and the “Choose channels”
    panel will be open.
    A new “View Inheritance” button has been added to the Aliases panel. This displays the
    inheritance status of the selected Alias.
    Player Sets can now be created. Players from multiple channels can now be changed using a
    single recall button.
    Fixes
    In Theatre, deleting a multi or loading a session containing a multi with no member would cause
    an Access Violation.
    Center Banks on SD7 could disappear on Snapshot recall if Centre Bank Fader Flip and Recall
    Banks were active.
    Matrix input send level scopes we incorrectly reporting on Additional Core 2 channels.
    If an input channel was set to stereo and had an input route from the local IO then an Access
    Violation could occur on session load after an incorrect shutdown or session recovery.
    Stereo Channel Right leg Phase setting was not being recalled on session load.
    SD8 would not load sessions that had been created with a 5.1 Buss.
  • DJheini 13. Februar 2021 um 13:50
    Hat das Thema aus dem Forum FOH nach Mischwerkzeuge verschoben.
  1. Leatcon 2026 Forumstreffen
