  5. Signalquellen
Audio Technica ATW-7373
  • Michael.dri
  • 1. August 2005 um 08:48
  • Michael.dri
    Kann jemand dazu was sagen? Gibt es nicht mehr zukaufen und infos im Internet so gut wie gar nicht.
    TW-R73 receiver + ATW-T73 unidirectional condenser microphone/transmitter
    Available in two frequency ranges:
    656 - 668 MHz (TV channels 45 - 47) and 728 - 740 MHz (TV channels 57 - 59)
    100 PLL-synthesized channels selectable via switches on receiver and transmitter
    True Diversity operation selects the better signal from two independent receiver sections, reducing dropouts
    Interference-resistant UHF band operation
    InvisibleLink® circuitry for optimum sound quality
    Ground-lift switch and adjustable squelch control
    Balanced and unbalanced audio output jacks
    Two receivers can be mounted side-by-side in a single 19" rack space
    ATW-T73 handheld microphone/transmitter features the same condenser element used in the legendary AT4033 studio microphone
    "The ATW-7373 was designed as a direct result of input we received from leading artists and FOH engineers over the past three years," stated Audio-Technica Live Sound Market Manager Joel Singer. "We tested the system on several high-profile tours, including the Backstreet Boys, Creed, Kiss, Michael W. Smith, and Tina Turner. Every engineer had the same response: the unit sounded like a wired mic, with better rejection than any other wireless condenser."
    gruß Michael
  • slaytalix
    • 1. August 2005 um 09:47
    Leider nicht verfügbar im ISM Band bei 863 - 865,9 MHz.
    Somit müßte man diese FX anmelden bei der "Netzagentur" (früher http://www.regtp.de)
    Willst Du das unbedingt kaufen oder hast dies schon ?
    Der letzte Streetpreis war 666 €
    Wir haben jetzt die 3000 er Serie sowie 1452 im zulassungfreien Frequenzbereich:
    Ich zitiere:"
    Audio Technica ATW7373 E
    ATW-T75 UniPak™ transmitter includes Super Hi-Z input that provides optimum load for guitar pickups
    ATW-T76 handheld microphone/transmitter features a Hi-ENERGY® dynamic element with superior internal shock mounting
    Audio-Technica announces the new ATW-7373 Multi-channel UHF Wireless Handheld Condenser System. The ATW-7373 combines the condenser element from the AT4033 Studio Microphone, with the RF performance of the Audio-Technica 7000 Series Frequency-agile UHF Wireless System. Featuring studio quality sound, operation in the 700 MHz frequency band, a choice of 100 PLL-synthesized channels, and true diversity operation, the ATW-7373 Handheld Condenser System sets a new benchmark in wireless performance.
    The ATW-7373 Wireless System consists of the ATW-T73 handheld condenser microphone/transmitter and the ATW-R73 true diversity receiver. At the heart of the ATW-T73 is the same element that is used in the AT4033 microphone. This provides a real step up in wireless audio quality, delivering rich sound, natural top end, and superb off-axis rejection, all in a rugged, roadworthy transmitter with enhanced internal shock mounting.
    The ATW-R73 receiver features an all-metal housing for superior shielding as well as dual independent receiver sections. Its "true diversity" operation selects the superior signal from the two independent receiver sections, thus reducing dropout,s and minimizing multi-path distortion. The receiver is half-rack size, which permits side-by-side mounting of two units in a single 19" rack space. Balanced (XLR) and unbalanced (1/4") audio output jacks, a ground-lift switch for the XLR output, adjustable volume, squelch controls, and RF/AF/A-B front panel indicators are also provided.
    A wide range of accessories are available for the ATW-7373, including the new ATW-A20 UHF Ground-plane Antenna System, the ATW-D70 UHF Active Unity-gain Antenna Distribution System, and the ATW-RA1 Rack-mount Antenna Kit.
    Apollo Audio & E-Bike Rental.
  • Michael.dri
    • 1. August 2005 um 10:32
    War ein Schnellschuß gestern bei EBAY für 120 EUR - neu, original verpackt-, wollte eigendlich noch ein Audio Technica aus der 1400 Serie und dachte mir schlechter kann es nicht sein.
    Meine beiden anderen sind im ISM Band
    Ich sehe gerade könnte Probleme geben:
    cc) 470-606 und 614-790 MHz (Fernsehkanäle 21 bis 37 und 39 bis 60)
    Bedarfsträger: Öffentlich-rechtliche Rundfunkanstalten.
    Das war wohl ein Eigentor. Werde es wohl wieder verkaufen müssen. :(
  • Michael.dri
    • 4. August 2005 um 14:58
    Heute ist das Mikro eingetroffen!
    Was soll ich sagen, Verkäufer hat falsche Frequenzen angegeben,
    das Mikro hat 100 Frequenzen zwischen
    800.550 und 819.700.
    Schwein gehabt!
    gruß, ein glücklicher Michael
  • slaytalix
    • 4. August 2005 um 15:00
    Für den Preis kann man nicht meckern, trotzdem wohl anmeldepflichtig, weil außerhalb der ISM Bänder, kannst Du beim Preis aber verkraften, denke ich :D
