  4. Andere Gewerke (nicht PA)
  5. Rigging
Gewinkelt Truss
  • goran mitic
  • 18. Mai 2008 um 12:24
  • goran mitic
    Hello Forum
    I have searched, but I could not find... I am interested in angled trusses. How do I calculate forces on two points of a truss, when the truss is angled?
    Also, there is a problem of getting the right span between points on truss in order for deadhangs to be vertical, but that is not a problem, really, as if I know left and right deadhang length, I could easily calculate needed space between points on truss.
    The main question is, how to calculate the forces on point A and on point B, if truss is angled at certain degree (alpha)?
    I was thinking, if I am tipping a truss over, the higher end should bear less load. But that seems too plain...
    Is there some literature on this, or does anyone know how to approach the problem?
    I would appreciate your input.
    Best regards, Goran
    Download latest PC and Pocket PC Rigging Software:
    Rig Them All...
  • skyper
    • 18. Mai 2008 um 21:31
    in case your deadhangs are straight downward, the forces on points A and B can be calculated the same way as on a horizontal truss. You just have to project your loads straight downwards, and calculate with the new distances/positions. (gravity always works only straight downwards, otherwise your truss would move to the side all the time... :) )
    just an example: if your truss is 15 meters long and hanged in an 45 degree angle,
    the downward projection will just be around 10,6 meters [=15m / sqrt(2)] long)
    So your calculation will be based on a shorter distance with loads placed closer together, but your deadhangs are picking the "virtual" truss further outwards!
    In case your loads are not uniformly distributed, completely new results may occur.
    Attention: this calculation will just cover the loads on points A and B, and does in no way refer to the mechanical capabilities of your truss!!!
    Please keep in mind that this angled hanging method could reduce the maximum swl of your truss seriously!
    So far for theory, now to the practical issue:
    the new distance for your deadhangs (straight downwards!) on the truss can be calculated by dividing the distance beween your points in the roof by cos alpha.
    e.g. for an angle of
    ==> 30 degrees in the shown example the new distance on the truss will be 5m / cos(30°) = 5,77m
    ==> at 45 degrees 5m / cos(45°) = 7,07m (which is sqrt(2) x 5m, the diagonal through a square, so the calcultion seems to be correct.)
    crosscheck with pythagoras: (7,07m)² - (5m)² = 25m² = (5m)² - voila!
    ==> at 60 degrees 5m / cos(60°) = 10m
  • martin.riesch
    • 18. Mai 2008 um 23:27
    hi Goran,
    the bending moment and shear forces of a diagonal truss are the same as bending moment and shear forces of a horizontal truss.
    if the truss is diagonal, there will be normal forces. this arising normal forces are not relevant for the construction of trussing, mostly.
    i have never calculated the internal forces (forces of bracing etc) of a diagonal gribbeted framework .. but now i will do and i'am interested in the results.
    free informations of diagonal beams:
    http://www.vieweg.de/freebook/978-3-519-35025-5_l.pdf
    best regards,
    martin
  • goran mitic
    • 19. Mai 2008 um 16:32
    Hello Martin, Skyper,
    skyper:
    Thank you for your elaborative answer. You explained it very clearly.
    @ Martin:
    Thank you for that link. I will translate it and try to make something out of it... ich habe meine hausaufgabe immer zu hause fergessen, also meine Deutch is sehr schleht
    (Real joke, happened to me: Once I wanted to say that I have a big wish to do something, so I said Ich habe eine grosse Wurst...)
    Danke Alles
    Best regards, Goran
    Rig Them All...
  5. Suche Lichteffekt
    19. September 2026 um 10:13
    dxnny074
    18. September 2026 um 15:16
