  4. Veranstaltungssicherheit
Festival evakuiert vor Tornado: May-Day in Memphis
  • falcocgn
  • 12. Mai 2010 um 09:31
  • falcocgn
    Hallo Gemeinde,
    es geht wieder los. In Memphis wurde das "Beale Street Music Festival" trotz Tornado-Vorwarnung durchgeführt und dann evakuiert. Auf einer der Bühnen wurde das Bühnendach planlos und mit vollem Licht an abgelassen, während darunter die Band ihr Equipment zusammenpackte. Ein Motor blockierte bei der Aktion und verursachte Sachschäden und -zum Glück- leichte Verletzungen bei einigen Kollegen.
    http://www.plsn.com/index.php?option=com_content&task=view&id=5689&Itemid=1
    "May Day in Memphis: A Near Miss at the Beale Street Music Festival
    MEMPHIS, TN - Thunderstorms had passed through Memphis the morning May 1, so there was a feeling of gratitude in the air, along with sunshine, when the three-day Beale Street Music Festival got back underway on its second day. Few knew a storm cell packing 135 mph winds would soon be heading their way.
    Close to 40,000 music fans filled Tom Lee Park along the banks of the Mississippi. Even with the threat of further stormy weather coming in later than evening, it was easy to dismiss the risk. The air was calm, the music was pleasant, and the biggest threat from the sky seemed to be a bit of light drizzle.
    But as the skies darkened, Scott Chamryk with Premier Global Productions was getting updates from sheriff's department and NOAA officials who had been on site, tracking radar reports of approaching thunderstorms.
    The radar forecasts went from uncertain to ominous, and a consensus emerged. A super cell storm system packing 135 mph winds was heading directly for the festival site. It was time to pull the plug.
    Tornado sirens wailed, prepared emergency announcements were played on the P.A. system, and Music in May, the festival organizer, put its evacuation procedures into gear. Tens of thousands of fans started leaving the festival grounds.
    By now there was some light drizzle falling from the night sky, but still not much wind. But as some crew members were scrambling to protect gear in case the drizzle turned into a downpour, others were fearing something worse than mere rain.
    "It was a chaotic moment," admits Chamryk, who was well aware of the strength of the storm cell bearing down on the festival site. Knowing that the worst of the storm might only be 15 minutes away, Chamryk sought to minimize risk from flying debris by lowering the truss-mounted lighting fixtures and the roof - a task normally done over the course of 30 minutes to an hour.
    Peter Moshay, production manager with Hall & Oates, which had been three songs into their show on the Sam's Town stage when the festival was abruptly cancelled, heard the sirens, but had no idea that a tornado-producing storm cell was headed straight for the site. Judging from the calm air, he figured that danger was at least 30 miles away.
    Other show officials maintain that all crew members and performers were ordered to leave the stage and seek shelter in their tour buses and vehicles before the lighting truss and roof were lowered. And Chamryk says he was sure that the stage was empty before the lighting truss and roof were lowered.
    Moshay says he took the evacuation orders to mean the fans, not the crew. With no clear directive, he felt as though the situation was "every man for himself," and was startled by what he says happened next.
    "The lighting crew decided it was a good idea to drop hot (lit with power) lighting trusses to the deck while we were still packing up the band gear. Then someone thought it was a even better idea to drop the roof while we were all on stage. Nobody," he says, "was watching the roof as it came down.
    "One motor did not engage and the roof twisted and the motor broke loose dropping the roof onto us. Luckily, a few of us who were onstage at the time hit the deck and were spared as the truss stopped on the sidefills and other pipes...we got away with scrapes and bruises and a sprains.
    "All the time that they were dropping trusses and the roof, we were screaming to stop, as they were dropping steel on us as we were packing up onstage. Had there been a professional stage manager at the event, this would have not happened."
    Mike Borne, president of Allstar Audio, was not at the Sam's Town stage at the time of the accident but was at the festival, and some of his company's gear was damaged in the Sam's Town roof mishap. (Moonshine Lighting also says it sustained gear damage.)
    According to Borne, "there were stage managers assigned to all the stages on site," and adds that "all of the bands and crew had to check in with these stage managers as they arrived." He also maintains that it might have been safer to keep the fixtures lit rather than lower the lighting gear in a darker environment. But his accounting of the events doesn't deviate entirely from Moshay's take on what happened.
    "During the safeguarding and battening down of the gear, and subsequent lowering of the roof, an equipment malfunction caused one of the roof hoists to fail, allowing the downstage right corner of the roof to collapse about seven to 10 feet onto our sidefill speakers, and finally rest on the downstage lighting truss," Borne says. "It did not, however, fall all the way from trim height."
    Borne does not deny that the festival's Sam's Town stage dodged a bullet. "I think it was a relatively close call, and we were very fortunate, to say the least."
    The same could be said for the festival as a whole. The storm cell appears to have produced a tornado that tracked along the Mississippi river - but the opposite riverbank, not the side the festival was on.
    If everyone agrees that things could have been worse, Moshay, who sustained a minor injury to his hand, argues that things could have - and should have - gone smoother. He also voices skepticism that the damaged roof was fit for use the next day. It was put into service for the Sam's Town stage the next day, where Earth, Wind and Fire and others performed.
    Premier Global Productions business manager Brian Andrews counters that view, insisting that there was a thorough inspection for weakness and cracks after the incident. "We're talking about steel here, not aluminum," Andrews says. "There were no cracks."
    If the Memphis and the Beale Street Festival both emerged relatively unscathed - particularly in light of the more extensive flooding problems caused by the same storm system to the Nashville area - the mishap on May Day underscores an enduring conflict for an industry that tries to embrace "Safety First" as tightly as "The Show Must Go On."
    Everybody would agree that "gear can be replaced, but lives can't." But if "Gear vs. Life" is a no-brainer, those working in the live entertainment industry will always be faced with a shifting array of risk-benefit scenarios - gray areas - where risk creeps in.
    That's why Music in May decided to go ahead and stage the Beale Street Music Festival in the first place, even though it was conceivable - if unlikely - that it could be torn apart with a direct hit from a twister.
    That's also why Moshay and crew were busy packing up gear, with the wail of tornado sirens in the distance, instead of simply leaving the gear behind until the risk of severe weather had passed."
    Es hätte schlimmer kommen können und zeigt umso mehr die Notwendigkeit von existierenden und kommunizierten Notfallplänen und dem "A... in der Hose", diese auch umzusetzen.
    - DAS Fachbuch für die Veranstaltungstechnik https://www.europa-lehrmittel.de/Fachkunde-Vera…technik/60877-1
  • tufkaklto
    • 12. Mai 2010 um 09:55
    Der gemeine Ami an sich hat so viel Angst auf dem Job was falsch zu machen und gefeuert zu werden, sodaß er nicht global die Initiative ergreift sondern nur in seinem Eigenen eingegrenzen Bereich.
    Wenn da nicht im Vorfeld wer ganz dezidiert damit beauftragt wurde, dann wird das auch nix mehr....
  • tufkaklto
    • 13. Juni 2010 um 10:16
    Ok, Gegenbeispiel:
    Wir hatten gestern eine Evakuierung auf dem Festival, wo ich gearbeitet habe.
    Muß auch sagen, das dies sehr gut ablief und ich sogar erstaunt war, das ein Veranstalter wirklich rechtzeitig und sinnvoll was unternimmt.
    Nova Rock unterbrochen
    Vom Unwetter betroffen war auch das Musikfestival Nova Rock im burgenländischen Nickelsdorf, das Samstagabend nach einer Unwetterwarnung unterbrochen und die Areale vor den beiden Hauptbühnen geräumt werden mussten.
    Laut Veranstaltern sei das von mehr als 50.000 Menschen besuchte größte Rockfestival Österreichs an einem Abbruch "knapp vorbeigeschrammt". Das Programm wurde schließlich mit einer halbstündigen Verspätung wieder aufgenommen.
    Wobei die Pause war eine gute Stunde.
    Wir haben auch die Bühne geräumt und sind in Container gegangen, das Publikum wurde mit Durchsagen aufgefordert, das Gelände Richtung Zeltplatz zu verlassen und anschließend sofort mittels Securities schnell weggebracht.
    Das Unwetter ist keine 2 Kilometer an uns vorbeigezogen :shock: :shock:
    Das Schauspiel an Blitzen war dafür einzigartig :D
  • falcocgn
    • 14. Juni 2010 um 09:46
    Hallo Klauston,
    danke für die Info. In der letzten Woche hatten wir mit 30.000 Besuchern zu tun und einem von Südwest heraufziehenden Unwetter. Wir haben das ab Mittag auf den üblichen Quellen beobachtet. Am Spätnachmittag führten wir dann ein Gespräch mit dem Productionmanager der nicht unbedeutenden Künstlerin. Er hatte selber schon ein Prozedere, um der Künstlerin eine Nachricht zukommen zu lassen zum unterbrechen und auch zum abbrechen. Das haben wir dann mit dem Veranstalter besprochen, in saubere schriftliche Form gebracht und waren froh, dass das Unwetter erst (allerdings direkt) nach dem Show-Ende eintraf. Der Abbau gestaltete sich dann recht nass und von Arbeitspausen unterbrochen (wegen Blitzgefahr).
    Ich kann allen nur raten, sich frühzeitig Gedanken über den Fall der Fälle zu machen.
  • tufkaklto
    • 14. Juni 2010 um 10:58
    Ja, in unserem Fall hätten wir Techniker nichts gemerkt.
    Es war nur langsam aufkommender Wind, aber nichts unangenehmes, im Gegenteil.
    nach einem Tag mit 36° hat uns das gefreut.
    Dann kam plötzlich der PL und teilte mit, Planen vorbereiten, das man im Notfall schnell dichtmachen kann, es könnte Gewitter kommen.
    10 Min später wurde schon Alarm gegeben, eine kurze Durchsage und das Gelände wurde geräumt.
    Mitten im Gig, egal.
    Planen drüber und nach hinten in die Container......
    Aber ganz ehrlich, macht ein gutes Gefühl, wenn man weiß, das im Notfall auch sowas vorkommt.
    Man könnte ja auch selbst Betroffener sein....
    Wir hatten Heute Nacht beim Abbau wieder Gewitter, allerdings in einiger Entfernung.
    Es wurde aber immer beobachtet, das das Gewitter nicht näher kommt, sonst hätten wir auch die Bühne wegen Blitzgefahr geräumt.
  • tufkaklto
    • 8. August 2010 um 23:49
    Und weiter gehts:
    http://uk.sonispherefestivals.com/2010/08/freak-storm-hits-finland/
    funkbrother
    5. Oktober 2026 um 16:21
  4. Leatcon 2026 Forumstreffen
