Ich schreibe es mal hier rein, bei Bedarf bitte in die richtige Rubrik verschieben.
Auf der NAMM war erstmals zu sehen:
http://forums.prosoundweb.com/index.php/topi…html#msg1314260
Ich habe heute ein Datenblatt bekommen auf dem folgende Features für die SB3216 aufgeführt sind:
Peavey Electronics and Waves have partnered to produce one of the most innovative and feature-rich digital audio mixing platforms on the market today. The 3216 Stage Box IO interface from Peavey, powered by the Waves SoundGrid audio processing/networking platform, is designed to work with the new Waves eMotion Mixer for SoundGrid. Combined, the products result in a mixing platform that is unsurpassed in the industry with regard to features, audio quality, and value. The Peavey Stage Box IO features 32 microphone/line inputs and 16 line outputs. The digitally controlled high-quality mic preamps feature ultra-low input noise, high slew rate, very low THD, and 66dB adjustment range in 1dB steps to maximize dynamic range. An integrated gigabit Ethernet switch allows for easy networking. Combine two Stage Box IO interfaces for a total of 64 inputs by 32 outputs.
• 32 microphone/line inputs
• XRL mic and TRS ¼" line inputs
• 16 Line outputs
• High performance digitally controlled microphone preamps feature:
• Low input noise at both high and low gain settings
• High slew-rate
• Very low THD
• Mic input accepts a +27 dBu input signal without pad
• 66 dB adjustment range in 1 dB steps to maximize dynamic range
• Gain changes on zero crossing to minimize adjustment noise.
• 48 Volt phantom power switchable on every mic input.
• Integral gigabit Ethernet switch for easy networking
• Waves SoundGrid Digital audio network protocol
• Balanced output maximum level switchable between + 24 dBu and + 18 dBu
• Supports sample rates of 44.1 kHz, 48 kHz, 88.2 kHz and 96 kHz
• External word clock input and output
• Two AES digital outputs
• Headphone output with level control
• MIDI in and switchable out or thru
• 4U rack mount package
• Universal input power supply
Die zugehörige Software heisst eMotion LV1 und kommt wohl direkt von Waves. Das Datenblatt sagt dazu folgendes:
• 64 input channels (mono/stereo)
• 32 stereo busses + return channels
• L/R, center, mono main busses + master channels
• 8 DCA faders, 8 mute groups, 8 user-assignable function controls
• Cue/SIP and talk-back
• EMO-Q4 Equalizer: 4-band EQ with HP and LP per channel
• EMO-D5 Dynamics Processor: Comp/Gate/Expander/DeEsser/
• Limiter/Leveler per channel
• Up to 6 plugins per channel
• Connect to multiple DAWs for recording and playback
• Save and transmit sessions and snapshots from any DAW to eMotion
• Connect and share SoundGrid I/O devices, drivers and applications
• Up to 1000 Scenes/Snapshots
• Up to 96 kHz sample rate
• Automatic plugin delay compensation
Mehr ist hoffentlich auf der PLS zu sehen.
Micha
