DiGiCo Core2
Zitat von "DiGiCo"Alles anzeigen
SD Series Software V821 Stealth Core 2 Release Notes
These release notes cover new features and fixes from V760 to V821 Stealth Core 2
V821 replaces V760 as the production release.
IMPORTANT NOTE:
When using multiple consoles on an Optocore loop, please ensure that all consoles are running the same version of software and same Optocore Firmware.
V821 Will only load sessions last saved in V300 or later.
SD V821 is Compatible with Waves 9.8 or above only. If you are running Waves MultiRack on your console, please visit http://www.waves.com/downloads/digico to download the latest version. Waves 9.7 or earlier is not compatible with SD Series Stealth Core 2 Software.New Features
Stealth Core 2 Processing and interface. Users are allowed three console starts after upgrade before an activation password is required (Activation password is not required for SD5-CS or SD7). Sessions made in versions earlier then V821 may need to be restructured to access additional resources.
Multi-Band Compressor, Dynamic EQ and DiGiTubes can now be accessed on every channel and Buss on every console.
A “graph” button has been added to Reverb FX and Dynamics panels. This opens an expanded panel with a graphical representation of the processing. All controls can be adjusted by touch.
The consoles now have the following Inputs/Bussing processing available.
SD11 48 Inputs – 24 Busses + Master
SD11i/B 80 Inputs – 24 Busses + Master
SD9 96 Inputs – 48 Busses + Master
SD8 120 Inputs – 48 Busses + Master
SD10 132 Inputs – 56 Busses + Master
SD5cs 132 Inputs – 56 Busses + Master
SD5 Up to 253 inputs – 128 BussesSurround bussing has been added to SD8 & SD10.
The SD5-CS 4th MADI port on can now be accessed.
Extension authorisation and activation is now done from the SD Application. The panel is located in the System menu. The extensions application in the SDx folder has been removed.
All consoles now have three fader layers. Default Console layout now uses new layers if required and the Fader Banks panel has been amended to match.
SD9 now has an on screen layer select switch for each bank. This can be moved by touch. A new macro, located in the layout commands, has been added to show or hide these controls.
Move and Swap have been added to the LCD Func menus where they did not previously exist. (SD8, SD9, SD10, SD11)
Text chat function is now available on all consoles.
A new “keep old presets” button has been added to the load session panel. When active, this will add any existing console presets to the session being loaded. When disabled, existing presets will be cleared before session load.
Support added for Optocore, Hydra and Waves DMI cards in an Orange Box. Support for Waves MultiRack 9.8. Waves 9.7 will not function correctly with V821
The Waves port (if present) can now be added and function as an IO device in Audio IO without having to enable Waves MultiRack.
In audio IO, SD9 and SD11 can now have Optocore connections added to ports 1, 2 and 3.
Aux Setup panel now allows choice of Inputs Only, Groups Only, or Both for the actions on all sends of the pre/post switches and the Copy Levels button list.
There are now two modes for triggering Macros with GPIs. A “GPI Macro Mode” selection has been added to the GPIO relays panel.Theatre
Channel Cues and Module Cues are now resizable. Snapshot Name column has been made wider.
A Fire Selected button and column widths +/- buttons have been added to CG Cues. Matrix Preset names contained in Snapshots now listed in Session Report
CG AutoMute now defaults to on.
In Theatre, the "New Custom" Alias button has been removed. The "New" button now displays the table of modules to copy and/or update, with the exclusion defaults set as Filters, EQ, and Dynamics.Fixes
Consoles were not loading their Waves session on start up or session recovery.
Fire Next command macro was firing twice when triggered by a GPI.
Tap tempo values were incorrectly being affected by the consoles frame rate.
At 96K, DD4MR devices in audio IO were showing double the required number of sockets and fiber channels. -
Ich habe zunächst die offline Editoren von SD8 und SD11 geladen und kommentiere mal die Dinge, die meinen Pultbetrieb betreffen und weise darauf hin, dass das meine ganz persönlichen Vorstellungen und Bedürfnisse spiegelt und für jemand anderen ganz anders aussehen kann:
Zitat von "DiGiCo"Multi-Band Compressor, Dynamic EQ and DiGiTubes can now be accessed on every channel and Buss on every console...
Das ist schön, allerdings muss man hier für wenig DiGiCo Erfahrene noch mal sagen, dass es sich auch bisher nicht um Inserts sondern um immer in allen Kanälen vorhandene Dinge gehandelt hat nur eben mit begrenzten Instanzen. Ich bin seit über 20 Jahren bekennender Fan von DPR901 dem die DiGiCo Variante des Dynamic EQ sehr ähnlich ist und ich nutze auch die Tube Emulation und den Multicomp. Trotzdem hat sich bisher mein Bedarf nach noch mehr Instanzen davon eigentlich eher in Grenzen gehalten.Zitat von "DiGiCo"A “graph” button has been added to Reverb FX and Dynamics panels. This opens an expanded panel with a graphical representation of the processing. All controls can be adjusted by touch.
Das werde ich sicher nicht nutzen, da man schon bisher alle FX Parameter gleichzeitig sehr komfortabel mit einem einzigen Touch auf Hardware-Encoder legen konnte. Das ist mir lieber. Die neue "nüchternere, zweidimensionalere" Graphik der Stripdarstellung insgesamt ist ebenfalls Geschmackssache. Ich fand die alte hübscher und die on/off Buttons in den Kanälen waren ein wenig größer und damit besser zu sehen.Zitat von "DiGiCo"The consoles now have the following Inputs/Bussing processing available.
Ob ich wirklich 80 Inputs mit den 12 Fadern von SD11i verwalten will, glaube ich eher nicht. Da ich auch bisher etliche Stereo-Kanäle genutzt habe, konnte ich auch vor V821 ein 48er MADI-Rack mit den 40 Flexi-Channels der 'i' Version vollständig auslasten. Sehr gut finde ich, dass ich jetzt mehr Mono-Auxe machen kann. Das war bisher öfter knapp.Zitat von "DiGiCo"SD8 120 Inputs – 48 Busses + Master
Ja, hier machen mit 37 Fadern auch die vielen Mono-Inputs Sinn, da man hier schon immer bequem 2 MADI Racks = 96 Kanäle betreiben konnte.Zitat von "DiGiCo"
Sehr schön, endlich erfüllt mein SD8-Joy-Stick seinen eigentlichen Zweck
Zitat von "DiGiCo"Extension authorisation and activation is now done from the SD Application. The panel is located in the System menu. The extensions application in the SDx folder has been removed.
Jo, wobei man das ja immer nur einmal nach dem Updaten anfasst. Da war es eigentlich auch nicht schlimm, das im Windows zu suchen.Zitat von "DiGiCo"All consoles now have three fader layers. Default Console layout now uses new layers if required and the Fader Banks panel has been amended to match.
Damit ist geklärt, wie das mit den vielen Kanälen geht ... :wink:Zitat von "DiGiCo"Move and Swap have been added to the LCD Function menus where they did not previously exist. (SD8, SD9, SD10, SD11)
Suuppi, das macht das Layer umkonfigurieren schneller ...jetzt sollte ich das bei SD genauso schnell können wie bei A&H :wink:Zitat von "DiGiCo"Text chat function is now available on all consoles ...
Hihi, ... kleiner small talk gefällig?
Zitat von "DiGiCo"A new “keep old presets” button has been added to the load session panel. When active, this will add any existing console presets to the session being loaded. When disabled, existing presets will be cleared before session load.
Das ist eine sehr gute Sache. bisher habe ich alle halbe Jahr die presets händisch entmüllt, weil die libraries der Kollegen vor allem beim SD8 "zwangskummulieren" und das dann ziemlich unübersichtlich wird ...Zitat von "DiGiCo"Aux Setup panel now allows choice of Inputs Only, Groups Only, or Both for the actions on all sends of the pre/post switches and the Copy Levels button list.
Ebenfalls sehr sinnvoll. :wink:
Die Liste der Bugfixes ist erfreulich niedrig, was meiner Praxiserfahrung entspricht. Inzwischen gibt's da einfach nicht mehr viel zu fixen ...
Ich habe erst mal nicht verstanden, was der act mit der veränderten Grafik soll. Jetzt ist der Groschen gefallen:
Die neue "konturiertere" Graphik kontrastiert besser im Tageslicht, was bisher ein berechtigter Kritikpunkt war. Also doch gute Sache. :wink: -
Inzwischen gibt's noch einen Bug-Fix für SD5, SD10 und SD11:
V822
DJheini
13. Februar 2021 um 13:50 Hat das Thema aus dem Forum FOH nach Mischwerkzeuge verschoben. -
