  4. Verstärker
Endstufen
  • KlangTerrorist
  • 27. September 2003 um 05:38
  • KlangTerrorist
    Was ist von diesen 2 Endstufen zu halten:
    1. Working mode: stereo/bridge mono.
    With perfect protection for short circuit, DC current.
    Standard XLR and 1/4"TRS socket.
    Adopt bulky power supply, it can reduce the interfering modulation distortion. interfering signal noise
    MODEL: CA-1200
    RMS power 8Ω): 650W
    RMS power4Ω): 1000W
    rated bridge power(8Ω): 1500W
    Frequency Response: 20Hz - 20KHz +0 , -0.2 dB
    T.H.D: <0.05%
    Input Impedance: >10KΩ
    Slew Rate: >40V/us
    Input Sensitivity: 0dB(0.775V)Full power
    Signal-to-Noise: >110dB
    Cross Talk: <-80dB
    Power: AC 230V/50/60Hz
    2. The power of FB series amplifier is very strong and its sound is very excellent.
    adopts the high-efficiency and large transformer, big capacity power supply.
    The inside filter limits the circuit, and protect the normal work of loudspeaker
    Low noise design
    Automatic two-speed fan cooling system/tunnel Transient-free turn-on/off operation(relay)
    Perfect protection for short circuit/DC votage/sub-sonic frequencies/speaker protection 0.77V,1V,1.4V input sensitivity
    The Mode:Stereo and Bridge Mono
    Output socket:2 Speakon
    MODEL: FB-20
    Output Power
    8Ω1KHz,RMs 2×1000W
    4Ω1KHz,RMs 2×1800W
    2Ω1KHz,RMs --------
    Output Power
    (bridged mono) 3000W (8Ω)
    THD <0.1% (Full power)
    Cross Talk <-80dB
    SN Ratio >100dB
    Slew Rate 50V/us
    Damping Factor (8Ω) >300
    Frequency Response 20-50KHz+1dBl (Half power)
    power supply AC230V/50-60Hz
    Dimension(W×D×H) 480×130×500mm
  • bowdy
    • 27. September 2003 um 16:21
    MODEL: CA-1200
    RMS power 8Ω): 650W
    RMS power4Ω): 1000W
    T.H.D: <0.05%
    Slew Rate: >40V/us
    Cross Talk: <-80dB
    Low noise design
    MODEL: FB-20
    Output Power
    8Ω1KHz,RMs 2×1000W
    4Ω1KHz,RMs 2×1800W
    2Ω1KHz,RMs --------
    Output Power
    Cross Talk <-80dB
    SN Ratio >100dB
    Slew Rate 50V/us
    Der Typ der die Anbietet ist mir komisch!!! Läßt sich immer wieder Neu bei Ebay registrieren und will dann die Dinger verkaufen.Früher hieß es jetzt bestellen und bezahlen und liefern in 12 Wochen.
    Ich vermute aber auch nur das es der gleiche ist weil es jemand mal so betrieben hat und die Neue Handschrift ist sehr Ähnlich.
    Also Vorsicht, nimm mal Kontakt auf. Bei Ebay hatte ich für 2 Stück den Zuschlag, dann kam nur Bla bla und später keine Meldung mehr. Zum Glück habe ich nicht vorab überwiesen!!!!!
    Gruss Bowdy
  • Kracky
    • 27. September 2003 um 19:55
    Um mal zu wissen um was es überhaupt geht, sind das diese Endstufen?
    CA-1200
    http://www.electronic-cn.com/mixeramplifier2.htm
    FB2.0
    http://www.cawboy.net/english/products2/amp2/fb2.htm
    Tolle Daten schreiben kann jeder. Aber grade mit der Produktbeschreibung CA-1200 kenne ich schon drei Endstufen, einmal Acustica, Zeck und eben die oben.
    ASR Computer & PA Technik
    André Ruhnau
    Rosenstr.6
    78598 Königsheim
  • KlangTerrorist
    • 27. September 2003 um 20:33
    genau das sind sie.....
  • Fossi
    • 27. September 2003 um 20:42
    MODEL: CA-1200
    RMS power 8Ω): 650W
    RMS power4Ω): 1000W
    MODEL: FB-20
    Output Power
    8Ω1KHz,RMs 2×1000W
    4Ω1KHz,RMs 2×1800W
    Ich verstehe die Angaben der Brückenleistung dieser Endstufen nicht wirklich...
    ein Amp der an 4 Ohm 1,8kW bringt, sollte in Brücke an 8Ohm die doppelte Leistung haben, und nicht nur das 1,5fache.
    Ansonsten ist das Netzteil zu gering dimensioniert, bzw. bei Angabe der Leistung pro Kanal wurde nur ein Kanal gemessen und der andere war unbelastet...
    Das ist doch (leider legaler) Beschiss :evil:
    Kauft Euch doch bewährte Endstufen, und wenns auch "nur" Tamps sind!
    Gruss Thomas
    blubb.
  • Kracky
    • 28. September 2003 um 04:39
    Klasse! China Ware, schön billig und für meinen Geschmack nicht zu empfehlen!
    -> verschoben nach "Party"
    André Ruhnau
    Rosenstr.6
    78598 Königsheim
  9. Suche Lichteffekt
