verkaufe hier
4 Stück Eminence Kappa Pro 12-A zu je 130€ (Thomann: 155€)
SPECIFICATION
Nominal Basket Diameter 12", 305 mm
Nominal Impedance* 8 Ω
Power Rating*
Program Power 1000 W
Watts 500 W
Resonance 37 Hz
Usable Frequency Range 57 Hz - 2.8 kHz
Sensitivity* 97.1 dB
Magnet Weight 80 oz.
Gap Height 0.37", 9.5 mm
Voice Coil Diameter 3", 76 mm
THIELE & SMALL PARAMETERS
Resonant Frequency (fs) 37 Hz
DC Resistance (Re) 5.46 Ω
Coil Inductance (Le) 1.22m H
Mechanical Q (Qms) 6.93
Electromagnetic Q (Qes) 0.25
Total Q (Qts) 0.24
Compliance Equivalent Volume (Vas) 121 liters / 4.27 cu.ft.
Peak Diaphragm Displacement Volume (Vd) 249 cc
Mechanical Compliance of Suspension (Cms) 0.32 mm/N
BL Product (BL) 17.3 T-M
Diaphragm Mass Inc. Airload (MMs) 59 grams
Efficiency Bandwidth Product (EBP) 148
Maximum Linear Excursion (Xmax) 4.8 mm
Surface Area of Cone (Sd) 519.5 cm2
Maximum Mechanical Limit (Xlim) 14.8 mm
MOUNTING INFORMATION
Recommended Enclosure Volume
Sealed N/a
Vented 17-34 liters / 0.6-1.2 cu.ft.
Driver Volume Displaced 0.09 cu.ft. / 2.55 liters
Overall Diameter 12.38", 314.5 mm
Baffle Hole Diameter 11.07", 281.2 mm
Front Sealing Gasket Yes
Rear Sealing Gasket Yes
Mounting Holes Diameter 0.27", 6.9mm
Mounting Holes B.C.D. 11.69", 296.9mm
Depth 6.22", 158 mm
Net Weight 16.6 lbs, 7.53 kg
Shipping Weight 18.4 lbs, 8.35 kgs
MATERIALS OF CONSTRUCTION
Coil Construction Copper voice coil
Coil Former Polyimide former
Magnet Composition Ferrite magnet
Core Details Vented core
Basket Materials Die-cast aluminum basket
Cone Composition Paper cone
Cone Edge Composition Cloth cone edge
Dust Cap Composition Solid composition paper dust cap
4 Stück Eminence Kappa Pro-15LF 2 8 Ohm zu je 160€ (Thomannpreis 190€)
SPECIFICATION
Nominal Basket Diameter 15", 381 mm
Power Rating*
Program Power 1200 W
Watts 600 W
Resonance 35 Hz
Usable Frequency Range 38 Hz - 1.8 kHz
Sensitivity* 97.8 dB
Magnet Weight 120 oz.
Resonant Frequency (fs) 35 Hz
DC Resistance (Re) 6.5 Ω
Coil Inductance (Le) 1.4m H
Mechanical Q (Qms) 7.3
Electromagnetic Q (Qes) 0.32
Total Q (Qts) 0.3
Compliance Equivalent Volume (Vas) 198.8 liters / 7.02 cu.ft.
Peak Diaphragm Displacement Volume (Vd) 571.2 cc
Mechanical Compliance of Suspension (Cms) 0.2 mm/N
BL Product (BL) 21.6 T-M
Diaphragm Mass Inc. Airload (MMs) 102 grams
Efficiency Bandwidth Product (EBP) 112
Maximum Linear Excursion (Xmax) 6.7 mm
Surface Area of Cone (Sd) 856.3 cm2
Maximum Mechanical Limit (Xlim) 18 mm
Sealed N/a
Vented 76.5-164 liters / 2.7-5.8 cu.ft.
Driver Volume Displaced 0.152 cu.ft. / 4.31 liters
Overall Diameter 15.21", 386.3 mm
Baffle Hole Diameter 14", 355.6 mm
Mounting Holes Diameter 0.28", 7.1mm
Mounting Holes B.C.D. 14.56", 369.8mm
Depth 6.57", 166.9 mm
Net Weight 22.3 lbs, 10.12 kg
Shipping Weight 24.8 lbs, 11.25 kgs
Core Details Vented and extended core
alle Lautsprecher sind neuwertig und waren kurz in einem Gehäuse verbaut.
Versand ist kein Problem, passende Kartons sind vorhanden.
Wer 4 oder mehr nimmt, bekommt einen Preisnachlass.
Eine Rechnung von Kleingewerbe wird ausgestellt.
Alexander
