hi was haltet ihr vom Eminence Kappalite 15'' LF
  • thomas.b
  • 18. Juni 2006 um 11:54
  • thomas.b
    hi was haltet ihr vom Eminence Kappalite 15'' LF 8 Ohm is ja fürn neodym reltiv günstig zu bekommen :)
    EKL3015LFL
    Code
    Specifications
    Nominal Basket Diameter 15", 381mm
    Nominal Impedance* 8 ohms
    Power Rating**
    Watts 450W
    Music Program 900W
    Resonance 42Hz
    Usable Frequency Range*** 40Hz-1.5kHz
    Sensitivity 99.8
    Magnet Weight 11 oz.
    Gap Height 0.365", 9.27mm
    Voice Coil Diameter 3", 76.2mm
    Thiele & Small Parameters
    Resonant Frequency (fs) 42Hz
    DC Resistance (Re) 5.31
    Coil Inductance (Le) 0.92mH
    Mechanical Q (Qms) 6.82
    Electromagnetic Q (Qes) 0.41
    Total Q (Qts) 0.39
    Compliance Equivalent Volume (Vas) 158.8 liters / 5.6 cu. ft.
    Peak Diaphragm Displacement Volume 846cc
    Mechanical Compliance of Suspension (Cms) 0.14mm/N
    BL Product (BL) 18.6 T-M
    Diaphragm Mass inc. Airload (Mms) 101 grams
    Efficiency Bandwidth Product (EBP) 102
    Maximum Linear Excursion (Xmax) 9.6mm
    Surface Area of Cone (Sd) 881.1 cm2
    Maximum Mechanical Limit (Xlim) 17.0mm
    Mounting Information
    Recommended Enclosure Volume
    Vented 102-193 liters/3.6-6.8 cu.ft.
    Overall Diameter 15.32", 389.1mm
    Baffle Hole Diameter 14.03", 356.4mm
    Front Sealing Gasket fitted as standard
    Rear Sealing Gasket fitted as standard
    Mounting Holes Diameter 0.28", 7mm
    Mounting Holes B.C.D. 14.56", 369.8mm
    Depth 7.25", 184.2mm
    Net Weight 8.6 lbs., 3.9 kg
    Shipping Weight 10.7 lbs., 4.9 kg
    Materials of Construction
    Copper voice coil
    Polyimide former
    Neodymium magnet
    Vented core
    Die-cast aluminum basket/heatsink
    Paper Cone
    Cloth cone edge
    Solid composition paper dust cap
    mfg Thomas
    >>>> http://www.kst-lan.de <<<<
    >>>> http://www.200g.de <<<<
  • Michael Roth
    • 18. Juni 2006 um 13:38
    Ich teste grad die pappe in nem doppel15er hybridbassgehäuse, für den derzeitigen einführungspreis kein schlechtes chassi was preis/leistung angeht. tiefbasswunder ist das ding logischerweise keines bei den daten, aber dafür gibts ja 18er oder andere 15er, die dann aber deutlichst im anderen preissegment liegen.
    Praxistest auf ner hip hop va in ner kneipe werd ich in 2 wochen haben, dann wird sich zeigen, ob ich am 2ten va-tag doch wieder 18er hinstelle.
    Michael
  6. Impedanz Messgerät
