Was haltet Ihr hiervon?????
  • nicom
  • 6. Oktober 2006 um 19:44
  • nicom
    Preis 2700€
    Professionelles Horn Konzert-System BOWAY® mit 4600 Watt RMS
    2 x BW-8122L
    Mid-/Hi Box 2 x 12"
    Compression Driver 45mm Titanium dome and copper coated aluminium round wire voice coil
    12" Woofer 63mm KSV former with pure copper wire voice coil
    Cabinet 18mm MDF with rock paint finishing
    Handle Steel handle for carrying
    Horn Well engineering fibre glass three way horn
    Power (Peak) 1000 Watts
    Power (RMS) 500 Watts
    Frequency Response 40Hz ~ 20kHz
    Nominal Impedance 4 ohm
    Sensitivity 105dB
    Crossover point 2.5kHz
    Dimensions (HxWxD) 1370 x 600 x 620mm
    Weight 88 kg
    Cabinet materials 18 mm MDF
    Finishing Rock paint
    Connectors 6.35 mm binding post Neutrik Speakon 4
    Accessories Steel handle
    2 x BW-8560S
    Subwoofer 2 x 15"
    Component LF: 15" woofer
    Cabinet 22mm MDF with rough paint finishing
    Power (RMS) 600 Watts
    Frequency Response 38Hz ~ 280Hz
    Sensitivity 102dB
    Crossover point None
    Dimensions (HxWxD) 597 x 1003 x 623mm
    Weight 104 kg
    Cabinet materials 22 mm MDF
    Finishing Rough paint
    Connectors 0.25" phone jack and Neutrik Speakon connector
    2 x BW-8860S
    Subwoofer 2 x 18"
    Component LF: 18" woofer
    Power (RMS) 1200 Watts
    Frequency Response 25Hz ~ 250Hz
    Sensitivity 105dB
    Dimensions (HxWxD) 710 x 1200 x 800mm
    Weight 134kg
    Cabinet materials 22mm MDF
    1 x PMA-1200
    Endstufe mit Limiter
    Type H output circuit
    Full short circuit protection, open circuit protection
    Overheat & overload protection
    Peak power limiter
    Clip indicator, soft start
    Dual speed fan motor cooling system
    Input sensitivity selector, mono/bridged selector
    Input connectors: 6.35mm phone jack, XLR connectors
    Output connectors: Neutrik speakon 4, versatile binding post
    * 2 x 800 W RMS/channel (8 Ohm)
    * 2 x 1200 W RMS/channel (4 Ohm)
    * 2400 W RMS brigded (8 Ohm)
    * Frequency response: 10 Hz - 20 kHz
    * Input sensitivity: 0,775 V, 1 V, 1,4 V
    * Input impedance: 20 kOhm/10 kOhm
    * Signal to noise ratio: > 105 dB
    * Crosstalk: > 65 dB
    * Damping factor: > 650
    * Slew rate: > 45V/µs
    * Dimensions: 482 x 517 x 132 mm
    * Weight: 36 kg
    2 x BN-450
    Type AB output circuit
    Peak power limiter
    Variable speed fan motor cooling system
    BN-450
    Output Power per channel in Stereo
    4 ohm 650 W
    8 ohm 450 W
    Output Power per channel in Bridge
    8 ohm 1,100 W
    Frequency Response 10Hz - 50kHz
    Signal to noise ratio > 101dB
    Total harmonic distortion < 0.02%
    Damping factor > 800
    Slew rate > 45V/μs
    Crosstalk > 70dB
    Input sensitivity -3dB
    Input impedance (bal., unbal.) 20kΩ, 10kΩ
    Load impedance in bridge mode 8/16Ω
    AC main voltage 230-240Vas / 115-120Vas
    Cooling system Variable speed fan
    Dimension (W x H x D) 48.2 x 13.2 x 46.5 cm
  • scanzy
    • 6. Oktober 2006 um 20:12
    Kannte die Firma bis dato nichtmal. Die offizielle HP scheint nicht zu gehen :(
  • Ravemaster
    • 6. Oktober 2006 um 20:21
    scheint nichts gutes zu sein. Kein guter Boxenhersteller verwendet MDF für seine Subwoofer...
  • TobiV
    • 6. Oktober 2006 um 20:23
    china....
    ...ein Beck's bitte...
  • nicom
    • 6. Oktober 2006 um 20:34
    Hier die Seite:
    http://www.heroessound.biz/boway/index.htm
  • Ravemaster
    • 6. Oktober 2006 um 20:54
    Nominal Impedance 8 ohm
    Sensitivity 102dB
    Dimensions (HxWxD) 699 x 597 x 800mm
    Weight 45kg
    22mm MDF ist sau schwer. dann nur 45 Kilo... tolles Chassi muss das sein (ND ist es garantiert nicht)... die restlichen werte sind auch nur geschönt...
  • manuela
    • 6. Oktober 2006 um 21:02
    das übliche eben...
    aber der portable Karaokeplayer mit wireless Mic und Accu, GEIL
  • TobiV
    • 6. Oktober 2006 um 21:07
    ein doppel12er Horntop mit 45mmVC HT-Treiber(also sicher 1" throat) und ner Trennfrequenz bei 2,5khz KANN(!) nicht funktionieren. Das ding ist das geistige Exkrement eines chinesichen BWLers mit mäßiger Allgemeinbildung.
    Desweiteren ist die Verwendung von MDF für derartige Trümmer (und überhaupt im bereich der mobilen beschallung) äußerst fragwürdig. Aber das sagte der Ravemaster ja schon..
  • Jobsti
    • 7. Oktober 2006 um 06:32
    Wie gesagt,
    1.) MDF is Mist, weil sackschwer -> 88kg Top :shock: , 104kg 15" Sub :shock: , 134kg 18" Sub :shock:
    2.) 2,5 KHz.....wie wat?
    Mit freundlichen Grüßen
  • soundfreak77
    • 7. Oktober 2006 um 15:41
    gibt es davon schon einen deutschen vertrieb??
    http://www.mm-audiotechnik.de
    Vertrieb von:
    Gisen Audio
    MM-acoustics
  • hell&dunkel
    • 7. Oktober 2006 um 15:51
    Nix.
    Das ist doch die Chance für einen Einstieg in die Selbstständigkeit. :wink:
    Kauft euch Zeugs, das erprobt ist und wo der Service stimmt.
    Wenn ihr auf Ersatzteile aus China monatelang warten müsst habt ihr ein Problem.
    Armin
