Yamaha mLAN
  • Nicky
  • 6. April 2004 um 16:10
  • Nicky
    Hallo Kollegen,
    es gibt ja nun mLAN von Yamaha, also Firewire.
    Hat jemand den Durchblick was man damit genau anstellen kann?
    Frage: Ist es möglich mit einem DM 1000 mit mLan Karte einzelne Känale an einen Computer zu übertragen, also quasi das DM 1000 als Soundkarte zu nutzen?
    Gruß Nicky
  • ThomasA
    • 7. April 2004 um 14:29
    Hi Nicky!
    Also:
    mLAN ist NICHT gleich Firewire, es verwendet allerdings die selbe Hardware.
    -------Quote-
    Just like the existing YGDAI cards which offer ADAT optical, TDIF, and AES/EBU connectors, each CD8mLAN will only handle eight audio channels because that is the limit of each YGDAI slot (see the 'Untapped Potential' box on page 154 for more on this).
    However, in an O2R, you could put four cards in and have 32 channels of mLAN audio I/O. Now, you might reasonably wonder what the difference is between putting in four mLAN cards and putting in four ADAT optical or TDIF cards, which would also give you 32 channels of digital I/O in those formats. The difference would become apparent if you interfaced the O2R with a FireWire-equipped computer. Instead of needing to add PCI cards with four ADAT optical connectors (say four Korg 1212s, two Sonorus StudI/Os, two RME Hammerfall Lites or a Frontier Dakota and Montana) or four TDIF connections (like a pair of Soundscape Mixtreme cards), you merely connect a single FireWire cable from the computer to the first CD8mLAN, saving yourself up to £1500 in PCI cards, and all 32 channels of I/O will then exit the computer on a single FireWire cable. Of course, you will have to use both 1394 connectors on each card to daisy-chain the other three CD8mLANs so that the O2R can receive all 32 of those channels, but you would still have a connector free on the final card to connect onwards to other mLAN equipment.
    ---------Ende Quote-
    gefunden unter:
    FIRE WORKS
    An Introduction To mLAN Part 3
    Paul Wiffen
    Sound on Sound magazine, October 2000
    http://www.soundonsound.com/sos/oct00/articles/mlan.htm
    weiterlesen auf:
    http://www.mlancentral.com/
    Wie das jetzt mit dem Routing auf deinem Pult funktioniert geh ich nicht suchen, dafuer gibt's Bedienungsanleitungen. Vielleicht weiss es ja auch jemand auswendig.
    lg, Thomas
    PS: Hat ca. 5min gedauert den Artikel nachzuschlagen...
    PPS: Vorsicht beim Marketinghype, die maximale Kabellaenge ist noch nicht befriedigend - und keinenfalls mit CobraNet zu vergleichen:
    ------Quote-
    Compared with 4.5m/400Mbps of IEEE1394 standard,the maximum transmission distance has been achieved up to 50m/100Mbps and 20m/400Mbps.
    -------End Quote-
    http://www.okidensen.co.jp/english/catalog/1394longcable.htm
    -> und das sind Spezialkabel!!
    "Klappe zu Gehirn! Sonst kriegst du eins mit dem Wattestäbchen."
    H. J. Simpson
    Thomas Albenberger
    Österreich
