  3. Sonstiges
  4. Bücher, Zeitschriften, Weiterbildung, Azubis
Sound Systems / Bob McCarthy: Druckfehler
  • skyworker
  • 20. Mai 2011 um 13:14
  • skyworker
    Männer, S te 11, Ka el 1 is bei me ner Aus b e woh v r ruckt, we äre denn m l s nett, mir d n rich gen Text ku z umailen?
    Wer das jetzt nicht lesen konnte - in meiner Ausgabe der grünen Bibel, zweite Auflage ist auf Seite 11 neben der Exel-Tabelle ein Fehldruck - da ist nicht wirklich was zu lesen. Wer wäre denn so nett und würde mir die Passage schnell mal einscannen oder abschreiben und schicken?
    THX
    SKY
    Kein Applaus für Scheiße!
  • chris216
    • 20. Mai 2011 um 13:27
    Wenn du bis 17 Uhr noch nix bekommen hast, leg ich meine Bibel auf den Scanner. Erinner mich per PM dran! ;)
    Christoph Holdinghausen
  • SebastianJaeger
    • 20. Mai 2011 um 13:31
    used since a doubling of voltage is a change of 6dB while a doubling of power is a change of 3dB. For the most part we will be using the 20 log version since acoustic pressure (dB SPL) and voltage are the primary drivers of our decision-making. Figure 1.10 provides a reference chart to relate the ratios of values to their decibel equivalents.
    Here is a handy tip for Microsoft Excel users. Figure 1.11 shows the formula format for letting Excel do the log cal- culations for us.
    The Electronic Decibel: dBV and dBu
    Electronic transmission utilizes the decibel scale to charac- terize the voltage levels. The decibel scale is preferred by operators over the linear scale for its relative ease of expres- sion. Expressed linearly we would find ourselves refer- ring to the signal in microvolts, millivolts and volts with various sets of number values and ranges. Such scaling makes it difficult to track a variable signal such as music. If we wanted to double the signal level we would have to first know the voltage of the original signal and then compute its doubling. With dynamically changing signals such as music, the level at any moment is in flux, making such calculations impractical. The decibel scale provides a relative change value independent of the absolute value. Hence the desire to double the level can be achieved by a
  • skyworker
    • 20. Mai 2011 um 15:59
    Cool - aber ich brauch den Absatz drüber. Fängt an mit
    "There are two types..."
    Dann könnte eine Formel kommen...
    Ab "Here is a handy tip..." kann ichs wieder lesen.
    THX
    SKY
  • SebastianJaeger
    • 20. Mai 2011 um 16:11
    There are two types of log formulas applicable in audio:
    Power-related equations use the 10 log version, while pressure (SPL) and voltage related equations use the 20 log version. It is important that the proper formula be
