Schönes für Midas User
  • kob1
  • 25. Mai 2013 um 14:33
  • kob1
    Neue Firmware V 2.1.02
    http://soundforums.net/varsity/7389-m…-available.html
    Update erfolgt anfang nächster Woche...
    Gr.
  • hermste
    • 25. Mai 2013 um 15:11
    Da danke ich meinem Vertrieb, habe vor wenigen Minuten (Wochenenddienst) Downloadlink inkl. Releasenotes erhalten, die sind bei mir etwas Ausführlicher:
    New Features:
    • Effects Pack II
    • Categories and collapsible tree for selecting effects
    • New effect: Submonster
    • New effect: Tape Saturation
    • New effect: DN60 Spectrum Analyzer
    • New effect: Variable Phase
    • Dynamics
    • New Compressor type: Shimmer
    • All compressors now have Presence control
    • All compressors now have MOR option
    • Two new gates:
    • Transient Gate (inc. Transient Accent control)
    • Ducker
    • Tap tempo now controllable by both milliseconds and note lengths for all reverb effects
    Addressed Issues:
    • Pop-up display values on controls corrected to correlate with GUI display values in the channel
    detail strip.
    • Corrected labeling of POP groups in FOH mode.
    • Addressed issue regarding memory leak from diagnostics leading to occasional slowdown/lock
    after prolonged operation.
    • You can now export a file directly after the ‘Saved As’ option has been used.
    • Surface IO is now correctly labeled on the patching screen.
    • Improvements to consistency of IO labeling
    • Input and Output Select Follows Solo now works with respective channel types only.
    • FOH MIDI port correctly listed in MIDI event list.
    • Cancel button now appears consistently in upgrade pop-up dialogue when more than one upgrade
    option is available.
    • Scene 1 of automation file is now highlighted green when safe scene is selected in a show file with
    only one scene present.
    • Matrix Mixer delay increments by 0.1ms for both inputs and outputs.
    • For the Mixtender (iPad app) server a warning message now displays when the third octet of the
    IP address is set to a value between 8 and 255.
    • DL444 D-Sub card now shows correct gain steps in the patching page.
    • “Output” label in Matrix Mixer re-aligned correctly
    • Touch reticule for pre-delay on reverb units displays correctly when using global tap tempo.
    • Surface Gate mode button.
    • Improved audio output when adjusting knee on compressors.
    • DN60 miss match between level set and display has been addressed.
  • nojunk
    • 25. Mai 2013 um 17:18
    ich habe die letzten beiden tage unsere pro1, als auch die pro2c "upgedated", laufen seit dem OHNE probleme.
    nächste woche werd' ich mich mal um die neuen features kümmern - schönes wochenende :D
  • harryhirsch
    • 27. Mai 2013 um 20:06
    Frage:
    Laufen die alten Showfiles auf der neuen Software oder sind da Probleme zu erwarten?
    Mein Pro01 lief letztendlich auch mit der 2.05.01. störungsfrei und ich will jetzt keine bösen überaschungen erleben :)
    Harald Berndsen
    Show PA Concertproduction
    Gutenbergstraße 5
    D-85276 Pfaffenhofen
    http://www.showpa.de
  • hermste
    • 27. Mai 2013 um 20:40
    ich habe meine Showfiles von der vorigen Software geladen - keine Probleme.
  • nojunk
    • 27. Mai 2013 um 22:25
    selbiges hier - sowohl pro1 als auch pro2(c).
  • harryhirsch
    • 27. Mai 2013 um 23:38
    Juhu - na dann freu ich mich :D
    Jetz brauch ich nur noch die AVB Card für die DN9650 Networkbridge :lol:
    Harald Berndsen
    Gutenbergstraße 5
  • billbo
    • 28. Mai 2013 um 00:32
    Als (meistens) Yamaha User kann ich mir eine Frage nicht verkneifen:
    Empfindet man es als Midas User eigentlich generell als Sensation, wenn die Kiste nach einem Update immer noch läuft?
    scnr... :D
    Mit freundlichem Gruß
    BillBo
  • kob1
    • 28. Mai 2013 um 11:18
    Gefühle 30Seiten verteilt auf mehrere Threads fürs iLive und V1.9, da darf man beim 1. Update für die kleinen PROs schon ein bisschen in Geburtstagslaune kommen :D
    Gr.
  • hermste
    • 28. Mai 2013 um 12:04
    Nein, keine Sensation. Allerdings gab es einfach noch nicht so viele Updates für Pro2&Pro1 (m.W. zwei) - daher das Interesse, ob es Probleme gibt. Denn wir wissen alle, wenn ich morgen mit dem Pult unterwegs sein muss und heute updaten will, soll dies ohne Komplikationen laufen. Vermutlich kommt daher die Frage...
    Ist halt ein wenig komplexer als ein (altes) Yamaha-System, bei dem eine Komponente upgedated wird. scnr.
    Bei Pro1/2 gibt es MC (Kontrollcomputer), DSP (2x FX, 6x Main DSP) und Stagebox, die alle upgedated werden wollen. Im Pro1/2 laufen zwei Rechner, ein Steuerungsrechner und ein Audiorechner.
    Bei einem CL-System ist es m.W. ähnlich, da gilt es auch mehrere Teile zu aktualisieren.
  • Christian Engel
    • 28. Mai 2013 um 13:29
    Es ist ja auch ein nicht ganz so un-umfangreiches Update mit stellenweise ganz neuen Funktionen :D Da darf man sich schon mal freuen!
  • hermste
    • 28. Mai 2013 um 15:26
    Ist vergleichbar mit einem DiGiCo Update, da werden auch mehrere Systemkomponenten aktualisiert sowie auch manchmal/meistens die Stageboxen.
    • 28. Mai 2013 um 16:09
    Yes. :wink:
  • harryhirsch
    • 24. Juni 2013 um 22:40
    Hallo Midasuser,
    kann bitte mal jemand testen ob folgender Bug nur bei unserem Pro01 passiert:
    Es geht um Auxwege bei den Returnkanälen ein und auszuschalten - wenn ich Aux16 gedrückt halte kann ich ja eigentlich mit den Selecttastern die jeweiligen Channels on/off schalten. Tut's bei mir aber nicht bei den Returns, dafür wird Aux15 geschalten...!?!
    Danke für eure Hilfe!
    Ach ja, natürlich unter V 2.1.02....
    Harald Berndsen
    Gutenbergstraße 5
  • hermste
    • 27. Juni 2013 um 12:34
    Ich kann es nachvollziehen.
    Lade Factory Defaults mit Perference Hide unassigned channels (oder wie das halt heißt, wobei das für diese Funktion nicht relevant ist).
    Dann weise ich Aux Return 1 und 2 dem Aux Send 16 über lange drücken des Aux-Send-Knopfes zu. Er ist auch automatisch auf Aux 15. Also auf beiden (nicht nur auf einem). Die Aux-Sends sind nicht gelinkt. Auch mit "normalen" Kanälen (Mic 1-40) tritt das gleiche Phänomen bei mir auf. Wie bei dir Pro1 mit DL2.1.02.
    Wenn ich das gleiche mit Aux Send 13 mache, gibt es den Fehler nicht, dass es auch auf einen anderen Aux Send zugewiesen wird. Das passiert auch nicht bei Aux Send 14. Allerdings bei Aux 15 und Aux 16. Egal bei welchem ich die Aux Send pro Kanal auf "On" schalte, passiert es auch auf dem anderen (je nachdem Aux 15 oder Aux 16).
    Mein Workaround für diesen vermutlichen Bug:
    Wenn ich die "Aux On" Befehle über das GUI-Setze, schalten sich keine Sends auf anderen Auxen auf. Scheint über das GUI fehlerfrei zu sein.
  • kob1
    • 27. Juni 2013 um 22:36
    Bug bei Pro1 und letzem Release (V 2.1.02):
    Hallfahnen werden beim Verändern von Predelay oder Decay abgeschnitten, es reicht nur den entsprechenen Encoder zu berühren.
    Hat jemand selbige Erfahrung gemacht?!
    Gr.
  • hermste
    • 28. Juni 2013 um 07:38
    Also das ist seit Generation II so, da es sich um Faltungshall handelt. Wenn du die Size veränderst, passiert das. Allerdings auch nur bei diesem einen Parameter.
    Wenn du den Parameter "Size" veränderst, wirst aus- und eingefadet. Wenn du den Parameter Decay verwendest, hast du das Problem nicht. Falls du also in einem Song die Länge anpassen willst, solltest du "Decay" verwenden.
    Bei Veränderung von Predelay und Decay läuft bei mir bei V2.1.02 alles normal weiter. Bei dir nicht?
    • 29. Juni 2013 um 22:56
    ... und ausserdem ist das nicht nur bei 'Faltern" sondern auch bei manchen rechenintensiven Parametern in algorithmischen Hardware-Halls selbst der letzten Generation so. Ich finde das nicht sooo schlimm bei komplexeren Sachen wie 'size'. Blöd finde ich das bei "einfachen" Parametern wie z.B. einer Delayzeit oder den Filtern.
  • kob1
    • 17. Juli 2013 um 14:10
    Hat lange gedauert, aber ich habs nochmal gestestet:
    Hall stoppt bei Veränderung von "Size", die ja auch das Decay verändert.
    Hall stoppt aber auch bei Predelay!
    Ich benutze in diesem Fall den Hall reverb nicht den DN760.
    Gr.
    • 24. August 2013 um 23:19
    Seit 22.08.13 ist Mixtender 2 mit deutlich erweiterten Funktionen downloadbar.
    Braucht min. iOS 6.0 und spielt daher nicht mit ipad 1.
  1. Leatcon 2026 Forumstreffen
