YAMAHA CL/QL V3.1 und Stagemix V5.1
  • 25. August 2015 um 09:00
    “The new upgrades will be very effective in the touring, theatrical, and other live sound applications, as well as corporate events, broadcasting, and more, states, Marc Lopez, marketing manager, Yamaha Professional Audio Division, Commercial Audio Products. We continue to listen to our customers in order to deliver products and updates that offer real improvements for their work environment.”
    New Features in Version 3.1 include the addition of a Pan Law Parameter with CENTER NOMINAL and LR NOMINAL settings to monaural input channels. When CENTER NOMINAL is selected, nominal level is produced when the channel is panned to center; and when LR NOMINAL is selected, nominal level is produced when the channel is panned full L or R.
    An improved Cascade Setup for DCA, MUTE MASTER, and other settings has been added to CASCADE LINK. An attenuator has also been added to the CASCADE input. RECALL SAFE, FOCUS, and GLOBAL PASTE now have independent CASCADE IN and CASCADE OUT settings. RSio64-D I/O rack patches (between the CL/QL and RSio64-D), user routing pattern, and sample rate converter control can all be accessed directly via the CL/QL Version 3.1 display.
    It is now possible to update both the console firmware and the Dante firmware for CL and QL from a USB flash drive in one operation. R Series firmware and Dante firmware must still be updated independently (the ability to simultaneously update R Series and Dante firmware from the R Remote application for is planned for a future release).
    Several significant new features have been added in StageMix Version 5.1 for CL, M7CL and LS9 Digital Consoles including 121-Band Real Time Analyzer (RTA) support that expands on the 61-band capability of the current RTA by using the built-in iPad microphone. The 121-band mode is now selectable via the SETUP screen. Also, it is now possible to make STEREO/MONO bus assignments when the mixer window is in the PAN mode.
    New features added in StageMix Version 5.1 for CL/QL only include an improved USB Recorder enabling the timeline dot to be dragged to change the playback point, or the desired playback point (time) can be entered numerically. A 2-channel sinewave has been added to Oscillator Selection, and control of the dual oscillator (SINE 2CH) added in CL/QL Version 3.0 is now available in StageMix.
    As mentioned, new features in R Remote Version 3 include control of SRC settings and other parameters via the inclusion of RMio64-D enabling a Dante/MADI conversion. And, the user pattern can be accessed and edited via the Grid Patch window.
    Console File Converter Version 3.0 for CL/QL Firmware Version 3.1 makes it possible to convert PM5D and CL/QL surround pan, divergence, and LFE level data.
  • hermste
    • 25. August 2015 um 12:15
    Etwas detaillierter in den Release Notes steht übrigens, dass das Update nur vom Dante Teil der CL-Konsolen via USB-Stick 30 Minuten (!) dauert!
    Ob das stimmt? Ich probiere es nicht aus - da mache ich es lieber mit dem Dante Firmware Update Utility - falls ich das überhaupt während des Updateprozesses entscheiden kann.
    Grundsätzlich finde ich es gut, dass es wieder in die "USB-Stick reinstecken und alles wird erledigt"-Richtung geht.
    Allerdings wäre es erst richtig interessant, wenn auch alle auf der CL5 gemounteten R-Geräte (Rio & co) gleichzeitig via diesem USB-Stick upgedatet werden bzw. ich auswählen kann, welche gemounteten Geräte upgedatet werden sollten.
  • billbo
    • 25. August 2015 um 13:55
    Richtig. Erst dann wären wir wieder bei der einigermaßen risikoarmen Möglichkeit 'Update von USB on the Fly' – wenn das örtlich vorgefundene Setup (1 oder 2 RIOs hängen ja immerhin mindestens dran) wg. veralteter Firmware mittags das Tourfile mal wieder nicht schlucken möchte. So, wie das bei M7 eine leichte und auch nicht gerade selten durchgeführte Übung ist.
    Ansonsten riskiert man, dass neue und alte Dante- Firmware nicht kompatibel sind und nach dem (Teil-) Update gar nichts mehr spielt; so war das zumindest beim letzten größeren Dante- Update.
    Erfahrungsberichte daher höchst willkommen. Wer traut sich als Erster? :D
    Mit freundlichem Gruß
    BillBo
    • 26. August 2015 um 09:20
    wenn man das so liest, denkt man unwillkürlich an die alte weisheit: "never change a running system" :lol:
  • DJheini 13. Februar 2021 um 13:52
    Hat das Thema aus dem Forum FOH nach Mischwerkzeuge verschoben.
  2. Leatcon 2026 Forumstreffen
