  2. KlangTerrorist
Beiträge von KlangTerrorist
  • SYRINCS M3-220
    • KlangTerrorist
    • 28. September 2003 um 23:26
    Hat jemand erfahrungen mit dem System??
  • Endstufen
    • KlangTerrorist
    • 27. September 2003 um 20:33
    genau das sind sie.....
  • Endstufen
    • KlangTerrorist
    • 27. September 2003 um 05:38
    Was ist von diesen 2 Endstufen zu halten:
    1. Working mode: stereo/bridge mono.
    With perfect protection for short circuit, DC current.
    Standard XLR and 1/4"TRS socket.
    Adopt bulky power supply, it can reduce the interfering modulation distortion. interfering signal noise
    MODEL: CA-1200
    RMS power 8Ω): 650W
    RMS power4Ω): 1000W
    rated bridge power(8Ω): 1500W
    Frequency Response: 20Hz - 20KHz +0 , -0.2 dB
    T.H.D: <0.05%
    Input Impedance: >10KΩ
    Slew Rate: >40V/us
    Input Sensitivity: 0dB(0.775V)Full power
    Signal-to-Noise: >110dB
    Cross Talk: <-80dB
    Power: AC 230V/50/60Hz
    2. The power of FB series amplifier is very strong and its sound is very excellent.
    adopts the high-efficiency and large transformer, big capacity power supply.
    The inside filter limits the circuit, and protect the normal work of loudspeaker
    Low noise design
    Automatic two-speed fan cooling system/tunnel Transient-free turn-on/off operation(relay)
    Perfect protection for short circuit/DC votage/sub-sonic frequencies/speaker protection 0.77V,1V,1.4V input sensitivity
    The Mode:Stereo and Bridge Mono
    Output socket:2 Speakon
    MODEL: FB-20
    Output Power
    8Ω1KHz,RMs 2×1000W
    4Ω1KHz,RMs 2×1800W
    2Ω1KHz,RMs --------
    Output Power
    (bridged mono) 3000W (8Ω)
    THD <0.1% (Full power)
    Cross Talk <-80dB
    SN Ratio >100dB
    Slew Rate 50V/us
    Damping Factor (8Ω) >300
    Frequency Response 20-50KHz+1dBl (Half power)
    power supply AC230V/50-60Hz
    Dimension(W×D×H) 480×130×500mm
  • wecleh technischen geräte bei goa / sytranceparties ?
    • KlangTerrorist
    • 27. September 2003 um 05:23
    Nen EQ und nen Digital-Controller bei Konserve.
    Bei Live einiges mehr........
  • Gabberparty??
    • KlangTerrorist
    • 26. September 2003 um 06:15
    Soo wir habens jetzt mal bissel durchgecheckt, und so schlimm isses garnicht.
    Sound war doch relativ laut. Druck ist auch vorhanden
    (nicht mördermässsiger aber doch gut drückender)
    Werden wohl vorne 6 Stacks pro Seite stellen und hinten noch eine Delay mit den kleinen Systemen die übrig sind.
    Wird schon irgendwie hinhauen....
  • Súche Ausbildungsplatz
    • KlangTerrorist
    • 23. September 2003 um 22:45
    Sollte in der Gegend von Mannheim sein.
    Art ist nicht soo wichtig.
    Hauptsache was mit Ton.
    Anfangen könnte ich nächstens Jahr ab September.
    Angebote einfach per PM.
  • Gabberparty??
    • KlangTerrorist
    • 23. September 2003 um 22:40
    naja solange der druck stimmt passt das. denke mal das wir morgen mal das lager bissel umräumen und einfach alles anschließen was wir findenn können.
    nen versuch isses bestimmt wert. aus soviel dynacord kisten muss doch was rauszuholen sein.
    wir haben auch nicht so das budjet zur verfügung. da es halt auch keine kohle einbringt.
    naja werde dann berichten obs was werden könnte.
  • Gabberparty??
    • KlangTerrorist
    • 23. September 2003 um 20:02
    Ich habe ihn angenommen weil ein Kumpel von mir Geburtstag feiert. Material haben wir uns nun überlegt. wir räumen komplett nen kumpel aus(pa verleiher) also 12stacks dynacord wave und noch paar kleinere dynacords.
    hauptsache es ist ordentlich laut.
    ps: ich höre selber auch gabber.
  • Gabberparty??
    • KlangTerrorist
    • 22. September 2003 um 20:59
    Laut Daynacord gehen mit
    8 V17
    8 V18
    8 V12
    5000Leute....
    wir haben mit
    8 V17
    12 V18
    8 V12
    so 1000 leute geschafft chartsmucke.....
    also am besten das doppelte stellen....
    sind dann 4stacks pro seite.....
    oder doch lieber alles stellen??
  • Gabberparty??
    • KlangTerrorist
    • 22. September 2003 um 20:41
    Hab aber nur das Material zur Verfügung....
    was soll ich da machen??
    6Stacks Wave auffahren oder noch mehr??
    (nen Stack sind 2-3Bässe und nen Top)
    V17
    V18
    V12
    das währe das vorhandene material
    Stacks sind glaub ich 12st vorhanden
  • Gabberparty??
    • KlangTerrorist
    • 22. September 2003 um 20:08
    Habe bald eine Gabberparty.
    Weiß aber nicht so recht wieviel ich an Ton hinstellen soll.
    12 HD´s und 2Tops werden wohl zuwenig sein oder??
    Hab auch noch die Möglichkeit an einige Stacks Dynacord Wave ranzukommen.
    Soll ich dann noch was von dem Material dazustellen oder was würdet ihr machen??
    Und wieviel sollte es sein??
    Halle hat ca 400m² und kommen ca 300-400Leute
  • Kabelklett
    • KlangTerrorist
    • 22. September 2003 um 19:14
    Zitat von &quot;Tobias&quot;
    Keine ahnung, ob der Peter dieselbe Methode meint, aber ich habe den Knoten von meinem Opa. Der ist also hochseeerprobt geht wirklich kaum ab!!
    1) Man nehme einen Klett-Kabelbinder
    2) Dann wird das gelbe Ende eigentlich falschrum durch die Öse eingefädelt. Das weiche (schwarze) Klettzeugs ist außen, die Gegenseite ist in der Schlaufe.
    3) Das gelbe Ende wird ein zweites Mal durch die Öse rausgezogen (nicht zu weit, sonst löst sich der ganze Kram wieder auf) so dass quasi 2 Schlaufen übrig bleiben
    Dieses Konstrukt wird jetzt über das Kabel gezogen. Sodas das kabel durch die innere schlaufe läuft. (hier symbolisiert durch die schraube...)
    Festziehen und fertig.
    Sorry wegen der schlechten Bildqualität, aber ich hab nur eine ömmelige webcam.....
    Vielleicht fühlt sich ja jemand dazu berufen das noch mal in Schön zu machen
    Natürlich kann man den klett auch direkt montieren und muß das nicht erst hinterher über den 108er Harting ziehen. Das könnte eng werden :)
    ma ne frage dazu:
    wie bekommt man das wieder auf*fg*
    soo habs zwar geschafft.....aber wie geht es schneller??
    habe es mit nem schraubendreher gemacht immer dazwischen und gedrückt...hat 6min gedauert. also doch ziemlich lang. bei nem dünneren kabel hätte ichs eher abgelötet, bzw aufgeschraubt. währe schneller gegangen....
  • Mülltonnen-Bass
    • KlangTerrorist
    • 22. September 2003 um 12:05
    *gg* mal einmischen....
    habe das selber scuh schon aus spass gemacht....
    nen doppel 15er bass aus einer 240l Tonne
    und nen 2*12er + 2er Top, aus einer 120l Tonne
    Sah ganz nett aus und hat auch funktioniert.
    aber naja das Stacken ging dann doch nicht soo gut.
    war einfach zu leicht, und kippte zu schnell.
  • Liverecording mit den Splittern von Thomann !!!!!!
    • KlangTerrorist
    • 21. September 2003 um 20:35
    ich hab den aktiven...
    • KlangTerrorist
    • 21. September 2003 um 09:23
    Habe die Splitter selber.
    Aber halt eher für PA.
    Aber da taugen sie ganz gut.
    Genauso sind sie als Aufholverstärker nicht schlecht.
  • Selbstbautreffen
    • KlangTerrorist
    • 19. September 2003 um 04:47
    ok. ich erkundige mich morgen mal.
  • Selbstbautreffen
    • KlangTerrorist
  • HD 15 -Bau
    • KlangTerrorist
    • 18. September 2003 um 21:41
    war das nicht der esx??
    *fgg*
  • HD 15 -Bau
    • KlangTerrorist
    *fgg*
  • Selbstbautreffen
    • KlangTerrorist
    • 18. September 2003 um 21:28
    muss man kucken. habe 2 hallen zur verfügung. die eine könte ich wahrscheinlich jederzeit haben(leider nicht grade so sauber). und es währen sogar 125a vorhanden.
    die andere würde kosten und es gibt nur einen 32a
    aber das langt ja.
    abklären könnte ich das mal. wenn das mal wegen dem geld geklärt wird.
  7. Suche Lichteffekt
