  4. Biete
Flex Pixel Driver 1 zu verkaufen
  • Christian Ever
  • 30. Juni 2016 um 10:57
  • Christian Ever
    Verkaufe 2 Flex Pixel Driver 1 - SKU# FLE768 - als geprüfte B-Ware
    VB 30,-- EUR
    Eine sehr moderner und guter Led Stripe Treiber.
    Ansteuerung über Dmx.
    Jeder Pixel des angeschlossenen Stripes einzeln ansteuerbar.
    Beschreibung:
    The FLEX PIXEL DRIVER 1 is a professional dedicated DMX driver for LED pixel tapes that supports up to144 pixels / 2 tapes, and up to 432 DMX channels of control. Its small compact design allows for easy mounting and integration into any system. It features an LED control display, separate 3pin terminals for DMX IN and OUT, a 6pin terminal for power IN, and operates on 5VDC.
    FEATURES
    Professional LED Driver for LED-Tape (144 Pixels / 2 Tapes)
    LED Control Display
    CONTROL / CONNECTIONS
    DMX IN via 3pin Terminal
    DMX OUT via 3pin Terminal
    Power IN via 6pin Terminal
    SIZE / WEIGHT
    Length: 3.5” (90mm)
    Width: 1.6” (40mm)
    Height: 0.8” (20mm)
    Weight: 0.12 lbs. (0.055kg)
    APPROVALS
    CE | cETLus
  3. Soundbase vs WWB
  7. Astera AX5 akku refreshen
  8. "Nutzbass"
