wie der Titel schon sagt schwanke ich derzeit zwischen den folgenden Geräten: Showtec Phantom 75 oder Indigo 5500.
Hat jemand Erfahrungen welches Gerät "besser" ist und welches eventuell sogar heller?
Phantom 75
Output
Lux @ 1m: 24.500
Beam Angle: 17°-20° Manual
Light Source: 1 x 75W White LED
Electrical
Input Voltage: 100-240 VAC
Power consumption: 170W max. at full output
LED Drive Current: 16.5A
Control
On-Board: Display for auto, Sound control & Master/Slave
Control Protocol: DMX512
Control Personality: Advanced 14ch /Basic 8ch
Optical system
Dimmer: 0-100%
Strobe: 0-20Hz
Focus: Motorized
Prism: 3-facet prism
Movement
Pan: 540°
Tilt: 270°
Pan/Tilt resolution: 16 bit
Special: Pan / Tilt movement blackout,
User-selectable Pan & Tilt ranges,
540°/360°/180°, Reverse Pan / Tilt movement
Gobos & Color
Gobo: 2 glass + 5 metal gobos (replaceable)
Gobo functions: Gobo-flow effect,Gobo shake
Rotation: Bi-directional
Gobo inner diameter: 20 mm
Gobo outer diameter: 24 mm
Colors: 8 dichroic-filters + white
Color functions: Split colors, Rainbow-flow effect
Physical
Color: Black
Housing: Metal & Flame-retardant plastic
Fixture Connection: XLR Data in/out, IEC Power in
Dimensions (WxDxH): 340 x 248 x 446 mm
Weight: 11 kg
Certification and Safety
Certification: CE
Max. ambient Temp.: 40°C
Indigo 5500
Output
Lumen: 2800+
Lux@2m: 11000+
Efficiency: 40 lm/W
LED Quantity: 7x 10W CW
Driver current: 3A
Focus: Electronic focus
Dimmer: 0-100%
Strobe: 0-20Hz
Prism: Rotating 3-facet prism
Beam Angle: 16°
Gobo1: 7 static Gobos
Gobo2: 6 rotating Gobos
Color1: 7 Colors + White
Pan: 540°
Tilt: 270°
Pan/Tilt Resolution: 8-16 bit
Special: Pan/Tilt movement blackout
User-selectable pan/tilt ranges
Control
On Board: Display for easy Set Up
Options : DMX512, Auto, Manual
DMX personality: 11, 14 Channel
Electrical
Input Voltage: 100~240VAC...50/60Hz
Power consumption: 160W max @FO
Physical
Dimensions (LxWxH): 360 x 270 x 520 mm
Weight: 12,5 kg
IP Rating: IP-20
Housing: Flame-retardant plastic(V0)
Connections: Powercon + XLR 3 pole
Cooling: Forced Cooling (Fan)
