ich interessiere mich für die MSL3 hat jemand technische Daten, Größe, Gewicht, und bis wann wurden sie gebaut.
Hab im Web nix brauchbares gefunden.
http://www.meyersound.com/prod…untinued/msl-3a/index.htm
MSL-3A Reinforcement Loudspeaker
70°H 60°V
21 1/4" wide
56 3/4" tall
30" deep
241 lbs (109.3 kg)
Max SPL (Peak/Cont): 135/130
Freq Range: 75-18 kHz
You can download this product data sheet in Adobe Acrobat format.
Acoustical - MSL-3A/M-3A System
Frequency Response 1 ±4 dB from 75 Hz to 18 kHz
Maximum SPL 2
Continuous 130dB
Peak 135 dB
HF Coverage
Horizontal 70°
Vertical 60°
Acoustical Crossover Frequency 800 Hz
MSL-3A Loudspeaker
Transducers
Low Frequency (2) MS-12 12-inch cone drivers, 8 ohms per driver
High Frequency MS-2001A 2-inch throat (4" diaphragm) driver, 12 ohms
High Frequency Horn 70° modified radial
HF DC Protection 20 µF Polypropylene capacitor
Enclosure Vented, horn loaded, multi-ply Finnish birch
Finish Black textured, charcoal-grey carpet (optional) or black weather protected (optional)
Physical Dimensions 21 1/4" W x 56 3/4" H x 30" D
Weight 241 lbs. (109.3 kg)
Protective Grill Hex perforated metal screen, damped, charcoal-grey foam covering
Connector EP-4 male, EP-5 male (Europe only), Pyle National (optional)
Rigging Aircraft pan fittings, 600 lbs. safe working load each
M-3A Control Electronics Unit
Input Type 3 Balanced ISO-Input™, 10k ohms
Output Type Active, push-pull, 200 ohms output impedance
Maximum Input Level
Balanced +23 dBu
Unbalanced +23 dBu
Maximum Output Level 4
Balanced +26 dBu
Unbalanced +20 dBu
Hum and Noise 5 -90 dBV
Dynamic Range 6 >110 dB
Sense Inputs 10K ohms true differential, opto-isolated
Electrical Crossover Frequency 800 Hz
High Frequency Delay Type Active all-pass
Driver Protection Circuitry
Low Frequency RMS limiter
High Frequency RMS limiter
Indicators
Sense; Hi and Lo Green/Red LEDs
Limit; Hi, Lo and VHF Red LEDs
Safe Green LED
Power Green/Red LEDs
Controls
Front Panel Input attenuator, AC power switch
Preset Panel Lo Cut switch, Safe switch, HF EQ Switch, VHF Var/Cal switch, VHF control
Connectors
Balanced Input/Output 3-pin XLR (A-3) female/male
Sense Inputs Banana jacks
Power 120/240V AC, 50/60 Hz (internally switchable)
Physical Dimensions 19" W x 1 3/4" H x 7 3/4" D, Standard rack mount
Weight 8 lbs. (3.6 kg)
geile box, gabs fast baugleich auch von AudioPerformance als SL II.
meines wissens wurde die produktion irgendwann in den 90ern eingestellt.
Die Audio Performance SL II gibts sogar immer noch neu zu kaufen, auf Anfrage allerdings. Die Box hat so viele Fans, dass die immer noch mit nichts anderem arbeiten möchten (trotz des Gewichtes).
Die Meyer MSL und Audio Performance SL sind identisch bis auf den Hochtontreiber. Die SL klingt noch ein bißchen sanfter und dabei auflösender. Mid driver ist in beiden OEM von Ciare.
