  4. Offenes Brett
Hatelist
  • HMPF
  • 28. August 2004 um 10:05
  • HMPF
    A Live Sound Engineer's Hate List
    1) Lighting guys
    2) Two minute set changes
    3) 104 Volts
    4) Elevators or stairs load-ins
    5) 18 acts, 30 timbales, 12 hours (this is a long story)
    6) Volunteer stage hands
    7) People who sit in front of the PA and then complain that
    it's too loud
    8) Sound companies that don't zero out the console before
    you use it and still has the tape from the last show on your inputs
    9) Companies that say, "Oh yeah, we have a 40-channel console.",
    and when you show up, it's two 20-channel consoles slaved together
    10) From the sound company, "We've got all the best stuff! I
    don't know why it sounds like this... it always sounds great to me!"
    11) Mixing monitors from FOH
    12) System engineers that try to "help" you mix the show
    13) Companies that bring out inadequate gear because they
    bid too low to get the gig
    14) Mix positions in stupid locations
    15) Being short of channels because the headliner won't let you use
    them and there's no additional console for the opening act.
    12 Stupid Sayings From The Audience
    1) "What would happen if I did this?" (With simulation of twisting knobs on console)
    2) "That would look great in my living room!"
    3) "Do you know what ALL those knobs do?"
    4) "Are you the DJ"?
    5) "Where is the talent knob?"
    6) "Can I keep my coat back there?"
    7) "I can't hear the vocals." (From the people in frontof the stage)
    8) "Do you get to the meet the band?"
    9) "What does THIS do?"... as the audience member leans over the board
    10) "Can't you count any higher than two?"
    11) "What would you do if I touched this?"
    12) "It's too loud!" (While sitting in front of the PA)
    "die Anlage sieht aus wie ein plattgefahrenes Ü-Ei"
    "Das Mikro ist kaputt, das pfeift nicht!"
  • Leuchtturm
    • 28. August 2004 um 10:50
    Die Antwort des Lichts:
    Die Hassliste eines Light Operators
    für mitlesende Hands auf deutsch
    1. Dekorationsfirmen, Tontechniker die Lichtler hassen
    2. Umbauten, die länger als 2 Minuten dauern, die Mac's brauchen für die neue Position doch auch nur 1 Sekunde
    3. 16A Schuko
    4. Tore, die für den Truck 10 Zentimeter zu schmall sind
    5. 1 Regisseur, 1 Lied, 65 Lichtstimmungen
    6. Stage Hands, die von vornherein sagen, dass sie eigentlich nur Ton können
    7. Menschen, die sich beschweren, das sie vom Blinder geblendet werden
    8. Verleihfirmen, die von vornherein die doppelte Moving Light Anzahl wegen der nötigen Sparegeräte liefern und auch dann hat man nicht die gewünschte Menge funktionierende Geräte
    9. Alle Pulte die weniger als 1024 Kanäle haben
    10. Aussagen wie: bei uns im Lager hatten die Lampen alle noch die gleiche Helligkeit und Farbtemparatur
    11. Verfolgerfahrer, die vergessen das Funkgerät einzuschalten
    12. Ungeduldige Regisseure, die nicht verstehen, dass die gewünschte Lichtstimmung erstellt werden muss und dies länger als 1 Sekunde dauert.
    13. Schlecht bezahlte Jobs mit zuwenig Equipment, bei denen sich der Auftraggeber danach noch beschwert, das er sich von 24 Parcans mehr Lightshow erwartet hätte!
    14. Das es immer noch keine zugelassenen Siemenslufthaken gibt und an der ultrawichtigen Scheinwerferposition einfach keine Traverse läuft.
    15. Nicht einsetzbare Moving Lights, weil der planende Kollege sich beim DMX-Kanalbedarf verrechnet hat.
    Das Licht am Ende des Tunnels ist auf Kanal 218-232!
  • Jeremy
    • 28. August 2004 um 12:24
    Die Liste aus der Sicht des Stage Managers:
    1. Von der Band bestellte Fender Rhodes in 440Hz, die dann durch das unangemeldet mitgebrachte eigenen Rhodes in 443Hz ersetzt werden, worauf es natürlich nicht mehr zum Flügel passt ...
    2. Cellospielerinnen, die ein Ampeg 8x10"-Stack verlangen, damit sie sich gegen den Kontrabass (der in einen GK MB150 spielt) auch richtig durchsetzen können ...
    3. All-Star-Tour-Besetzungen, die während des vereinbarten 20-Minuten-Linechecks anfangen, die neuesten Stücke zu proben (Ansage des Toners dazu: "Ich glaube, jetzt duzen sie sich endlich ...")
    4. Pianistinnen, denen nach dem Soundcheck am Vormittag einfällt, dass sie gegen den Teppich auf der Bühne allergisch sind, so dass auf die Schnelle ein paar Quadratmeter Laminatboden unter den Flügel verlegt werden müssen ...
    5. Gaststars, die lt. Vertrag an dem einen Flughafen direkt am Rollfeld mit einer Stretchlimousine abgeholt werden wollen (was ja organisatorisch nicht ganz trivial ist), dann aber unangemeldet an einem anderen Flughafen landen und sich weigern, das Flugzeug zu verlassen ...
    6. Pianistinnen, die, nachdem wegen der Teppichbodenallergie ein Laminatboden unter den Flügel gelegt wurde, beim Auftritt feststellen, dass sie jetzt pötzlich gegen das Leder der Pianobank allergisch sind ...
    7. Orangegekleidete Krishna-Jünger, die bei einem Zeltfestival während der leisen und besinnlichen Stellen auf der Bühne plötzlich trommelnd und schellend um das Zelt ziehen ...
    8. Veranstalter und Promoter, die sich ohne zu fragen am "After-Work-Grappa" bedienen ...
    9. Schlagzeuger, die das Drumset beim Soundcheck nur akzeptieren, wenn alle Schrauben an der Hardware genau parallel ausgerichtet sind, beim Auftritt aber als erstes überall rumschrauben ...
    10. Veranstalter, die eine aktualisierte Bühnenanweisung zurückhalten, weil sie keinen Unterschied zu der alten erkennen ...
    Jeremy
  • MonoTon
    • 28. August 2004 um 18:32
    Ochje, von solchen Listen gibt's doch schon etliche (nur eben deutlich besser) hier im Forum.
    Könnte bitte jemand die Pointen für mich markieren? Kann wieder mal nix finden... :wink:
    Halloooooooooo, wir sind hier im Jokes-Brett - das ist die Rubrik für LUSTIGE Sachen :roll:
    Nix für ungut...
    Elvis ist auch nicht an einem Tag gestorben worden.
  • HMPF
    • 29. August 2004 um 16:26
    Naja, ob das jetzt lustig oder traurig ist, darüber kann man vielleicht streiten. Aber dennoch halte ich das im Jokes Brett für gut aufgehoben.
  1. Soundbase vs WWB
  5. Astera AX5 akku refreshen
  6. "Nutzbass"
  10. HK Audio Polar 15
