Suche Datenblatt BMS 4549 - 8 OEM
  • montarbo
  • 18. Mai 2010 um 00:41
  • montarbo
    Hallo
    hat jemand noch ein Datenblatt vom BMS 4549 OEM in 8Ohm herumliegen?
    Danke schon mal
    ceterum censeo functionum unum esse utendum
    Im übrigen bin ich der Meinung, dass Funktion One verwendet werden muss.
  • Jobsti
    • 18. Mai 2010 um 01:59
    Ne PDF habe ich leider nicht, aber Daten:
    1" HIGH FREQUENCY COMPRESSION DRIVER
    · 113 dB sensitivity 1W / 1m
    · 1 kHz Crossover
    · Extended high frequency
    · response up to 20 kHz
    · Small size and low weight
    · 44,4 mm voice coil
    BMS 4549 Plus is a powerful 1" professional
    compression driver that deliver outstanding sonic
    quality in a small package. It has an exceptional
    dynamic range and produces even the most
    complex music signals with depth and definition.
    The BMS exclusive voice coil technology employs
    a light weigh Cooper Clad Aluminium wire wound
    inside and outside of the Kapton former to improve
    the heat dissipation, dramatically increasing the
    acoustic output and reliability of the driver while
    minimises the power compression.
    The BMS 4549 Plus - 1" compression driver is
    compatible to the older 4549 model offering more
    linear frequency response and greater reliability.
    It was designed for a wide variety of applications
    in high quality, high power professional
    reinforcement systems and for replacing the 4548
    model in existing systems.
    BMS Elektronik GmbH - Germany
    Specifications
    Throat diameter 1" (25,4 mm)
    Nominal impedance 8 or 16 Ohm
    Power capacity (RMS) 80 W
    Peak power 450 W
    Sensitivity:
    CD Horn 90°x75°, 1W/1m 112 dB
    Plane wave tube, 1mW 117 dB
    Maximal SPL (continuous) 131 dB @ 80 W
    Frequency range 500 - 20.000 Hz
    Recommended crossover 1.000 Hz
    Voice coil diameter 1,75" (44,4 mm)
    Magnet material Ceramic
    Flux density 1,9 T
    Voice coil material Cooper Clad Aluminium
    Voice coil former Kapton
    Diaphragm material Polyester
    Mounting information
    Overall Diameter 123 mm
    Depth 52 mm
    Net weight 0,83 kg
    Two M6 holes, 180° on 76,2 mm diameter
    Vielleicht hat ja noch jemand die Messungen, ggf. auch mit gewünschtem Horn für dich.
    Mit freundlichen Grüßen
  • Wolfgang
    • 1. Juni 2010 um 02:16
    hi montarbo,
    was Du suchst, steht auf http://www.prodance.cz/protokoly/BMS_4549_PLUS+A7570.pdf .
    das ist dann das h100...
    gruss wolfgang
  • Enno Gieske
    • 2. Juni 2010 um 11:09
    Ich könnte eine Messung mit dem AH LH290F anbieten. Jedoch schon mit Weiche und TT.
  6. Impedanz Messgerät
