  4. Lichttechnik & Effekte
Showtec Phantom 75 oder Indigo 5500
  • Techno
  • 5. Januar 2014 um 00:15
  • Techno
    wie der Titel schon sagt schwanke ich derzeit zwischen den folgenden Geräten: Showtec Phantom 75 oder Indigo 5500.
    Hat jemand Erfahrungen welches Gerät "besser" ist und welches eventuell sogar heller?
    Phantom 75
    Output
    Lux @ 1m: 24.500
    Beam Angle: 17°-20° Manual
    Light Source: 1 x 75W White LED
    Electrical
    Input Voltage: 100-240 VAC
    Power consumption: 170W max. at full output
    LED Drive Current: 16.5A
    Control
    On-Board: Display for auto, Sound control & Master/Slave
    Control Protocol: DMX512
    Control Personality: Advanced 14ch /Basic 8ch
    Optical system
    Dimmer: 0-100%
    Strobe: 0-20Hz
    Focus: Motorized
    Prism: 3-facet prism
    Movement
    Pan: 540°
    Tilt: 270°
    Pan/Tilt resolution: 16 bit
    Special: Pan / Tilt movement blackout,
    User-selectable Pan & Tilt ranges,
    540°/360°/180°, Reverse Pan / Tilt movement
    Gobos & Color
    Gobo: 2 glass + 5 metal gobos (replaceable)
    Gobo functions: Gobo-flow effect,Gobo shake
    Rotation: Bi-directional
    Gobo inner diameter: 20 mm
    Gobo outer diameter: 24 mm
    Colors: 8 dichroic-filters + white
    Color functions: Split colors, Rainbow-flow effect
    Physical
    Color: Black
    Housing: Metal & Flame-retardant plastic
    Fixture Connection: XLR Data in/out, IEC Power in
    Dimensions (WxDxH): 340 x 248 x 446 mm
    Weight: 11 kg
    Certification and Safety
    Certification: CE
    Max. ambient Temp.: 40°C
    Indigo 5500
    Output
    Lumen: 2800+
    Lux@2m: 11000+
    Efficiency: 40 lm/W
    LED Quantity: 7x 10W CW
    Driver current: 3A
    Focus: Electronic focus
    Dimmer: 0-100%
    Strobe: 0-20Hz
    Prism: Rotating 3-facet prism
    Beam Angle: 16°
    Gobo1: 7 static Gobos
    Gobo2: 6 rotating Gobos
    Color1: 7 Colors + White
    Pan: 540°
    Tilt: 270°
    Pan/Tilt Resolution: 8-16 bit
    Special: Pan/Tilt movement blackout
    User-selectable pan/tilt ranges
    Control
    On Board: Display for easy Set Up
    Options : DMX512, Auto, Manual
    DMX personality: 11, 14 Channel
    Electrical
    Input Voltage: 100~240VAC...50/60Hz
    Power consumption: 160W max @FO
    Physical
    Dimensions (LxWxH): 360 x 270 x 520 mm
    Weight: 12,5 kg
    IP Rating: IP-20
    Housing: Flame-retardant plastic(V0)
    Connections: Powercon + XLR 3 pole
    Cooling: Forced Cooling (Fan)
  • Rem
    • 7. Januar 2014 um 23:45
    Phantom 75 !
    Geniales Gerät. Soweit ich weis wird die Indigo Serie auch nicht weiterentwickelt, womit die Antwort einfach ist.
    M.f.G.
  • Geisi1909
    • 8. Januar 2014 um 03:00
    Wenn man auf den motorischen Fokus verzichten kann, und der Movinghead kleiner sein kann, dann bitte Phantom 50 nehmen, die sind nur unwesentlich dunkler.
  • Nordemil
    • 8. Januar 2014 um 07:50
    Jup hatte mich auch für den Phantom 50 entschieden, kleiner, schneller, Lichtoutput nicht viel schlechter, vom Preis bekommt man quais 3stk 50er oder 2 75er!
    Das Video kennst du berstimmt!
    http://www.youtube.com/watch?v=cEKGWwg2Bus
  • Techno
    • 10. Januar 2014 um 20:01
    Super erstmal danke für die Antworten.
    Jetzt bin ich heute im Internet über ein weiteres Gerät "gestolpert" ein 120 Watt LED Moving Head von Flash. Hat jemand Erfahrungen mit dem Teil? Oder kennt den Moving Head überhaupt jemand? :roll:
  • Dino_1984
    • 26. Januar 2014 um 20:35
    Flash ist eine Eigenmarke von elcotec.
    Aktuell
    10% Rabatt auf den Pioneer DDJ-SX (Gutscheincode: Neujahrsangebot)
    http://www.DeeJay-House.de
  • cdt.sound
    • 27. Januar 2014 um 17:40
    Das ist so nicht richtig. Flash ist ein polnischer Importeur für chinesische Lichttechnik. So wie Steinigke in Deutschland, nur deutlich kleiner.
    Da kann jeder, der einen Gewerbeschein hat, rüber fahren und einkaufen.
  3. Soundbase vs WWB
  7. Astera AX5 akku refreshen
  8. "Nutzbass"
