  2. tthorsten
Beiträge von tthorsten
  • passender Hochtöner/Trennfrequenz
    • tthorsten
    • 10. November 2002 um 11:40
    warum sind die leute immer anonym und habne keine ahnung, ???
    dann bu ich keine PA box sondern eher ne Hifi sachen oder was fürs auto.
    • tthorsten
    • tthorsten
    • 10. November 2002 um 11:31
    bitte dann drei hochtöner nehemn kannste dann auch tiefer trennen .
    und so eine schlechtere qualität ein bauen.
    aber odbs das wirklich bringt ???
    • tthorsten
  • Concaves linearray bei Prosound web LAB forum
    • tthorsten
    • 10. November 2002 um 11:15
    und hier mal der Dialog
    Last time i saw the pictures of CLA it looked just like high stack of boxes - nothing fancy. 8 high vertical stack of MT-4H makes 32 HF horns ribbon (with gaps and spaces between...).
    von Chirs dem entwickler
    can help you there. The MT4 concave array was configured by me in 1994. The first time it was flown was at the NEC Arena, Birmingham during an evaluation and comparison of a V-dosc system that Christian Heil had brought over to the UK for demonstration.
    I proposed my concave configuration to Mick Hughes for a tour (that I can't name because the Live-Audio Board automatic censor throws it out - it was the Black Album tour though..) in 1995 and we rigged it using dB Sound MT4 at Albany, New York in the spring of 1995.
    The finest hour for the concave MT4 array was probably Castle Donington Monsters of Rock in the UK in August 1995.
    The key to using MT4 in this configuration was the replacement of the 2 x HP64 horns and manifolds with 4 x HP42 units, each with a DH2A compression driver, to increase the array density in the vertical axis and give some reasonable geometry in the horizontal. It was a line array, or rather three line arrays configured concave in the horizontal, but true line source it was not of course. It worked very well in the vertical axis, especially outdoors, and had only moderate problems off-axis horizontally where the HF column was separated by the midrange (on the other face the horns were adjacent and coupled very well).
    You might be be surprised, but the fact that the system was large had one serious advantage. The low-mid and bass directivity control in the horizontal was excellent and much better than the antennae-like low-mid directivity of the current line array designs. Everyone has been concentrating on HF waveguides however the solution to the mid-bass directivity will be the line array holy grail of the next couple of years - you wait and see!
    I hold a patent on concave array devices that came from work I did following the MT4 experiments and continue to develop the idea from time to time. I think dB Sound have made a few claims to have 'invented' the concave arrays but if you want to verify the truth you should ask Christian Heil or Big Mick Hughes.
    It's important to remember that sound waves at concert levels (ignoring HF horn throats) baheave in a linear fashion. If the directivity control of the boxes is good (and a large box like the MT4 has this) the only serious intereference between the boxes is right in the focal point region near the array. Because the sound waves from each box are not modulated by the other, the coverage in the far field (in the frequency range range of pattern control) is going to be similar to the boxes in a convex setting set at the geometrically equivalent splay angles.
    The advantage, as Chris put nicely, is that you increase the density of the drive elements of the boxes, which was the desired effect for this situation.
    It's not ideal, but presents and interesting solution for what was at hand.
    It doesn't eliminate lobing in fact. All I was seeking to do was overcome the array density problems of arraying MT4 where the box size was so great that, by the time the cabinets are articulated from the rear in the 'normal' convex configurations the horn elements are so far apart that the inter-cabinet interference is horrendous.
    The more interresting subject is that of using 3 axis concave arrays to generate coherent point sources. This requires that the elements are relatively small - I have a 16 element model with excellent directivity from 400Hz - 3kHz. The notable characteristic is that the output can be steered by introducing very small amplitude tapering across the elements of the array. By small I mean less than 1dB overall can produce 10deg of beam steering and the output remains coherent in band throughout. The HF resolution is proportional to the diameter and directivity of each element however the lower frequency control is a product of the sum of the elements of course. The key is the geometry is that the origin of the array lies at the focus in 'real' space (where there is energy) as opposed to theoretical (where there is not) in the case of a convex array.
    The original idea came from a review of multicell horns and the limitations in terms of space for compression drivers. I reasoned that one could invert the geometry with the same overall result and have all tthe space in the world to mount as many drivers as one wished. The steering ideas developed from that.
    Now that line arrays are fairly well understood I think it might be interesting to pursue these ideas for high power single point source devices that would be more suitable for smaller venues and which might be steered or reconfigured in software to suit venue occupancy.
    I also think that, using digital matrices one might have variable directivity for different sources - one might for example configure a signal to be directive to the audience and a secondary artefact at lower level to stimulate a degree of room reverberation
    • tthorsten
    • 10. November 2002 um 11:11
    komme übrigens nun auch über die hauptseite da rein .
    komisces windoof.
    nun ja es sieht so aus, wie wennn DBsound
    die boxen mit 4x40x20 grad hornern aus gestattet hätten, dann hängne die noch horn zu horn zumindest zwischen dem innneren und einem äusseren stack funktioniert das ja.
    bei 40 grad winkel auf einander zu kommt es zu einem Beam .
    die zweite reihe kommt ja nun nicht mit den hörnenr zusammen zielt aber eher auf den neu entstandenen quellen punkt.
    das tut schon irgendwie .
    kommt bestimmt brutal.
    wenn man nun die Ansteuereung der Boxen ändert muss mannja die abstrahlcharteristik in gewissen grenzen verändern können.
    im low mid koppelt das an ohne ende .
    dann nch zwei reiehen bässe neben einander gehängt das kommt bestimmt brutal.
    Das könnt mann aber auch doch mit einem assymetrischen line arry mahen, um noch mehr richt wirkung und spl zu bekommen.
    prinzipkell auch mit nem symetriscehn.
  • Forumstreffen im Dezember. 21-26.12.02 in Sindelfingen schl
    • tthorsten
    • 10. November 2002 um 10:46
    Inselgert
    so ein mist jetzt macht der hier ne konkurrenz VA auf.
    kommt ihr auch in dne wilden süden ??
  • Forums Large size URPS
    • tthorsten
    • 10. November 2002 um 10:24
    ESX mahct aus BR momentan das beste
    was geht. - finde ich
  • Forums Midsize Urps
    • tthorsten
    • 10. November 2002 um 10:22
    vergesst es doch einfach mal
    eure andere projekte in threads zu plzieren.
    was will ich hier mit 18" kram ???
    oder mit Licht zeugs ?????
    ich wollte was konkretes haben und ihr boykottierts.
    ich finde 18" auch käse.
    Die 6x12" variante V6 genannt von D&B zur B2 war echt gut leider teuer und dem Kunden schwer zu verkaufen auch vom Handling her.
    meine suche nach dem besten hat sich in dem segment erledigt. - ich hab meine wunsch box gefunden.
    Andere im Forum suchen immer noch .
    KurzHörner finde ich nicht so prickelnd
    Also bleibt als alternative nur was gescheites ein EAW 940
    oder halt nen URPS
    aber ohne Konkrete vorgaben ist das stochern im Nebel.
    Gehäuse und entzerrung ist relativ klar.
    Urps Chassis eigentilich auch nur noch ein zwie konkrete empfehlungen fehlen mir.
    Nehmen wir ein BR Kistnen Projekt
    ich gebe da vor billig soll er sein Cahssis so ca. 150€ uhd so 80-150l soll das haben . bis 40hz sollte es auch gehen.
    da kann mann den Kappa 15LF oder nen 18soudn 18lw700 als chassis empfehlen.
    Bzw. leihe ich mir ne box wo das verbaut ist aus und schaue ob mir der sound gefällt.
    Warum kann mann das nicht beim urps machen
    ist das so schwer männer.
    Ihr habt ja nicht mal den courrage zu sagen, wo mann das wunder ding bestaunen kann.
    Ich fahre da dann auch nach München oder Hamburg wenn es sein muss.
    am 25.11 bin ich in Hannover mit einem teil des Forums so wie t ist es nach Hammburg auch nicht kann mann daann das Teil mal anhören ??
    Wir helfen auch beim aufbau. und spendieren das Bier.
    TBF die Boxer idee war ne idee ob das geht und wie die anordnung sein soll oder könnte.
    hab ich wieder verworfen aber der Spanplatten PROTO wird wohl auch in der variante gebaut werden.
    Die Cahssis müssen wohl echt alle plan auf der schallwand sitzen.
    ergo ultra flaches gehäuse.
    auch wurst stellen wir das halt vor die Bühne trägt kaum auf und drückt bzw shceibt ordentlich.
    Aber das topteil sollte dadurch schon bis 80hz können damit die Wings nicht Kalt klingen.
    Deshalb auch die geforderten kickhörner.
    Da ich immer alles versuche anzuhören und zu testen, bevor ich es baue oder kaufe
    werde ic das beim urps auch weiter hin versuchen . so viel info wie möglich zu bekommen.
  • Production Partner Test "Nexo Geo" Line Array
    • tthorsten
    • 9. November 2002 um 23:00
    die shaolin mönche sind in usa auch mit geo unterwegs evtl in eouropa auch.
  • Wievel Line Array braucht der Markt ?????
    • tthorsten
    • 9. November 2002 um 22:49
    endlich kann ich mal mit wellen front einr meinug sein
    6-10" klingt gut in den mitten
    EAW 853 ein geiles system 2x10" 2x2"
    Turbosound Flaschligth 6" und 1"
    Vdosc 4x7" einfach klasse
    Xline 2x8" super.
    Martin W8l geil
    alles andere nunja
    und zum bass.
    nun ja 12" ist nur konsequent für nen Bass Horn als treiber warum mann das vorher nicht gemacht hat keine ahnung.
    18" ist halt kostne günstig und HLA und ESX sind die besten am markt.
    • tthorsten
    • 9. November 2002 um 22:34
    jetzt hab ich es eher zufälli selbst gefunden.
    http://www.dbsound.com/SysCLA.htm
    • tthorsten
    • 9. November 2002 um 22:08
    eines aus dem highendbereich
    <font size=-1>[ Diese Nachricht wurde geändert von: tthorsten am 2002-11-09 22:19 ]</font>
  • ESX Simulation und Funktionsprinzip
    • tthorsten
    • 9. November 2002 um 22:01
    lies doch martins posting.
    ist ne mischung aus beidem
    da müsst ihr sochn selber drauf kommen.
    ist wei beim urps nur das mann über den treiber nicht rum rätseln muss.
    • tthorsten
    • tthorsten
    • 9. November 2002 um 21:56
    und noch ein linearray
    http://www.segconsulting.com/English/L-TEX75.htm
    • tthorsten
    • 9. November 2002 um 21:48
    bilder vom xline
    http://www.electricaudio.nl/produktinfo/CLA.html
  • Meyer MSW Bass und M3D
    • tthorsten
    • 9. November 2002 um 21:02
    hier von Rock am Ring ein paar Bilder
    http://rock-am-ring.stage-access.com/rar2001/rar_re…ort_alt_pa.html
    • tthorsten
    • tthorsten
    • 9. November 2002 um 20:23
    he ich hab nur ne anregung auf genommen und will jetzt was konstruktives haben.
    chassis empfehlung gehäuse also eine art labhorn projekt.
    meine chassis empfehlungen könnt ihr ja alle nach lesen.
    bassking67
    23. Oktober 2026 um 19:32
  2. Jenische Musik
    Herr Nink
    22. Oktober 2026 um 17:47
    Pyrotechniker
    21. Oktober 2026 um 16:45
    Silv
    21. Oktober 2026 um 09:05
  6. 20 bis 20KHz Eigenbau
