Nagelneuer Amp aus England
2 x 3.500 W
Frequency Response (±3dB ref 1kHz):8Hz – 24kHz
Signal to Noise Ratio (ref full power, 1kHz):102dB
THD (1kHz, full power):0.07%
THD (20Hz - 20kHz, full power):<0.1%
Slew Rate:69V/μs
Damping Factor (ref. 8R, 100Hz):>650
Cooling (Temperature Controlled Dual Speed Fan):2x 80mm Fan + 60mm internal fan
Cooling Direction:Front to Back
Dimensions, mm:482 x 88 x 400
Weight:9.0kg
