  5. Konzert-Sound Praxis
Submeeting in the Netherlands
  • davy gabriels
  • 23. November 2004 um 07:51
  • davy gabriels
    Last weekend we had a submeeting in the netherlands
    Pics:
    http://www.ovmsales.nl/imagine/forumtroep/sub/submeeting.htm
    http://www.vitality-show.nl/fotoboek/album31
    http://fossalta.xs4all.nl/powerbass/img/New-line/Submeeting/
    http://fossalta.xs4all.nl/powerbass/Submeeting.wmv
    Used:
    8* 18S BR118 LW1300
    4* 18S BR118 LW1400
    4* BR18 B&C 18 PZB 46
    2* DIY 2* 15" Beyma SM115
    5* Punisher Horn (Ciare 12.00)
    2* LabHorn
    1* M-Horn (empty)
    1* Meyer 700HP
    3* Meyer USW
    2* Meyer UPA
    Plots:
    http://www.lucas-nicolas.easynet.be/submeeting/TL.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/USW.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/700HP.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/Lab.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/18LW1400.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/B&CPZB46.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/18LW1300.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/Punisher.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/2Punisher.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/1vs2Punisher.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/1vs4Punisher.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/2x18LW1300.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/2x18LW1400.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/2xB&CPZB46.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/2x18LW1400BUX.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/2x18LW1400PL4.JPG
    http://www.lucas-nicolas.easynet.be/submeeting/PL4vsBUX1400.JPG
    If you speak a little bit dutch you can follow on the forum:
    http://forum.licht-geluid.nl/forum/topic.asp?TOPIC_ID=12365&whichpage=1
    greetings from belgium
    PS: if you see T-amps on the pics, they are mine :D (together with the 8x 18s BR118 18W1300)
    PS: you can answer me in german, I understand fully only the writing of german is a little bit difficult but I can try!
  • Mnyut
    • 23. November 2004 um 11:13
    wie sind die Punisher Hörner so? Sind 2 Stück pro Seite schon ausreichend?
    Mit wie vielen Boxen wurde die Messung gemacht?
    Einmal editiert, zuletzt von Mnyut (28. April 2007 um 17:19)
  • davy gabriels
    • 23. November 2004 um 11:32
    Ich denke (bin nicht ganz sicher) das ist 1 Punisher. Also nicht viel druck unter 60Hz.
  • Mnyut
    • 23. November 2004 um 15:29
    Bauplan Punisher Horn: http://www.speakerstore.nl/index.php?show=tekening&constructieID=21
    Da steht im Bauplan was von 50-200 Hz und im Text kann man was von 140dB bei 2 Stück pro Seite erahnen.
    Wenn das wirklich mit 2 Stück pro Seite schon funktionieren würde (abfall ab 50 Hz) währe das klasse.
    Vielleicht kannst du ja mal den Besitzer der Bässe fragen. Kann leider kein niederländisch.
    Danke
  • davy gabriels
    • 23. November 2004 um 15:34
    das ist der Plot von 2x punisher pro Seite.(kannst du auch sehen in der Link: ....2Punisher.JPG)
  • Mnyut
    • 23. November 2004 um 15:51
    OK, alles klar. Danke :D
    Hab ich übersehen.
  • pm-acustics
    • 24. November 2004 um 09:30
    Moin, der hier altbekannte Tthorsten hat mich gebeten hier in seinen Namen was zu der Sache zu posten:
    Immer wieder kommt ja die Frage auf Horn oder BR
    Hörner werden oft als weittragender und lauter empfunden und titiuliert
    - es geht karasser ab.
    zu meist muss das gute alte HD 15 ( trubosund TSM3) hier als parade beispiel her hatlen.
    hier ein link dazu.
    http://speakerplans.com/page12.html
    HD 15 ist für mich ein Töck generator, da unter 60hz kaum was geht.
    das ist eine viertel raum mit kappa 15lf simulation und der DOOMM bestätigt dies in seinem bilderbericht auch noch.
    Nun gibt es die Steigerung des selben das Punisher Horn
    kein Töck -generator mehr nein ein Tick -generator.
    Im forum ein link zu einem Niederländischen vergleich .
    von selbstbaukonstrukten.
    http://www.paforum.de/phpBB/viewtopic.php?t=30266
    und vorallem zeigen die Messungen was ich schon immer sage.
    Horn bässe sind Töck generatoren. mann bekommt immer mehr töck hin zu und der bumms bleibt auf der strecke.
    die 1-4 punischer honr messungen zeigen das deutlichst.
    der töck nimmt zu etwas tiefe gewinnt es
    aber im vergleich zu einer BR box hoffnungslos leise.
    oben rum nimmt es mit der menge auch ab an Schalldruck und oberer grenz freuenz und sound qualität und ich muss so um die 80- 120 hz trennen und das zumeist eher flach als steil flankig um die anpassung ans top besser hin zu bekommen. bzw die unnütze ernergie um 100 bis 200hz zu eliminieren.
    was bleibt übrig der berühmte töck hügel. der sich zwischen 65 und 90hz bewegt. ich nutze also vom ach so breit bandigen horn nur eine halbe oktave.
    Amen :D
    Grüßle
    Sven
  • Mnyut
    • 24. November 2004 um 10:01
    vs.
    Hab hier mal die Messungen von 2xTick- und 2xBooom-Generator übereinander gelegt und den Gain angepasst:
    (hab ich das so richtig gemacht?)
    Wieviel Hz macht das Punisher Horn weniger tief? 6, 7, 8 Hz? Dafür ist kein fetter Einbruch im Töckbereich :)
    Wer von den beiden lauter kann man ja wohl so nicht sagen weil ich ja nicht weiß wie gemessen wurde.
  • pm-acustics
    • 24. November 2004 um 10:29
    @Mynut:
    Ich sehe das ähnlich, ich habe auch beide mal übereinander gelegt !
    Sehr schön ist der Einbruch beim 2x18" aufgrund der fehlenden Resonatorunterstützung >63Hz zu erkennen.
    Ich denke mit etwas Eqing währe auch noch der minimale Nachteil im Tiefsbassbereich auszugleichen.
    Schön wäre zu wissen ob die Messungen unter richtig Last entstanden sind oder bei Kurortpegel.....
    Ich denke so ein entzerrter 4er Stack könnte recht nett sein.. nur so richtig skallierbar ist es nicht....wo man wieder beim Singel 18"ler wären
    Grüßle
    Sven
  • Mnyut
    • 24. November 2004 um 12:11
    Wie fehlenden Resonatorunterstützung ? Ich dachte das nennt sich "Raumeinflüsse" :D
  • text&ton
    • 24. November 2004 um 12:34
    Thorsten, ich hatte vor kurzem wieder das Vergnügen, 12 EAW BH760 zu hören.
    Glaube mir, das macht nicht töck.
    Und tick auch nicht.
  • pm-acustics
    • 24. November 2004 um 12:57
    Ach so stimmt, ich vergass das man das so nennt.........die Lösung:
    Man nimmt den 4x15" in ein Gehäuse und stimmt jede Kammer unterschiedlich ab (40,50,60,70 Hz) und weg sind die Raumeinfüsse.....gröhhhhhhllllllll. :D
    Grüßle
    Sven
  • Wellenfront
    • 24. November 2004 um 13:21
    12xBH760 machen weder Tick noch Töck,und die "Raumeinflüsse" sind auch plötzlich wech.....
    Merkwürdig aber auch..... :wink:
    • 25. November 2004 um 14:59
    habt ihr da eine qsc pl4 gegen eine bux gemessen? welcher amp hat denn welche farbe? welcher klang nach mehr rrrummmmsss 8)
  • AlphaC
    • 25. November 2004 um 15:07
    Mal wieder das Thema Bass... und mal wieder so viel Sinn und Unsinn dicht beieinander....
    Die Photos & das Video zeigen eine große Garage oder sowas ähnliches. Die akustischen Bedingungen sind in jedem Fall ungünstig, erst recht bei tiefen Frequenzen (draußen war's wohl zu kalt, gelle?). Das Messmikrofon liegt (!) ungedämpft auf einer Stufe einer Aluminium-Leiter (!!!). Klar. Wenn die Halle bebt - die leichte Blechleiter wird garantiert keine Schwingungen auf das Mikrofon übertragen... (HILFEEEE!).
    Der Messabstand ist unbekannt (warscheinlich "rund" 1 m). Die Messhöhe ebenfalls unbekannt - geschätzte 20-25cm (auch Unsinn, weil tiefe Frequenzen misst man 1. in größerem Abstand und 2. zu ebener Erde, um Laufzeit-/phasenprobleme zu eliminieren). Wenn man schon versuchen will in so einer Halle tiefe Frequenzen zu messen, sollte man wenigstens 20 Messungen in möglichst verschiedenen Winkeln, Entfernungen und Positionen der Box machen und dann MITTELN. Gerade in so einer "Garage" kann man bei der Verschiebung des Messmikros und/oder des Subwoofers von nur ein paar Zentimetern völlig andere Frequenzgänge messen!
    Die Messungen haben allesamt KEINE Aussagekraft. Lediglich eine TENDENZ lässt sich erkennen, nämlich dass die (vor Ort befindlichen!) BR echten Tiefbass können und die (vor Ort befindlichen!) Hörner nicht.
    Alle BR-Hasser will ich hier mal fragen, wieso der F-Gang ZWEIER gestackter LW1400 BR einen deutlichen Einbruch im Punch-Bereich hat... EIN EINZELNER aber nicht??? Ist nach eurer Logik leider nicht wirklich erklärbar...
    Außerdem:
    Die Subs können kaum bei SPLmax gemessen worden sein, denn das benutzte Behringer Microfon verträgt (wie die meisten anderen Messmicros auch) nur 130dB... würde also bereits bei einem einzelnen, gescheit geampten Subwoofer längst zerren... Dass also die Subs während der Messung "am Ende" gewesen sind, ist höchst unwarscheinlich...
    Der den Production Partner Lesern bekannte Einbruch der SPLmax Kurve im Punchbereich (den einige wenige, sehr tief abgestimmte BRs wie z.B. der EAW SB750 auch tatsächlich aufweisen) bezieht sich lediglich auf die 10% THD Linie!!!!!!!!! Ein solcher Subwoofer spielt aber sehr wohl ohne Einbruch des tatsächlich wiedergegebenen SPL, nur verzerrt er halt mehr! Der Klirranteil wurde bei den hier publizierten "Messungen" aber überhaupt nicht beachtet oder gar bewertet!
    freundlich grüßt,
    Alex
    PS @pm-acoustics & Mnyut: Bei einem auf über 40Hz getunten BR kann von "fehlender Resonatorunterstützung" keine Rede mehr sein. Der Resonator spielt insgesamt etwa eine Oktave breit (-6dB), und bedämpft damit das Chassis soweit, dass es selbst bei RMS*2-Amping NIEMALS den Xmax erreicht! Der Einbruch ist somit leider NICHT erklärbar...
  • TBF
    • 25. November 2004 um 15:21
    ich habe Dich ja immer fürrecht kompetent gehalten ....
    öhm Lernresistenz?
    Tipp: membranbealstung, Energieabgabe, kont. max. pegel im nutzbassbereich
  • AlphaC
    • 25. November 2004 um 15:37
    TBF:
    Lernresistenz
    Nö. Faktenbezug.
    nutzbassbereich
    für mich zählen 40Hz dazu. ich nutze sie jeden tag.
    Im übrigen: Ich hab nix gegen Hörner! Allerdings mag ich sie nur, wenn sie in Rudeln auftreten und gescheit (kompromisslos) gebaut sind (siehe EAW).
  • TBF
    • 25. November 2004 um 17:08
    der bass speitl aber wo anderst wenns unten rumblubbert geht das singel im stack verpackens aber die pappen nimmer - einbruch klirr membrankompression "raumeinflüsse" *G* interessant ist wenn ein bass nciht funzt sinds immer raumeinflüsse damit kämpfe ich zujmidnest immer am wenigsten
  • davy gabriels
    • 25. November 2004 um 22:06
    First at all, we had not the intention to measure at all. It was the first time we came together to listen to different types of bass (we saw that german people did it a lot to get together and was always very interesting :D ).
    So someone had taken a measurement system, mostly to make comparison between basreflex and horn enclosures. Purpose was not to make exact max SPL measurements etc... ok?
    We are already planning a new meeting (when it's a little bit warmer brrrrrr) and then do thing in a more structured way.
  • Seven
    • 25. November 2004 um 23:26
    Finde es net und interessant das jemand der Allgemeinheit seine Messungen zur Verfügung stellt. Weniger nett finde ich es, dass jemand aufgrund der Tatsache fast "auseinandergenommen" wird.
    Das muss echt nicht sein. Ob der Test jetzt "gut","richtig" oder eben nicht durchgeführt wurde, interessiert eher sekundär. Wenn einer die Meinung hat, dann soll er den Test nicht so ernst nehmen (für sich).
    Wäre schade, wenn aufgrund mancher Aussagen hier im Forum, künftig solche Ergebnisse nicht mehr gepostet werden würden.
