linearry Deschs MLA
  • 7. Januar 2003 um 22:34
    http://www.desch-audio.com/mla.htm
    was halten denn die experten von dem system hier ???
    Concept:
    The MLA "Modular Line Array" in ist present form has been developed in the mid -1990s and is still being tested. The development of the MLA loudspeaker system was mostly triggered by the growing demand of P.A. Systems in the expanding area of sporting and other major events. Out of logistical reasons organisers and clients as well began to ask for a centralisation of the sound sources.
    The MLA loudspeaker system comprises two elements with indentical measurements so far, a MH high-focus element for mid and high frequency and an external bass element to create external subarrays.
    Because highly efficient modular components are used we get a Line Array, which has optimum coupling features in the transmission range of 120Hz-16KHz. For the first time the MLA was fitted with ribbon compact drivers for the electroacoustical transmission of the hight frequency range. Unlike the compression drivers the ribbon compact drivers ´array and combination produce a line source. The acoustical coupling features of the MLA "Modular Line Array" have been demonstrated at open air events with significant range.
    Handling / rigging:
    When the MLA loudspeaker system was developed, great emphasis was place on the size and volume of the individual elements. With the standard measurements of 1160 x 470 x 900 mm 5-elements can be loaded into a standard Eurocontainer because the systems are designed to cover truck size. 10-elements can be transported at an area of 2350 x 2320 mm.
    The MLA case is made of multiple glued Finnish birch with an CPF core to reduce the weight.
    Each MLA element has 4 "Ancra Aircargo" bars which guarantee a flexible and safe handling of the MLA system. "Airstraps" are used for connecting the MLA loudspeaker system which allow of a vertical descend in 0,5° steps. The mainframe for the MLA "Modular Line Array" consists of a "FLYHAWK" with a TÜV-approval (German approval authority for technical products) of 12000 kg. A two-bar rail system makes it especially easy to exactly align the array. Due to this system the upper bar can be independantly aligned from the lower bar. The MLA "FLYHAWK" which is made of aluminium has a total weight of only 95 kg.
    10x MLA high focus measured in the open 95m on axis
    Specification:
    MLA Sub: 2x15” dual voice coil long excursion cone speaker
    Frequency response: 30Hz - 120Hz +/- 3dB
    Impedance: 2 x 4 ohms per speaker
    SPL: < 130dB nom. < 136dB peak
    Program power: 1400watts
    Peakpower: 5600 watts
    Connectors: 2 x Alcatel EP-5
    Dimensions: LxHxD 1160 x 470 x 900
    Weight: 95Kg
    Color: black, optional all RAL colors
    MLA High Focus: MF - dual 12” expotential horn with 70° dispersion
    HF - dual ribbon compact driver with 70° dispersion
    Frequency response: 120Hz - 20KHz +/- 3dB
    Impedance: 6 ohms / Frequency range
    SPL: < 132dB nom. < 139dB peak
    Programm power: 1000 watts
    Peakpower: 4000 watts
    Weight: 108Kg
  • Adam Selene
    • 7. Januar 2003 um 22:52
    Klingt doch super :smile:
    Noch´n Line-Array. Dabei ist Line-Array doch schon fast wieder out. Im Herbst 2003 trägt der angesagte Beschaller Punktquelle!
    Adam
    • 8. Januar 2003 um 11:52
    Wo gibt es denn die Punktschall quelle.
    zu kaufen ???
    zum Thema DESch ist ja der einzige , der ein Bändchen verwendet also ein linearray in sich selbst.
    das muss doch von dne Höhen her besser sein als die üblichen vergewaltigeten 2" er.
  • trockenbassfetischist
    • 8. Januar 2003 um 15:53
    auf dei gefahr hin dass ich mich in die nesseln setze ....
    2"er bei linearrays? ich dachte eher 1"er?
    was mir an der ganzen linearray sache auffällt ist dass die imho - die die ich gesehn habe - meiner meinung nach immer "zu kurz" sind - imho ist das ja dann gar kein linearray ????
    ferner "wundert" mich dass noch kein HErsteller da auf k-koppler setzt :smile: - immerhin ist ein k-koppler ja schon eine linienschallquelle und zwar eine "sehr kurze"
    mit k-koppler meine ich nicht den unsymetrischen bandpass mit expo schlitz und 15"er sondern das 4 x 8 dingens der name fältl mir nimemr ein war im prinzip ein "abflussrohr" mit 4 8ern
    ist zwar recht offtopic aber hat das mal jemand versucht?
  • Anonymous
    • 8. Januar 2003 um 16:59
    JA wenns vom DESCH ist muss es ja spitze sein
    Hat der eigentlich noch die RS1200
  • Audiobuddy
    • 8. Januar 2003 um 20:31
    @ anonymous:
    Grööhl...!
  • adi
    • 10. Januar 2003 um 00:11
    Punktschallquelle......kein Problem
    EAW KF750..super System, wenn man nicht ein Linearray im Rider stehen hat(dann ohne Frage das Kf769-System:
    Nähere Info´s unter
    http://www.eaw.com
    oder
    http://www.eawaudio.de
    Ich kann nur sagen , das funzt!
    gruß Adi
    Eaw-Fetisch
