  5. Licht
Dawn Griven => is sowas wirklich verwendbar?
  • uifei
  • 20. Juni 2004 um 20:20
  • uifei
    DAWN von Griven => Archithekturaussenbeleuchtung in LED Format mit
    RGB Farbwechsel
    Wer hat soetwas schon verwendet und kann mir a bissal Auskunft geben über wirkliche Anwendungsbereiche ( Flächge etc) und wirkliche Helligkeit??
    TECHNICAL SPECIFICATIONS
    SOURCE
    High brightness 1,2W power LED (Light-Emitting Diode) units
    Continuously variable light intensity
    1-100% electronic dimming facility
    No UV
    Virtually instant light production (100 ns)
    Strobe facility (12 fps)
    SOURCE LIFE
    The LED light sources used have an exceptionally long life: predicted 100.000 hours under normal operating conditions.
    OPTICS
    10¡ã beam angle (ordering code AL 1202)
    30¡ã beam angle (ordering code AL 1204)
    45¡ã beam angle (ordering code AL 1206)
    Optional Frost filter for 10¡ã optics version only (ordering code AL 1302)
    Optional 10¡ã beam set (ordering code AL 1314)
    Optional 30¡ã beam set (ordering code AL 1315)
    Optional 45¡ã beam set (ordering code AL 1316)
    Optional expansion filter (ordering code AL 1304)
    COLOUR VARIETY
    RGB additive colour mixing for countless attractive saturated colours
    Theoretical variety of 16.700.000 colour hues
    Pre-set selectable colour sequences and blends
    CONTROL OPERATION
    On-board Dip Switch set for digital data assignment and stand alone operation control
    Master and Slave
    4 channels of DMX 512 standard protocol
    Input and output DMX signal connectors
    IP65 optional dedicated DMX controller (ordering code AL 1322)
    ELECTRICAL SPECIFICATIONS
    Power supply: standard 210-250V / 50-60Hz / 0,15 Amp.
    optional 100-120V / 50-60Hz / 0,35 Amp. (available on request)
    Power Consumption: 36W max at full intensity
    (full RGB)
    Self-resetting fuse protection
    Meets CE safety standards
    HOUSING
    Die cast aluminium body
    Scratch resistant silver-grey paint
    Easy mounting system for wall, ceiling and floor with full orientation capability
    Fixing yoke included
    Outdoor and indoor use
    IP66 protection rating
    EXTERNAL OPERATING LIMITS
    -20°C to 30°C (-4°F to 86°F) temperature
    0-95% relative humidity (non condensing)
    WEIGHT
    5,5 Kg
    DMX CHANNELS
    Channel 1 - Red
    Channel 2 - Green
    Channel 3 - Blue
    Channel 4 - Dimmer / Strobe
    __________________________________________________________________
    D-Typ BoXo , PowerCon , Powercon True1 und Zubehör
    http://www.uifei.de
    BoXo Gehäuse
    Bezugsmöglichkeit des BoXo siehe: http://www.happareute.de
    • 21. Juni 2004 um 09:54
    das ist die zukunft in der lichttechnik. wird nicht warm, lebt ewig. der einzige momentane fehler ist, das die dinger noch nicht so hell wie eine 'normale' birne sind. ich denke da an hmi 575 oder so für den anfang
  • Sven M
    • 21. Juni 2004 um 11:53
    sorry test, du schreibst totalen unfug.
    1. LEDs werden auch sehr warm. Das aufwendige bei der Entwicklung von LED Leuchten ist die Kühlung, da der Wirkungsgrad bei steigender Temperatur abnimmt. Die Halbleitertemperatur darf auch 150°C nicht übersteigen.
    Das merkt man auch an dem Wirkungsgrad. Normale Halogelampen haben einen wirkungsgrad von etwa 15lumen/W. Weiße LEDs (z.B. Luxeon 1W) von etwa 22lumen/W.
    Was richtig ist, das nach vorne (in "Lichtrichtung") kaum Infrarot Strahlung abgegeben wird.
    Wo LEDs allerdings ihre vorteile haben sind Farbiges Licht (es muss nichts gefiltert werden) und an stellen wo es auf lange lebensdauer (bis 100.000Stunden) ankommt.
  • lichtlamo
    • 28. Juni 2004 um 19:48
    Leute, habt ihr eine ungefähre Vorstellung, was so ein Ding kostet..?
    Hier kann man es nachlesen:
    http://www.lmp.de/cgi-bin/A/articles.cgi?agrpnr=150&wgrpnr=19&sgrp=2
    Viel Spaß damit!
    ...und es ward licht!
  • lini
    • 28. Juni 2004 um 19:56
    Dafür sparst Du dir aber ne ganze Menge an Leuchtmitteln und ein "herkömmlicher" Scheinwerfer von Griven ist ja auch nicht nur für nen 100er zu haben!
    Stefan Linhardt
