"wafeformer" was ist das? OT aber interessant find
  • mattt
  • 27. Juli 2006 um 13:54
  • mattt
    was genau macht diese konstruktion?
    http://www.voidaudio.com/product_detail.asp?id=17
    • 27. Juli 2006 um 14:12
    im grunde nur ein anderes wort für horn
  • ukw
    • 27. Juli 2006 um 14:35
    New types of transducers were developed that emit different frequencies from different locations around their radiation surface.
    z.B. BMS Caxialtreiber
    All these locations are then channelled to the ‘waveformer’ and emitted at a precise distance down the horn.
    Planar Front <> ebene Wellenfronten siehe: http://www.party-pa.de/phpBB/viewtopic.php?p=413514#413514
    The benefits of wave forming are enormous. All frequencies reach the mouth at exactly the same time so phase cancellation is virtually eliminated. This provides an extremely flat and uniform response with a very wide bandwidth available from each band. Dispersion characteristics are radically improved due to the ‘waveformers’ refraction grid, which reduces HF beaming by a significant amount. The series 2 version also incorporates a 2 way passive - 3 way active selector, further enhancing setup flexibility. All Stasys enclosures are designed to be used with our Livedrive 4 in 8 out system controller.
    Inteferenzen siehe: http://www.pa-forum.de/phpBB/viewtopic.php?p=424659&sid=5b37e38a280bdce3a2d61a917274419c#424659
    Systemcontroller siehe: http://www.paforum.de/phpBB/viewtopic.php?p=447864#447864
    ... for a few dB's more . . .
  • tufkajck
    • 27. Juli 2006 um 15:08
    Sieht alles recht liebevoll gemacht aus.
    Sind die Sachen eher teuer?
    • 27. Juli 2006 um 17:35
    sie sind es
  • unknown_artist
    • 27. Juli 2006 um 18:01
    na ja schon viel geld - aber im Gegensatz zu Konkurrenzprodukten? Eher günstig...
  • tufkajck
    • 28. Juli 2006 um 08:32
    Wo kann man es qualitativ (nicht imagemässig) ansiedeln?
  2. Soundbase vs WWB
  6. Astera AX5 akku refreshen
  7. "Nutzbass"
