Was ist von diesen 2 Endstufen zu halten:
1. Working mode: stereo/bridge mono.
With perfect protection for short circuit, DC current.
Standard XLR and 1/4"TRS socket.
Adopt bulky power supply, it can reduce the interfering modulation distortion. interfering signal noise
MODEL: CA-1200
RMS power 8Ω): 650W
RMS power4Ω): 1000W
rated bridge power(8Ω): 1500W
Frequency Response: 20Hz - 20KHz +0 , -0.2 dB
T.H.D: <0.05%
Input Impedance: >10KΩ
Slew Rate: >40V/us
Input Sensitivity: 0dB(0.775V)Full power
Signal-to-Noise: >110dB
Cross Talk: <-80dB
Power: AC 230V/50/60Hz
2. The power of FB series amplifier is very strong and its sound is very excellent.
adopts the high-efficiency and large transformer, big capacity power supply.
The inside filter limits the circuit, and protect the normal work of loudspeaker
Low noise design
Automatic two-speed fan cooling system/tunnel Transient-free turn-on/off operation(relay)
Perfect protection for short circuit/DC votage/sub-sonic frequencies/speaker protection 0.77V,1V,1.4V input sensitivity
The Mode:Stereo and Bridge Mono
Output socket:2 Speakon
MODEL: FB-20
Output Power
8Ω1KHz,RMs 2×1000W
4Ω1KHz,RMs 2×1800W
2Ω1KHz,RMs --------
Output Power
(bridged mono) 3000W (8Ω)
THD <0.1% (Full power)
Cross Talk <-80dB
SN Ratio >100dB
Slew Rate 50V/us
Damping Factor (8Ω) >300
Frequency Response 20-50KHz+1dBl (Half power)
power supply AC230V/50-60Hz
Dimension(W×D×H) 480×130×500mm
