Was ist davon zu halten?
POWER RMS:
2x 1200Watt 8Ohm
2x 2000Watt 4Ohm
2x 3000Watt 2Ohm
1x 4000Watt 8Ohm Bridge
1x 5000Watt 4Ohm Bridge
Frequency Response 20Hz-30KHz(±0.5db)
Input Sensitivity 0.77V/0 dB
Input Impedance 23.5K OHMS
Signal/Noise 100dB>
Cross talk at rated output power 8 OHM 1 KHz >60db
Damping Factor= 1KHz 8 OHM >2100
Slew Rate interval 25V/US
Power Consumption 8 OHMS 4200W
Input and output used NEUTRIK xlr connector and speakon connector
Intelligent limiter
over load short circuit DC
overheat protection.
Sterio mode ,bridge mono mode parallel mode output
Float /ground switch
Low pass filter (50hz/-3db)
